Micro Servo with 3-pin JST Cable STEMMA Connector Compatible
PRODUCT ID: 4326
This tiny little servo can rotate approximately 180 degrees (90 in each
direction), and works just like the standard kinds you're used to but smaller.
You can use any servo code, hardware or library to control these servos. Good
for beginners who want to make stuff move without building a motor controller
with feedback & gear box, especially since it will fit in small places. Of course,
it's not nearly as strong as a standard servo. Works great with the Motor Shield
for Arduino, or by just wiring up with the Servo library. Comes with a few horns
and hardware.
This servo is just like our classic Micro Servo but has a 3 pin JST PH cable at the
end! This makes it perfect for plug-and-play support with any of our boards
that have 3-pin STEMMA connectors, like
the PyPortal, HalloWing, PyGamer/PyBadge, etc! So you can just plug right into
the connector and get twistin'
To control with an Arduino, we suggest using the Servo library included with the
Arduino IDE (see here for an example sketch). Position "0" (1.5ms pulse) is
middle, "90" (~2ms pulse) is all the way to the right, "-90" (~1ms pulse) is all the
way to the left. For CircuitPython, check out this guide. MakeCode also has
Servo support.
The 19cm-long JST cable is color-coded:
Black for GND
Red for 5V
White for Data
Note that the default servo pulse widths (usually 1ms to 2ms) may not give you
a full 180 degrees of motion. In that case, check if you can set your servo
controller to custom pulse lengths and try 0.75ms to 2.25ms. You can try
shorter/longer pulses, but be aware that if you go too far you could break your
servo!
TECHNICAL DETAILS
Specs:
Size: 23 x 11 x 29mm
Voltage: 3V to 6V DC
Weight: 9g / 0.32oz
Speed: 0.12 sec/60 (at 4.8V)
Torque: 1.6 kg-cm
Working Temp: -30ºC ~ 60ºC
Teflon Bushing, 19cm wire, coreless motor, servo arms & screw included
https://www.adafruit.com/product/4326/9‐22‐19
很抱歉,暂时无法提供与“4326”相匹配的价格&库存,您可以联系我们找货
