434
    ADAFRUIT
    塑料 - 未指定 盒 橙色 手持,包含盖 4.961" 长 x 2.520" 宽(126.00mm x 64.00mm) X 0.866"(22.00mm)
434 数据手册
Large Modular Snap Box - SMD component storage - Orange PRODUCT ID: 434     Description   For storing small parts (especially SMT/SMD components), these little modular boxes are ideal. They have individual clear pop-open covers so you can keep only the ones you want open - less risk of mixing up parts or having a spill. The brilliance of these boxes is that they also snap together, in any configuration you want. You can mix all the sizes to make the ideal box for your needs, and add on more containers as necessary. There's a leaf-spring hinged top that will last much longer than an all-plastic molded top. These large boxes are 126mm wide, 64mm long and 22mm tall on the outside and are ideal for small parts, components, or beads (or really anything!) This particular box set is made of orange plastic and is 'equivalent' to 10 'tiny' boxes (5 x 2). Comes as a single box Technical Details                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/434 5‐5‐17
很抱歉,暂时无法提供与“434”相匹配的价格&库存,您可以联系我们找货
    • 5+17.05966
