Adafruit 8x8 Trellis Feather M4 Acrylic
Enclosure + Hardware Kit
PRODUCT ID: 4372
A super-specifically-laser-cut enclosure that turns your 8x8 'Trellis into a
handheld light/music maker! Perfect for your next cool interface, MIDI
instrument, control panel... whatever could benefit from a glow-up with an
elegant black and white enclosure and with beautiful diffused colorful buttons.
Note: This is only the plastic enclosure and hardware!
To complete this project you'll need also:
1 x Adafruit Feather mainboard. It's designed for use with any of our
Feather boards (except the FONA) - so you can pick from Bluetooth, WiFi,
high speed, etc. For CircuitPython use, the nRF52840 or M4 feathers are
recommended. For Arduino use, any of them will work.
4 x Adafruit NeoTrellis RGB Driver PCB for 4x4 Keypad
4 x Silicone Elastomer 4x4 Button Keypad
Optional but recommended! 4-pin JST cable to simplify wiring so you
don't need to do as much soldering!
If you'd like to make the board portable (say you've got a wireless bluetooth or
WiFi feather...)
1 x Lithium Ion Polymer Battery - 3.7v 500mAh
1 x Mini Panel Mount DPDT Toggle Switch
Some light soldering is required! You'll have to solder wires to the switch as well
as to the Feather.
Includes:
1 x Black Acrylic Cutout 1.5mm thick
14 x Clear Acrylic Cutouts 3mm thick
4 x M3 black nylon spacers 15mm long
8 x M3 black nylon screws 8mm long
4 x M2.5 black nylon screws 10mm long
4 x M2.5 black nylon nuts
4 x M2.5 standoffs 3mm long (un-threaded)
1 x set of Little Rubber Bumper Feet (4 bumpers total)
These acrylic cutouts come with paper backings on both sides (it protects the
acrylic while laser cutting and shipping). You'll need to peel those off before
assembly.
TECHNICAL DETAILS
Fully assembled 8x8 Trellis dimensions: 146mm x 146mm x 30mm / 5.7"
x 5.7" x 1.1"
https://www.adafruit.com/product/4372/9‐23‐19
很抱歉,暂时无法提供与“4372”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+228.829271+28.38617
