4433
    ADAFRUIT
    LED 环形管灯,2.2" 内径
4433 数据手册
      LED Ring Light - 76mm Diameter PRODUCT ID: 4433 This LED Ring Light is designed for use with microscopes but we kinda like the design and think it could be a really nice LED element for costuming or lighting effects or... something else? Of course you could also just use it as a great addition to your photo and video projects. It's super illuminating with cool, soft, light, perfect for photo studio lighting. We've also seen these used as microscope illuminators for intense, focused, and shadow-free detail work. Hook it up with 9V power, and you're one step closer to lights, camera, action! You'll need to provide 9V power, it won't work with 5V for sure. This wall adapter will do the job for when you have an outlet. If you want to power from a USB supply, try this USB-9V booster cable. For DIY connections, check out our 2.1mm male DC plugs. Note these are not 'NeoPixel' LED strips, you can turn the entire thing on/off or dim it with a PWM power signal but you cannot turn on individual LEDs. Originally, this ring came with a dimmer, but it was built into the wall adapter so not very useful for portable projects. This guide on analog RGB LED strip control will show you how to dim a 9V LED - you'll want a microcontroller with a PWM output, and a single N-MOSFETs to control the power TECHNICAL DETAILS  Weight: 41.4g  Overall diameter: 76mm / 2.9"  Inner diameter: 57.5mm / 2.2"  Cable length: 8.5mm / 0.33"           https://www.adafruit.com/product/4433/12‐20‐19
很抱歉,暂时无法提供与“4433”相匹配的价格&库存,您可以联系我们找货
