Adafruit Mini PiTFT 1.3" - 240x240 TFT
Add-on for Raspberry Pi
PRODUCT ID: 4484
If you're looking for the most compact li'l color display for
a Raspberry Pi (most likely a Pi Zero) project, this might be just
the thing you need!
The Adafruit Mini PiTFT - 1.3" 240x240 Color TFT Add-on for Raspberry Pi is
your little TFT pal, ready to snap onto any and all Raspberry Pi computers, to
give you a little display. The Mini PiTFT comes with a full color 240x240 pixel
IPS display with great visibility at all angles. The TFT uses only the SPI port so its
very fast, and we leave plenty of pins remaining available for buttons, LEDs,
sensors, etc. It's also nice and compact so it will fit into any case.
This display is super small, only about 1.3" diagonal, but since it is an IPS
display, it's very readable with high contrast and visibility. We had a little space
on the top-left so we give you two tactile buttons on GPIO pins so you can
create a simple user interface. On the bottom we have a Qwiic/STEMMA QT
connector for I2C sensors and device so you can plug and play any of our
STEMMA QT devices.
Using the display is very easy, we have a kernel driver and Python library for the
ST7789 chipset. You can set it up as a console output so you can have text and
user interface through the Raspberry Pi OS or you draw images, text, whatever
you like, using the Python imaging library. Our tests showed ~15 FPS update
rates so you can do animations or simple video.
Comes completely pre-assembled and tested so you don't need to do anything
but plug it in and install our Python code! Works with any Raspberry Pi
computer.
TECHNICAL DETAILS
Product Dimensions: 38.4mm x 31.5mm x 7.2mm / 1.5" x 1.2" x 0.3"
https://www.adafruit.com/product/4484/1‐13‐20
很抱歉,暂时无法提供与“4484”相匹配的价格&库存,您可以联系我们找货
