Adafruit DPS310 Precision Barometric
Pressure / Altitude Sensor - STEMMA QT
/ Qwiic
PRODUCT ID: 4494
How high are you right now? If you had a precision altitude sensor, you would
know for sure! The DPS310 sensor from Infineon a high precision barometric
sensor, perfect for measuring altitude changes with a up to ±0.002 hPa (or
±0.02 m) precision high precision mode and ± 1 hPa absolute accuracy. That
means you can know your absolute altitude with 1 meter accuracy when you set
the sea-level pressure, and measure changes in altitude with up to 2 cm
precision. This makes it a great sensor for use in drones or other altitude-
sensitive robots. This sensor would also do well in any environmental sensing
kit, you can use it to predict weather system changes
You can use this sensor with either I2C or SPI, so its easy to integrate. It also
has a temperature sensor built in with ± 0.5°C accuracy. For the lowest noise
readings, set it up to take multiple measurements and perform a low-pass filter,
that capability is built in! You can use it from 300 to 1200 hPa and in ambient
temperature ranges from -40 to 85 °C.
To make life easier so you can focus on your important work, we've taken the
sensor and put it onto a breakout PCB along with support circuitry to let you use
it with 3.3V (Feather/Raspberry Pi) or 5V (Arduino/ Metro328) logic levels.
Additionally since it speaks I2C you can easily connect it up with two wires (plus
power and ground!). We've even included SparkFun qwiic compatible STEMMA
QT connectors for the I2C bus so you don't even need to solder! Just wire up to
your favorite micro and you can use our CircuitPython/Python or Arduino
drivers to easily interface with the DPS310.
TECHNICAL DETAILS
Product Dimensions: 25.5mm x 17.7mm x 4.6mm / 1.0" x 0.7" x 0.2"
https://www.adafruit.com/product/4480/1‐27‐20
很抱歉,暂时无法提供与“4494”相匹配的价格&库存,您可以联系我们找货
