4523
    ADAFRUIT
    40 位置 FFC,FPC 连接器 扩展件 0.020"(0.50mm) 自由悬挂
4523 数据手册
        40-pin 0.5mm FFC / FPC Extender PRODUCT ID: 4523   DESCRIPTIONThis 40‐pin FFC / FPC Extender is very simple. It lets you connect two 40‐pin  0.5mm pitch FFC (Flexible Flat Cable) / FPC (Flexible Printed Circuit) cables end‐to‐ end and extend the length. Note that pin 1 of one cable is connected to pin 40 of the other so you need to use a cable that has contacts on the same side (type A cable) Carefully pry the two ears of the connectors, plug the cables with contacts pointing up, and then push the ears back in for a solid connection. We also carry a 50-pin 0.5mm version and a 24-pin 0.5mm version.       https://www.adafruit.com/product/4523/5‐27‐20
很抱歉,暂时无法提供与“4523”相匹配的价格&库存,您可以联系我们找货
