Adafruit Bonsai Buckaroo - micro:bit &
CLUE Plant Care Helper
PRODUCT ID: 4534
We can’t wait for spring to arrive, and we’re looking forward to caring for some
plants! We designed this little add-on for micro:bit or CLUE boards – bolt it on
with 5 screws to get a buzzer/beeper, motor driver, and breakouts for
connecting a soil sensor (two alligator clips + nails work just fine). Simple, but
effective!
8mm Buzzer/Speaker on pin P0 - have your plant kit beep when it wants
watering, or have it sing a song when its nice and happy.
3V Motor control (on/off) on pin P2 - connect to a water pump to
automatically water dry plants
Alligator clip pads for pin P1, 3V and GND - connect to two alligator clips
and nails to measure soil resistance
Works with micro:bit in Arduino, micropython or MakeCode. For CLUE, you can
use CircuitPython or Arduino.
Please note this product does not come with a pump, tubing, alligator clips,
nails, CLUE or micro:bit! It's just the control board that attaches to the micro:bit
or CLUE!
You'll want to also pick up separately:
micro:bit Go Bundle or Adafruit CLUE
Horizontal style or vertical style 3V water pump
Vinyl tubing - 8mm diameter (also available in any hardware store)
Two alligator clips in any color
Two stainless steel nails (available in any hardware store)
TECHNICAL DETAILS
Product Dimensions: 52.0mm x 26.0mm x 6.4mm / 2.0" x 1.0" x 0.3"
Product Weight: 8.0g / 0.3oz
https://www.adafruit.com/product/4534/3‐23‐20
很抱歉,暂时无法提供与“4534”相匹配的价格&库存,您可以联系我们找货
