4536
    ADAFRUIT
    适配器连接器 USB-C(USB TYPE-C),插头 至 2.1mm DC 插孔 黑色
4536 数据手册
      2.1mm 5VDC Barrel Jack to USB C Adapter PRODUCT ID: 4536 As technology changes and adapts, so does Adafruit, and speaking of adapting, this adapter has a 2.1mm barrel jack socket and a USB C plug - you could use this to power a USB C device from a common wall adapter. USB C is the latest industry-standard connector for transmitting data and power. Like Lightning and MagSafe cables, USB C has no up or down orientation. Plug this adapter onto the end of a 2.1mm 5VDC barrel jack, and now it's a USB C however please be aware there's no protection circuit or Power Delivery negotiation, you really should only be using this with a 5V adapter but if you have the wrong polarity or voltage, you could damage your electronics! Works great with any device that has a USB C port and does not require a USB Power Delivery chip, such as the Raspberry Pi 4. To match, you can use our 2A 5V wall power supplies! TECHNICAL DETAILS Product Weight: 9.0g / 0.3oz     https://www.adafruit.com/product/4536/8‐31‐20
很抱歉,暂时无法提供与“4536”相匹配的价格&库存,您可以联系我们找货
