Adafruit LSM6DSOX + LIS3MDL
FeatherWing - Precision 9-DoF IMU
PRODUCT ID: 4565
Upgrade any Feather board with precision motion sensing with the ST 9-DoF
IMU, an all-in-one sensing 'Wing. It sports two fantastic sensors from ST to
provide 9 degrees of full-motion data.
The board includes an LSM6DSOX, a 6-DoF IMU accelerometer + gyro. The 3axis accelerometer can tell you which direction is down towards the Earth (by
measuring gravity) or how fast the board is accelerating in 3D space. The 3-axis
gyroscope can measure spin and twist. This new sensor from ST has very low
gyro zero rate and noise, compared to the MPU6050 or even LSM6DS33 so it's
excellent for orientation fusion usage: you'll get less drift and faster responses.
The LSM6DSOX has flexible data rates and ranges. For the
accelerometer: ±2/±4/±8/±16 g at 1.6 Hz to 6.7KHz update rate. For the
gyroscope: ±125/±250/±500/±1000/±2000 dps at 12.5 Hz to 6.7 KHz. There
are also some nice extras, such as built-in tap detection, activity detection,
pedometer/step counter, and a programmable finite state machine / machine
learning core that can perform some basic gesture recognition.
It also includes a LIS3MDL 3-axis magnetometer that can sense where the
strongest magnetic force is coming from, generally used to detect magnetic
north. The three triple-axis sensors add up to 9 degrees of freedom, by
combining this data you can orient the board. Check out our guide on how to do
that!
Both sensors are connected over the shared I2C bus, so you can use it with any
and all Feathers! We also break out the interrupt pins and address-selection
jumpers in case you want multiple Feathers or have I2C address conflicts. We've
got both Arduino (C/C++) and CircuitPython libraries available so you can use it
with any Feather board and get data readings in under 5 minutes. Four
mounting holes make for a secure connection.
Additionally, since it speaks I2C you can easily connect it up with two wires (plus
power and ground!). We've even included a SparkFun qwiic compatible STEMMA
QT connector for the I2C bus so you don't even need to solder to connect more
of your favorite ST sensors like the LPS25! Simply connect a plug-and-play cable
to more sensor data, OLED displays, or other I2C devices connected ASAP.
We also wrote libraries to help you get these sensors integrated with your
Arduino/C++. This library covers the accel/gyro and this library is for the
magnetometer. For advanced Arduino usage, ST has their own fully-featured
library that includes extras such as FIFO management and tap detection for the
LSM6DSOX and also for the LIS3MDL magnetometer.
Comes fully tested and assembled with a bit of standard 0.1" header.
TECHNICAL DETAILS
LSM6DSOX Specifications:
Accelerometer ±2/±4/±8/±16 g at 1.6 Hz to 6.7KHz update rate
Gyroscope: ±125/±250/±500/±1000/±2000 dps at 12.5 Hz to 6.7 KHz
Continuous and single-conversion modes
Advanced pedometer, step detector and step counter
Significant Motion Detection, Tilt detection
Standard interrupts: free-fall, wakeup, 6D/4D orientation, click and
double-click
Programmable finite state machine: accelerometer, gyroscope and
external sensors
Machine Learning Core
I2C Address 0x6A or 0x6B
LIS3MDL Specifications:
±4/±8/±12/±16 gauss selectable magnetic full scales
16-bit data output
Interrupt generator
I2C Address 0x1C or 0x1E
https://www.adafruit.com/product/4565/6‐4‐20
很抱歉,暂时无法提供与“4565”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+167.507201+20.28420
