4696
    ADAFRUIT
    CABLE A PLUG TO C PLUG 3.28
4696 数据手册
      USB Type C Cable with Data/Charge Switch - 1 meter long PRODUCT ID: 4696 DESCRIPTION Perhaps your smart phone, tablet, or even your Raspberry Pi 4, charges off of USB, but can you really trust that charging station at the airport? Now you can control when to allow data in or out of your device with this specially-designed USB cable.Voila! Your cable's data lines can now be switched on or off. USB C is the latest industry-standard connector for transmitting data and power. Like Lightning and MagSafe cables, USB C has no up or down orientation. And who among us has inserted USB correctly the first time? Works great with any device that has a USB C port. Not only is it great for privacy and security concerns, it's also good for use with devices that automatically sync when you plug them into a computer. With the data lines off, you can use it while it charges. This is the most useful thing you never knew you needed! It is super easy to use. Comes with a USB C plug on one end and a USB A plug on the other. In between is an in-line switch that you can set to either "Data" or "Charger". When Data is set, both D+ and D- data lines pass through. When Charger is set, they are both disconnected. This cable will also work with anything that has a standard USB-C port. We also have a version that is an all-in-one Micro USB cable. Please note: Devices don't like it when the data lines mysteriously appear and disappear. We recommend setting the cable function and then plugging in your device.       https://www.adafruit.com/product/4696/9‐18‐20
很抱歉,暂时无法提供与“4696”相匹配的价格&库存,您可以联系我们找货
