Arcade Button - 30mm Translucent Green
PRODUCT ID: 475
Description
A button is a button, and a switch is a switch, but these translucent arcade buttons are in a class of their
own. They're the same size as common arcade controls (often referred to as 30mm diameter) but have some
nice things going for them that justify the extra dollar.
First, they look fantastic, all 6 colors have a crystal translucent glossy look. Although they do not have
LEDs built in, we're confident that sticking a diffused LED into the body would make it light up very
nicely. They are also shorter than cheap arcade controls, and snap into place, so you only need 1.5" of depth
(1.25" if you bend the contacts over). The button action is smooth, without a strong click, yet you can
definitely feel when the button is pressed. A tiny micro-switch is pre-installed, with gold plated contacts.
Technical Details
Weight: 12 grams
Engineered in NYC Adafruit ® https://www.adafruit.com/product/475 6‐14‐17
很抱歉,暂时无法提供与“475”相匹配的价格&库存,您可以联系我们找货
