5514
    ADAFRUIT
    6.7"(170.00mm) 接线夹,隔离型(3) 至 伺服连接器 测试引线 3 引线,黑色、红色和白色
5514 数据手册
Shrouded Servo to Alligator Clip Cable - 17cm long Product ID: 5514 Description Stretch out your servo connections with this flexible servo to alligator clip cable. It has a 3-pin shrouded "male" connection to plug your servo into and then, 17cm later, three alligator clips - it even keeps the common red/black/white color coding for power/ground/signal as you'd expect! This cable is perfect for connecting a servo to something with clip-pads like a Circuit Playground or micro:bit, or maybe for prototyping / power monitoring from a benchtop supply. A great add-on for all the servos we carry. Technical Details • Cable Dimensions: 17cm / ~6.7" • 26AWG wires • Diagram https://www.adafruit.com/product/5514 8-17-22
很抱歉,暂时无法提供与“5514”相匹配的价格&库存,您可以联系我们找货
