USB 2.0 Powered Hub - 7 Ports with 5V 2A
Power Supply
PRODUCT ID: 961
Description
Add lots more USB capability to your Raspberry Pi or computer using this powered USB 2.0 hub. It adds a
full seven powered ports, all at USB 2.0 speeds so you can use video cameras and other high speed
devices (cheaper hubs are v1.1 and not as fast!)
The extra sauce with this hub is that you can power it with an external 5V adapter. There's a 2 Amp adapter
included, which should be plenty to run even power-hungry cameras, WiFi adapters, and flash disks. The
hub is fused for two amps using a resettable PTC fuse. Unlike cheaper hubs, this one has a single chip that
provides all 7 ports instead of having two 4 port hubs chained inside. This is a great companion to your Pi,
as they only have one or two USB ports and limited powering capability - we've tested it with great success
on the Pi as well as our Mac and Windows desktop machines
Comes with a 7-port hub, a USB extender cable, 5V 2A UL listed power adapter that can be used with 100240VAC wall power.
Technical Details
o
o
o
o
o
o
o
7 USB 2.0 ports
Multiple Transaction Translator supports low-speed and high-bandwidth USB devices
Wrap-around cable protects port when not in use
Versatile bus or AC powered with over-current protection; hot-swappable
Plug and play - Windows and Mac compatible
Adapter tip: 3.67mm / 0.14"
Hub Dimensions: 50mm x 88mm x 21mm / 2" x 3.5" x 0.8"
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“961”相匹配的价格&库存,您可以联系我们找货
