ADT-TR-OM3MDC100G SR4 QSFP28
    ADTEK(亚德)
    收发器模块 光学 100Gbps 850nm MDC 可插入式,SFP
ADT-TR-OM3MDC100G SR4 QSFP28 数据手册
PRODUCT SPECIFICATION 100m Parallel MMF 100G SR4 QSFP28 Optical Transceiver FEATURES :  Hot-pluggable QSFP28 form factor  Supports 103.1Gb/s aggregate bit rate  Power dissipation < 2.5W  RoHS-6 compliant  Commercial case temperature range of 0°C to 70°C  Single 3.3V power supply  Maximum link length of 100m on OM4 Multimode Fiber (MMF)  4x25Gb/s 850mm VCSEL-based transmitter  4x25G electrical interface  MDC interface APPLICATIONS:  100GBASE-SR4 100G Ethernet DESCRIPTION : 100G QSFP28 transceiver modules are designed for use in 100 Gigabit Ethernet links over multimode fiber. They are compliant with the QSFP28 MSA and IEEE 802.3bm 100GBASE-SR4 and CAUI-4. Digital diagnostics functions are available via the I2C interface, as specified by the QSFP28 MSA. The transceiver is RoHS-6 compliant per Directive 2011/65/EU.  Absolute Maximum Ratings Page 1 Parameter Symbol Min. Typical Max. Unit Storage Temperature TS -40 +85 °C Case Operating Temperature TA 0 70 °C Supply Voltage VCC -0.5 4 V Relative Humidity RH 0 85 % PRdmg 3.4 Receiver Damage Threshold, per Lane dBm  Electrical Characteristics (EOL, TOP = 0 to 70C, VCC = 3.135 to 3.465 Volts) Parameter Symbol Min. Vcc 3.135 Supply Voltage Supply Current Module total power Typical Icc P Max. Unit 3.465 800 2.5 V mA W Note Transmitter Section: Signaling rate per lane Differential pk-pk input voltage tolerance Single-ended voltage tolerance 25.78125 ± 100ppm 900 Vin,pp,diff Vin,pp Module stress input test Gb/s mV -0.35 +3.3 Per Section 83E.3.4.1, IEEE 802.3bm V V Receiver Section: Signaling rate per lane Differential data output swing Vout,pp Eye width Eye height, differential Vertical eye closure Transition time (20% to 80%) VEC tr, tf 25.78125 ± 100ppm 100 400 300 600 400 600 800 600 1200 0.57 228 5.5 12 V mVpp UI mV dB ps  Optical Characteristics (EOL, TOP = 0 to 70C, VCC = 3.135 to 3.465 Volts) Parameter Symbol Min. Typical Max. Unit Note Transmitter Section: Signaling Speed per Lane Center Wavelength RMS spectral width λt △λ 25.78125 ± 100ppm 840 850 860 0.6 Gb/s nm nm Page 2 1 Average Optical Power per Lane Optical Power OMA per Lane Launch Power [OMA] minus TDEC per Lane TDEC per Lane Optical Extinction Ratio Optical Return Loss Tolerance Encircled Flux TxOMA -8.4 -6.4 P-TDEC -7.3 TXPx 2.4 3 dBm 4.3 TDEC ER 2 12 ORL >86% at 19 um
ADT-TR-OM3MDC100G SR4 QSFP28 价格&库存
很抱歉,暂时无法提供与“ADT-TR-OM3MDC100G SR4 QSFP28”相匹配的价格&库存,您可以联系我们找货
