Male-Male Sandwich Mounts
P
L
Male-Female Sandwich Mounts
P
P
Female-Blank Sandwich Mounts
L
L
P
D
D
G
Male-Blank Sandwich Mounts
L
D
G
G
G
TD
Family
Product
D
Load (lbs)
TD
Dimensions
Metal Insert
D
L
P
G
TD
Maximum
Compressive
Maximum
Shear
Diam.
(in)
Length
(in)
Type
Overall
Height
Grip
(in)
Depth
(in)
MM-100-UC04-H
MM-100-UC04-SL20100
MM-100-UC04-SL25200
MM-200-UC06-H
MM-200-UC06-SL20100
MM-200-UC06-SL25200
MM-200-UC08-H
MM-200-UC08-SL20100
MM-200-UC08-SL25200
MM-300-UC25-H
MM-400-UC31-H
4.0
0.5
0.5
8.0
1.0
1.0
8.0
1.0
1.0
20.0
50.0
1.5
0.2
0.2
3.0
0.4
0.4
3.0
0.4
0.4
5.0
13.0
.275
.280
.280
.400
.405
.405
.400
.405
.405
.615
1.00
.320
.320
.320
.500
.500
.500
.500
.500
.500
.625
.750
#4-40
#4-40
#4-40
#6-32
#6-32
#6-32
#8-32
#8-32
#8-32
1/4-20
5/16-18
.200
.200
.200
.375
.375
.375
.375
.375
.375
.500
.625
.060
.060
.060
.060
.060
.060
.060
.060
.060
.100
.100
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
MB-100-UC04-H
MB-100-UC04-SL20100
MB-100-UC04-SL25200
MB-200-UC06-H
MB-200-UC06-SL20100
MB-200-UC06-SL25200
MB-200-UC08-H
MB-200-UC08-SL20100
MB-200-UC08-SL25200
MB-300-UC25-H
MB-400-UC31-H
4.0
0.5
0.5
8.0
1.0
1.0
8.0
1.0
1.0
20.0
50.0
.275
.280
.280
.400
.405
.405
.400
.405
.405
.615
1.00
.320
.320
.320
.500
.500
.500
.500
.500
.500
.625
.750
#4-40
#4-40
#4-40
#6-32
#6-32
#6-32
#8-32
#8-32
#8-32
1/4-20
5/16-18
.200
.200
.200
.375
.375
.375
.375
.375
.375
.500
.625
.060
.060
.060
.060
.060
.060
.060
.060
.060
.100
.100
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
Male-Female
MF-100-UC04-H
MF-100-UC04-SL20100
MF-100-UC04-SL25200
MF-200-UC06-H
MF-200-UC06-SL20100
MF-200-UC06-SL25200
MF-200-UC08-H
MF-200-UC08-SL20100
MF-200-UC08-SL20100
MF-300-UC25-H
MF-400-UC31-H
2.0
0.3
0.3
4.0
0.6
0.6
4.0
0.6
0.6
12.0
45.0
.275
.280
.280
.400
.405
.405
.400
.405
.405
.615
1.00
.320
.320
.320
.500
.500
.500
.500
.500
.500
.625
.750
#4-40
#4-40
#4-40
#6-32
#6-32
#6-32
#8-32
#8-32
#8-32
1/4-20
5/16-18
.200
.200
.200
.375
.375
.375
.375
.375
.375
.500
.625
.060
.060
.060
.060
.060
.060
.060
.060
.060
.100
.100
.110
.110
.110
.160
.160
.160
.160
.160
.160
.260
.290
Female-Blank
FB-100-UC04-H
FB-100-UC04-SL20100
FB-100-UC04-SL25200
FB-200-UC06-H
FB-200-UC06-SL20100
FB-200-UC06-SL25200
FB-200-UC08-H
FB-200-UC08-SL20100
FB-200-UC08-SL25200
FB-300-UC25-H
FB-400-UC31-H
2.0
0.3
0.3
4.0
0.6
0.6
4.0
0.6
0.6
12.0
45.0
.275
.280
.280
.400
.405
.405
.400
.405
.405
.615
1.00
.320
.320
.320
.500
.500
.500
.500
.500
.500
.625
.750
#4-40
#4-40
#4-40
#6-32
#6-32
#6-32
#8-32
#8-32
#8-32
1/4-20
5/16-18
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
n/a
.110
.110
.110
.160
.160
.160
.160
.160
.160
.260
.290
ISOLOSS
SPR-00009
HD/SL SANDWICH
MOUNTS
Male-Male
Male-Blank
材質 ISOLOSS HD
數量100, 200
n/a
n/a
n/a
n/a
n/a
n/a
0.8
0.1
0.1
2.0
0.3
0.3
2.0
0.3
0.3
3.5
10.0
n/a
n/a
n/a
n/a
n/a
n/a
“H” after part number indicates ISOLOSS HD material; “SL-XXXXX” after part number indicates ISOLOSS SL material. Dimensions given here are nominal.
Exact specification print available on request.
13
Website: www.earsc.com
E-mail: solutions@earsc.com
7911 Zionsville Road
Indianapolis, IN 46268
Phone (317) 692-1111
Fax (317) 692-3111
650 Dawson Drive
Newark, DE 19713
Phone (302) 738-6800
Fax (302) 738-6811
M o l d i n g
M a t e r i a l s / C u s t o m
Fo r
c u s t o m - engineered parts to
control noise, vibration or shock,
E-A-R offers numerous moldable
thermoplastic and thermoset
materials to choose from.
VersaDamp 2000 Series TPEs are olefinic
dynamic vulcanizates. They are usually
selected to optimize damping performance or durometer or both. The materials
eliminate the need to make tradeoffs in
damping and operating temperature
range. They feature durometers ranging
from 40 Shore Ato 74 Shore A, and
they have widely varying energy
control capabilities.
Thermoplastics: ISODAMP C-1000
Series Thermoplastics are highly
damped vinyl materials that exhibit
extremely low amplification at resonance and quick return to system
equilibrium after shock input. C-1000
Series materials are soft and pliable, yet
physically strong and wear-resistant.
The three formulations are engineered
to perform in discrete temperature
ranges: ISODAMP C-1002 from 13C to
41C (55F to 105F); C-1105 from 27C to
54C (80F to 130F); and C-1100 from
35C to 63C (95F to 145F).
Description
Typical Process
Method
Peak Transmissibility
at Resonance (dB)
Hardness Nominal
ASTM D2240
15 sec impact at 23C (73F)
Shore A Durometer
Bashore Resilience
1st Rebound (%)
Tensile Strength (psi)
Elongation (%)
Post Compression
Recovery (%)
at 20C (68F)
Resistance to:
Ozone
Water
UV
Kerosene
Thermosets: ISOLOSS HD Elastomers
exhibit excellent load bearing strength,
compression-set resistance and stiffness
stability over a broad temperature
range. With a recommended maximum
continuous operating temperature of
90C (195F), the materials can withstand
intermittent exposure as high as 107C
(225F). Designed specifically for use
in metal-bonded elastomeric mounts,
these elastomers exhibit excellent
environmental-resistance properties.
ISODAMP C-8000 Series Thermoplastics
are highly damped elastomers that
provide the same benefits of the C-1000
series materials in a halogen-free
formulation. They are also formulated
to be environmentally clean; providing
excellent flammability performance
(UL 94 V-0) without halogens, silicones
or metal oxides. This unique family of
elastomers will meet most of the
emerging environmentally “green”
initiatives and specifications. ISODAMP
C-8000 materials have a peak performance temperature range of 17C to 41C
(62F to 105F).
Typical Properties
Property
P a r t s
ISOLOSS SL Thermoset Materials
combine good damping performance
with stable material properties over a
broad temperature range. The molding
stability of ISOLOSS SL materials allows
it to be used in isolator and snubber
designs with very thin sections.
ISODAMP ISODAMP ISODAMP ISODAMP VersaDamp VersaDamp VersaDamp
C-1002
C-1105
C-1100
C-8002
V-2325
V-2590
V-2725
ISOLOSS
HD
Vinyl
Solid
Injection
Mold
Vinyl
Solid
Injection
Mold
Vinyl
Solid
Injection
Mold
TPE
Solid
Injection
Mold
TPE
Solid
Injection
Mold
TPE
Solid
Injection
Mold
TPE
Solid
Injection
Mold
3
3
3
3
13
7
11
4
56
63
70
57
40
57
74
58
4.8
1574
459
5.4
1807
417
5.7
2058
317
4.0
1150
750
40
380
278
12.0
653
344
35
976
381
86
77
76
82
90
85
Good
Good
Good
Fair
Good
Good
Good
Fair
Good
Good
Good
Fair
Good
Good
Fair
Poor
Good
Good
Good
Poor
Good
Good
Good
Poor
ISOLOSS
SL-20100
ISOLOSS
SL-25200
Urethane
Synthetic
Synthetic
Solid
Rubber
Rubber
Transfer/
Transfer/
Transfer/
Compression Compression Compression
Mold
Mold
Mold
7
7
21
27
4.5
1300
424
12
530
625
12
636
600
80
96
97
97
Good
Good
Good
Poor
Good
Good
Good
Fair
Good
Good
Good
Poor
Good
Good
Good
Poor
See material summary sheets for more data and testing method information. The data listed in this guide are typical or average values based on tests conducted by independent laboratories or by the
manufacturer. They are indicative only of the results obtained in such tests and should not be considered as guaranteed maximums or minimums. Materials must be tested under actual service to
determine their suitability for a particular purpose.
Fax (317) 692-3111
650 Dawson Drive
Newark, DE 19713
Fax (302) 738-6811
14
很抱歉,暂时无法提供与“MB-400-UC31-H”相匹配的价格&库存,您可以联系我们找货
