MM-313-069-161-41WC
MM-313-069-161-41WC
    AIRBORN
    D-Sub 电缆组件 D 型,微型 D 多股,单股 1.50'(457.20mm) 插头,公引脚 至 单条导线引线 无屏蔽
MM-313-069-161-41WC 数据手册
~AirBorn Specifications Materials and Finishes * Contacts: Pins : BeCu alloy strip per ASTM B194 Sockets: Brass per ASTM B121 / B121 Mor ASTM B16 / B16M or ASTM B453 Contact Finish:** Gold plate per ASTM B488 Shells: Aluminum Alloy 6061-T6 per SAEAMS-QQ-A-250/11 or 6061-T6511 per SAE AMS-QQ-A-200/8 or Stainless Steel 300 series per ASTM A484 / A484M and ASTM A582 / A582M Passivated per SAE AMS2700 Aluminum Shell Finishes:** Electroless Nickel per SAE AMS2404, Class 3, 500 µ" min Electrodeposited Cadmium per SAE AMS-QQ-P-416, Type II , Class 3 Black Anodized per MIL-A-8625 , Type Ill , Class 2 Gold per MIL-DTL-45204, Type 11 , Grade C, Class 0 Zinc Nickel Alloy per ASTM B841 , Class 1 Pure Electrodeposited Aluminum per MIL-DTL-83488, type 2 High Phosphorus Nickel with Fluorocarbon Polymer additive per SAE AMS2454 , Grade 2E , Type V (9% MIN Phosphorus content by weight) Molded Insulators: Glass filled polyphenylene sulfide per MIL-M-24519 Embedment: Frey Engineering Co. insulating compound CF3003-80 and L-11-49 or equivalent Jackscrews, Jackposts and Nuts: Corrosion resistant steel per ASTM A320 or ASTM A484 / A484M and ASTM A582 / A582M Passivated per SAE AMS2700 Clips and Washers: Corrosion resistant steel per ASME 18.24 or NASM35333 or ASTM A484/A484M and ASTM A582/A582M (For reference only: ASME 18.24 CRS per ASTM A693 and NASM35333 CRS per ASTM A240) Passivated per ASME 18.24 or NASM35333 or SAE AMS2700 (For reference only: ASME 18.24 and NASM35333 passivated per SAE AMS2700) Guide Pins Corrosion resistant steel per ASTM A484 / A484M and ASTM A582 / A582M Passivated per SAE AMS2700 Latches Beryllium copper in accordance with ASTM B194 Electroless Nickel plate per SAE AMS2404 lnterfacial Seal Gaskets: Tolerances:- Fluorosilicone per MIL-DTL-25988 Unless otherwise specified: Fractions= ±1/64" Decimals = ±.01 0" Angles= ±5° W ire lengths : insulated/stranded = +1 .0"/-0.0" uninsulated/solid = +0.2"/-0.0" Note: AirBorn can manufacture special configurations for your exact specifications. * = Reference the above listed specifications or an equivalent industry standard when applicable ** =When ordering to Mil Spec P/N, Mil Spec requirements apply REV M CTM006 www.airborn.com (512) 863-5585 "M" Series Connectors M-6
MM-313-069-161-41WC 价格&库存
很抱歉,暂时无法提供与“MM-313-069-161-41WC”相匹配的价格&库存,您可以联系我们找货
