NK-2C2-015-125-TH00
NK-2C2-015-125-TH00
    AIRBORN
    15 位 D 型,Nano-D 插座,母型插口 连接器
NK-2C2-015-125-TH00 数据手册
NK .025" Metal PC Board Mounted Connector 2 2-Row C BODY STYLE: Plug, horizontal mount SMT BODY MATERIAL: Liquid Crystal Polymer w/ electroless nickel shell Liquid Crystal Polymer w/ electrodeposited cadmium shell 2 3 XXX Number of contacts (009, 015, 021, 025, 031, 037, 051, 065, 069, or 085) 12 TYPE CONTACTS/TERMINATIONS: Pin, SMT 5 8 PLATING OPTIONS: 50 u" Au contacts, Sn/Pb alloy terminations 50 u" Au contacts, tin plated terminations JC STYLE OF HARDWARE: Turning jackscrews, captivated #0-80 UNF* 00 WIRING OPTIONS: None * = #2-56 UNC thread on 85 position connectors .050 hex key (#0-80 thread) 1/16" hex key (#2-56 thread) Recommended torque value 1.0 inch-lbs. max. (#0-80 thread) Recommended torque value 2.0 inch-lbs. max. (#2-56 thread) Ball end hex wrench not recommended Hex wrench key/bit conforming to the requirements of ASME / ANSI-B-18.3 is recommended. .050" hex L-key long arm wrench - order AirBorn p/n CDG14148. 1/16" hex L-key long arm wrench - order AirBorn p/n CDG14160. = Option not RoHS compliant Ask About AirBorn's Accelerated Delivery Service
NK-2C2-015-125-TH00 价格&库存
很抱歉,暂时无法提供与“NK-2C2-015-125-TH00”相匹配的价格&库存,您可以联系我们找货
