AP-CCWWWG-Q-S222222-RP345-BL
    AIRGAIN
    ANTENNA PLUS ULTRAMAX MIMO ANTEN
AP-CCWWWG-Q-S222222-RP345-BL 数据手册
FLEET SOLUTIONS High Performance External Antenna ULTRAMAX MIMO 6-in-1 is a full outdoor antenna equipped with six ports, designed specifically to provide high performance connectivity for Fleet and Public Safety vehicles and assets connecting to almost any vehicular router or modem. This antenna is configurable and offers up to two high gain cellular/LTE/MIMO antennas, which include support for LTE Band 14 for FirstNet, three high gain Wi-Fi antennas, and a GNSS antenna inside a single robust and compact housing. Optimal MIMO Compact and Robust Performance for LTE UV Resistant Housing • 2 x Wideband Cellular/LTE Elements (MIMO) • 3 x 2.4 & 4.9-6GHz Wi-Fi Elements (MIMO) • 1 x GNSS Element • Six embedded antenna technologies that operate over multiple bands in one housing • Leading LTE performance while in coexistence with multiple other embedded antenna technologies • Lower profile and smaller footprint than competing solutions • High gain provides bigger cellular footprint • Must be mounted on metal • Available in black or white • US Patent 10109918 Descriptions/Applications Full Outdoor Installation Ready Customizable Cables and Connectors to Connect to Any Modem Flexible Mounting Options GNSS Low loss cable accessories Fast custom turnaround time The ULTRAMAX MIMO antenna builds on the best in class RF performance, leading design features, and extended operational life of our highly successful Fleet and Public Safety Antenna products. Like all our antennas, this product has been designed to be robust to withstand the natural hazards a vehicle faces including vibration, hot, cold, ice, salt, dirt, car washes, and tree branch sweeps. Our antennas typically outlast the life of a vehicle. Standard Configurations Bolt Mount Adhesive Mount Magnetic Mount AP-CCWWWG-M-S222222-RP345-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 3 & GNSS, Magnetic Mount, SMA on Cell/LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax AP-CCWWWG-A-S222222-RP345-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 3, & GNSS, Adhesive Mount, SMA on Cell/LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax AP-CCWWWG-Q-S222222-RP345-BL-15 MIMO Cell/LTE x 2, Wi-Fi x 3, & GNSS, Threaded Bolt Mount, SMA on Cell/LTE & GNSS, RP-SMA on Wi-Fi, Black, 15ft coax Also available in color white, customizable cable lengths up to 35 feet, and other connector variations. ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN ULTRAMAXTM MIMO 6-in-1 Electrical Data Frequency Range Elements 1 & 2 698-960/1700-2700 MHz Elements 3, 4, & 5 2.4/4.9-6.0 GHz Elements 1 & 2 LTE/Cellular Element 6 Operational Bands Elements 3, 4, & 5 Element 6 Elements 1 & 2 Peak Gain: Isotropic Elements 3, 4, & 5 Element 6 Elements 1 & 2 Isolation Elements 3, 4, & 5 Correlation Co-efficient Elements 1 & 2 1550~1610 MHz Wi-Fi GPS L1/GALILEO E1/GLONASS G1/BeiDou B1/QZSS L1 698-960 MHz 4.9 dBi 2.4 GHz, 5.5 GHz 7 dBi, 5 dBi 1710-2700 MHz 2.50 dBi > 10 dB 7 dBi 28 dB > 30 dB < 0.1 Environmental Data Hazardous Substances RoHS Compliant Temperature -40ºC to 65ºC (-40ºF to + 149ºF) Operating and Storage conformance to IEC 60068 Humidity (Non-Condensing) 5% to 96% Operating and Storage conformance to IEC 60068 Military Spec MIL-STD 810 conformance to vibration Mounting Data Height 2.220” (56.4mm) Dimensions Width 3.831” (97.3mm) Length 7.000” (178.3mm) Color Black (BL) or White (WH) Cable Data- Cell/LTE Type CFD195 Low Loss Diameter 0.195” (4.953 mm) Length 1 feet (0.3 m) Termination SMA Male Cable Data- Wi-Fi Type CFD195 Low Loss Diameter 0.195” (4.953 mm) Length 1 feet (0.3 m) Termination RP-SMA Male GNSS Data - Ceramic Patch Antenna Specification Bandwidth 1561 – 1602 MHz Gain@Zenith 2.5 dBi Polarization R.H.C.P. Axial Ratio 3.0 dB Typ. Cable Data- GNSS Type RG-174U Diameter 0.100” (2.54 mm) Length 1 feet (0.3 m) Termination SMA Male GNSS Data - LNA Specification Noise Figure 1.2 dB Gain 28 dBi Voltage 3.3V~5.6V Current 9.6±1mA@3.3V ap-sales@airgain.com | www.airgain.com | + 1-855-AIRGAIN
AP-CCWWWG-Q-S222222-RP345-BL 价格&库存
很抱歉,暂时无法提供与“AP-CCWWWG-Q-S222222-RP345-BL”相匹配的价格&库存,您可以联系我们找货
