LZI-19-600-A-00-20-S
    ALLIANCESENSORS(联盟传感器)
    Cylinder
    SENSOR LINEAR 609.6MM CABLE
LZI-19-600-A-00-20-S 数据手册
For use in: Packaging Equipment Automation Systems Assembly Machinery Hydraulic Cylinders LZ-19 Series LVIT Linear Position Sensor Through-bore LVIT Linear Position Sensor for applications needing superior stroke-to-body-length The LZ-19 Series of LVIT (Linear Variable Inductance Transducer) position sensors are contactless devices designed for use in factory automation or assembly machinery applications where space is a premium, as well as for external mounting on hydraulic cylinders to sense rod position. The LVIT is offered in nominal full scale ranges from 2.5 to 750 mm (0.100 to 30 inches) with an excellent stroketo-length ratio. The sensor has a 19.0 mm (3/4 inch) outside diameter aluminum or optional stainless steel body with a 1m axial cable for I/O connections. The 7.5 mm (0.295 inch) diameter through-bore of an LZ-19 provides clearance for its 6.00 mm (0.236 inch) diameter moving rod, which is made of the same material as its housing. This through-bore feature also means that the sensor is not subject to damage from typical mechanical overstroking. Technical datasheets and additional information can be found at www.alliancesensors.com Features: • Contactless operation prevents internal wearout from dithering or rapid cycling • LVIT Technology™ (Linear Variable Inductance Transducer) • Through-bore design eliminates mechanical over stroking • Full Scale ranges from 2.5 to 750 mm (0.100 to 30 inches) • Proprietary SenSet™ field adjustable range scaling • DC in / DC out operation with built-in electronics • Excellent stroke-to-body-length ratio Specifications: Analog I/Os Measuring Ranges Linearity Error Resolution Update Rate Terminations 0 – 5 V or 0.5 – 4.5 V DC output; 8 – 30 V input, 35 mA max, 0 – 10 V DC output; 12 – 30 V input, 35 mA max 4 – 20 mA (3-wire) output; 18 – 30 V input, 60 mA max. (75 C max) 12.5 to 900 mm (1/2 to 36 inches) full scale ≤±0.15% of Full Scale Output (FSO) typical, ±0.25% max 0.025% of FS 300 Hz nominal IEC IP-67 All specifications are subject to change without notice. © Alliance Sensors Group, 2018 Rev. 07272018 LZ-19 Series Specifications Con’t: Operating Temperature Temperature Coefficient Humidity Shock Vibration LZ-19 Range Table Nominal Range Length “A” Inches Inches (mm) mm 0.10 2.5 1.38 (35.0) 0.20 5.0 1.38 (35.0) 0.30 7.5 1.38 (35.0) 0.40 10 1.38 (35.0) 0.50 12.5 1.38 (35.0) 0.60 15 1.38 (35.0) 0.80 20 1.38 (35.0) 1.00 25 1.38 (35.0) 1.20 30 1.63 (41.3) 2.00 50 2.38 (60.5) 3.00 75 3.38 (85.9) 4.00 100 4.38 (111.1) 6.00 150 6.50 (165.1) 8.00 200 8.50 (215.9) 10.00 250 10.50 (266.7) 12.00 300 12.50 (317.5) 15.00 375 15.75 (400.0) 18.00 450 18.75 (476.2) 24.00 600 25.00 (635.0) 30.00 750 31.00 (787.4) -20 to 85 C (-40 to 105 C Extended Range) ≤±0.015% of FS/C 95% RH, non-condensing 1000 gs, 11 msec. 5-20 Hz 0.5 inch p-p; 20-2000 Hz 4.2 g p-p ASSEMBLY LZ-19 Connection Table I/O Function Color +Power Input Red Ground Black Analog output Green SenSet ™ White Shield/ drain* Shield CORE *Shield unconnected internally Ordering Information: Housing Diameter Electrical Termination Range (mm) Series Output LZ X- XX- XXX- X- XX- E- Voltage 19 - 19 mm 2.5 - 15mm A - Axial 00 - 1 m cable 05 - 0.5 to 4.5 V I - Current (2.5mm increments) Axial Termination Housing/Rod Material Output XX- 06 - 4.5 to 0.5 V X- A - Aluminium S - 300 Series SS 10 - 0 to 10.0 V 15 – 30mm 11 - 10.0 to 0 V (5mm increments) 20 - 4 to 20 mA 21 - 20 to 4 mA 050 - 300 50 - 0 to 5 V (50mm increments) 51 - 5 to 0 V 300 - 450 (75mm increments) 450 - 750 (150mm increments) All specifications are subject to change without notice. © Alliance Sensors Group, 2018 Rev. 07272018
LZI-19-600-A-00-20-S 价格&库存
很抱歉,暂时无法提供与“LZI-19-600-A-00-20-S”相匹配的价格&库存,您可以联系我们找货
