11494
    ALLIEDVISION
    Module
    CAMERA MONO CSMNT OPEN AR0135CS
11494 数据手册
Alvium 1500 C-120 • • • • AR0135CS CMOS sensor ALVIUM image processing MIPI CSI-2 interface Various hardware options Embedded vision CSI-2 camera with AR0135CS sensor Alvium CSI-2 cameras enable new designs for embedded applications with improved image quality and reduced workload for the host. The innovative ALVIUM System on Chip (SoC) performs image corrections and preprocessing tasks onboard the camera instead of the embedded board. Unlike FPGAs commonly used in machine vision cameras, the ALVIUM SoC is extremely power efficient. With Alvium, integrating hardware and software can be done effortlessly, which ultimately reduces development time. The ON Semi AR0135CS CMOS sensor enables high-quality imaging at 1.2 megapixel. Color models ship with an IR cut filter, monochrome and S-Mount models ship without a filter or protection glass. Benefits and features • • • • • • • • • Monochrome (1500 C-120m) and color (1500 C-120c) models ALVIUM® Technology for on-board image processing MIPI CSI-2 interface with up to 4 lanes Platform concept that enables the operation of different Alvium camera models with a common software Hirose HR FHH55 FPC connector with minimum space requirements for a compact design Precise sensor-to-lens mount alignment Standard M3 mounting holes for top and bottom mounting, standard M2 mounting holes for front mounting Industrial performance for embedded vision applications Easy-to-install driver and code examples Hardware options • Housing: Alvium 1500 C cameras are available as bare board or open housing cameras. • Various lens mounts: Select between S-Mount, CS-Mount, or C-Mount. For more information on hardware options, including product codes and technical data, such as  technical drawings and mass, see the Alvium Cameras Hardware Options document. Available accessories • • • • Tripod adapter Adapter boards for Nitrogen6_MAX and Wandboard i.MX6 FPC cables in 120 mm, 220 mm, and 420 mm length Various lenses and Allied Vision S-Mount lenses with focal lengths 2.97 - 12 mm Specifications Alvium Interface Resolution Spectral range Sensor Sensor type Shutter mode Sensor size Pixel size Lens mounts (available) Max. frame rate at full resolution ADC Image buffer (RAM) Non-volatile memory (Flash) 1500 C-120 MIPI CSI-2, up to 4 lanes 1280 (H) × 960 (V) 300 to 1100 nm ON Semi AR0135CS CMOS Global shutter Type 1/3 3.75 µm × 3.75 µm CS-Mount, C-Mount, S-Mount 50 fps using 1 to 4 lanes, RAW8 12 Bit 256 KB 1024 KB Output Bit depth Max. 12 Bit YUV color pixel formats YUV422_10 RGB color pixel formats RGB888, BGR888 Raw pixel formats RAW8 (monochrome or color) Operating conditions/dimensions Operating temperature +5 °C to +65 °C housing temperature (with heat sink) Power requirements (DC) 5 VDC over MIPI CSI-2 Power consumption Typical: 1.1 W Mass 10 g (bare board) Body dimensions (L × W × H in mm) 7 × 26 × 26 (bare board) Regulations 2011/65/EU, including amendment 2015/863/EU (RoHS) Quantum efficiency Features Image control Auto control • Auto exposure • Auto gain • Auto white balance  Other image controls • • • • • • • • • Black level De-Bayering up to 5×5 (color models) Exposure time Gain Gamma Hue Region of interest (ROI) Reverse X/Y Saturation Camera control • Temperature monitoring (sensor board) Technical drawing Camera hardware options The Alvium Cameras Hardware Options document informs about submodels, such as bare board or open housing cameras with different lens mounts. 26.3 25 1.5 19.6* 26.4 Mounting area A 1.3 0.05 (gap) *Mechanical length for C-Mount, for other mounts and details, see the user guide. 0.05 Mounting area 1.15 Sensor area Do not mount here 1.15 1.5 26.4 26.3 25 26.3 25 26.4 A (10 : 1) Applications Powered by the ALVIUM® Technology, a unique System-on-chip designed by Allied Vision, the Alvium 1500 and Alvium 1800 Series deliver industrial performance to embedded vision with many benefits for system engineers.
11494 价格&库存
很抱歉,暂时无法提供与“11494”相匹配的价格&库存,您可以联系我们找货
