From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
NOTES:
R E V I S I O N
DESCRIPTION
UNLESS OTHERWISE SPECIFIED
REV. DRAWN BY
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11002.
A
M BOYER
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
B
4. ALL INSIDE RADII .010R.
ECO No
DATE
APPROVED
PRELIMINARY RELEASE
17-Sep-11
D.C.
M BOYER
ADD THICKER COMPONENTS
09-May-12
D.C.
C
M BOYER
ADD SECOND PRESS POST
15-May-12
D.C.
D
M BOYER
REDUCE WIDTH AND THICKNESS
16-May-12
D.C.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE
UNLESS OTHERWISED SPECIFIED.
E
M BOYER
ADD VIEWS AND NOTES
06-Feb-13
D.C.
1.0
R CRUZ
UPDATE TO AS BUILT & RELEASED
25-Jun-13
D.C.
7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT
CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
2.0
R CRUZ
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE
DR XXX
02118
REMOVE -S OPTION, UPDATE FORMAT
2018-Jul-23
8. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF OEM.
10. THE GATE REMNANT FOR THIS ENCLOSURE IS LOCATED IN THIS POSITION
TO MINIMIZE THE COSMETIC IMPACT. IT IS HOWEVER VISIBLE AND VARIES
IN SIZE / SHAPE. IT IS EASILY REMOVED WITH CLIPPERS. IF YOU
WOULD LIKE NEW AGE TO CLIP THIS FOR YOU, PLEASE ASK YOUR SALES
REPRESENTIVE FOR A FREE QUOTE.
4
11. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
12. ALLOWABLE FLASH: 0.010 MAX.
13. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
2
14. TRIM GATE WITHIN 0.015" OF FLUSH.
NOTE 10
090604TU
SCALE 1.000
090604BU
SCALE 1.000
CONFIGURATION LEGEND
5
NOTE 10
-Tx
-Fx
-Cx
-Bx
BOTH
BOTH
ONLY
ONLY
COVER AND BASE ARE TALL
COVER AND BASE ARE SHORT (FLAT)
THE COVER IS TALL (BASE IS FLAT)
THE BASE IS TALL (COVER IS FLAT)
-xU
ENCLOSURE WITH MOLDED TYPE A USB OPENING
1
090604CU
SCALE 1.000
090604(xx) CONFIGURATIONS
-TU
090604 COVER w/ TYPE A USB
090606 TALL COVER w/ TYPE A USB
1
090604 BASE w/ TYPE A USB
090606 TALL BASE w/ TYPE A USB
1
-FU
1
1
-CU
1
1
-BU
1
3
SCALE 2.000
1
090604FU
SCALE 1.000
5
090604 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
4
090606U COVER - STANDARD
ABS
BLACK or WHITE
1
3
090606U BASE - STANDARD
ABS
BLACK or WHITE
1
2
090604U COVER - STANDARD
ABS
BLACK or WHITE
1
1
090604U BASE - STANDARD
ABS
BLACK or WHITE
1
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2018
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
EXPAND. USB - STANDARD
PXX-090604XX-XXX
SIZE
17-Sep-11
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
090604_R2_0
SHEET
1 OF 7
REV.DOC
2.0
090604FU ASSEMBLY
.315
.007
SEE DETAIL A
Y
(.516)
J
J
P
P
.060
.940
.127
.062
.006
SCALE 1.500
SECTION J-J
SECTION Y-Y
Y
2.0°
R.080
.630
.026 CLEARANCE
FOR USB WELD
2.0°
DETAIL A
SCALE 3.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
SECTION P-P
SCALE 3.000
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-090604XX-XXX
SIZE
17-Sep-11
fax (805) 595-1024
A
DRAWING NAME
090604_R2_0
SHEET
2 OF 7
REV.DOC
2.0
090604TU ASSEMBLY
.295
.298
Y
P
P
.060 WALL
.269 CLEAR
.940
.062 PCB
.149 CLEAR
.060 WALL
SCALE 1.500
SECTION Y-Y
Y
.600
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
SCALE
SECTION P-P
SCALE 3.000
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-090604XX-XXX
SIZE
17-Sep-11
fax (805) 595-1024
A
DRAWING NAME
090604_R2_0
SHEET
3 OF 7
REV.DOC
2.0
090604 COVER
TYPE A
USB OPENING
.480
.037
.126
.193*
.160
.035 +1°
DRAFT/SIDE
.000
.630
.160
R.015
Y
.470
.060
X
P
X
P
.055
.000
.940
.470
SECTION Y-Y
SCALE 2.000
Y
+.001
.062
-.001
.060
.080
+.001
-.010
.000
+.005
-.001
+.001
.037
-.001
.008
+.005
-.001
.133*
.068
SECTION X-X
.193*
.025
2.0°
.010
.135 +5°
DRAFT/SIDE
SECTION P-P
SCALE 4.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
* = ADD .135" TO DIMENSION FOR 090606 (FAT) COVER.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-090604XX-XXX
SIZE
17-Sep-11
fax (805) 595-1024
A
DRAWING NAME
090604_R2_0
SHEET
4 OF 7
REV.DOC
2.0
090604 BASE
TYPE A
USB OPENING
.480
.086
.153*
.059
.127*
.020 RELIEF
.160
.630
.000
R.015
.160
FEATURE NON-EXISTENT
ON 090606 (FAT) BASE
Y
.470
.200
.030
.055
.000
.940
.125
.470
SECTION Y-Y
R.080
Y
.630
SCALE 2.000
+.0010
-.0010
NO DRAFT
.0610
.064
+.002
-.002
.030
+.001
-.001
.000
+.002
.056
-.002
.063*
.090*
BREAK EDGE R.010
.123*
SECTION K-K
SCALE 4.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
SCALE
* = ADD .135" TO DIMENSION FOR 090606 (FAT) BASE.
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-090604XX-XXX
SIZE
17-Sep-11
fax (805) 595-1024
A
DRAWING NAME
090604_R2_0
SHEET
5 OF 7
REV.DOC
2.0
090604 PCB
CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
REFERNCE ONLY
USB PLUG CONNECTOR
ACON ADVANCED CONNECTEK INC.
PN. C-GAR71-OO-OO
(.986)
.390
.036
.055
.000
+.003
-.003
.250
.160
.000
.250
.390
.160
.130
THE ENCLOSURE CAN ACCOMODATE
VARIOUS PCB THICKNESSES
BY REPLACING MOLD INSERTS
AT MINIMAL COST.
PLEASE CONTACT YOUR
SALES REPRESENTITIVE FOR
MORE INFORMATION.
.780
.062
.500
SCALE 2.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-090604XX-XXX
SIZE
17-Sep-11
fax (805) 595-1024
A
DRAWING NAME
090604_R2_0
SHEET
6 OF 7
REV.DOC
2.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
090604 COVER
SCALE 2.000
090604 BASE
SCALE 2.000
PXX-090604XX-XXX
COVER
STEP NO
DESCRIPTION
CUTTER
1
T2 = .062" EM
STEP NO
DESCRIPTION
2
PAD PRINT
PXX-090604XX-XXX
INK COLOR
FIXTURE
ABS, BLACK
X.XXX = .010
X.X° = 1°
ORIENTATION
PROGRAM
COVER
ABS, BLACK
CLICHE DESCRIPTION
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
090604
DATE
CHECK
ENG.
CLICHE No. DRAWN BY
AS NOTED
M BOYER
17-Sep-11
SCALE
CL1010
ph. (805) 595-1310
fax (805) 595-1024
PXX-090604XX-XXX
SIZE
A
DRAWING NAME
090604_R2_0
SHEET
7 OF 7
REV.DOC
2.0
很抱歉,暂时无法提供与“P3A-090604TU”相匹配的价格&库存,您可以联系我们找货
