NOTES:
UNLESS OTHERWISE SPECIFIED
REV. DRAWN BY
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
R E V I S I O N
DESCRIPTION
DATE
APPROVED
PRELIMINARY RELEASE
28-Jan-09
D.C.
0710
UPDATE FORMAT
20-Mar-10
D.C.
M BOYER
0911
ADD CONFIG TREE AND UPDATE FORMAT
30-Mar-11
D.C.
M BOYER
6713
REVISE HOOK AREA
30-Sep-13
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11010.
1
M BOYER
1.1
M BOYER
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
1.2
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
2.0
ECO No
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY
AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL
FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END
OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS
PERMISSIBLE UNLESS OTHERWISED SPECIFIED.
7. THIS ENCLOSURE IS A SNAP FIT ASSEMBLY. FOR
PERMANENT CLOSURE: A DROP OF ADHESIVE IS REQUIRED.
2
8. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN
BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE
AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES
AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM.
3
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. TRIM GATE WITHIN 0.030" OF FLUSH.
12. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE.
1
EXPLODED VIEW
SCALE 2.500
SCALE 2.500
USB OPENING
120704(x) CONFIGURATIONS
120704
120704
120704
120704
COVER
COVER w/ USB OPENING
BASE
BASE w/ USB OPENING
-S
1
1
-U
1
120704_PCB
120704 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
120704_COVER
120704X COVER - STANDARD
ABS
BLACK or WHITE
1
1
120704_BASE
120704X BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
FILE
NAME
BILL OF MATERIALS
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
1
3
ITEM
THIRD ANGLE PROJECTION
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2013
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
120704
DRAWING NAME
A 120704X_R2_0
SHEET
1 OF 6
REV.DOC
2.0
.357
.242
.000
.242
.357
.201
.091
.000
.091
.201
OPTIONAL USB OPENING
IN STANDARD LOCATION
X
SCALE 3.000
R.020
.525
.181
R20.139
.045
1.229
.069 CLEAR
.062 REF. PCB
.171 CLEAR
.055
.010
X
R1.006
SCALE 2.000
SECTION X-X
P120704U SHOWN WITH (CUSTOMER SUPPLIED) PCB
.715
X.XXX = .010
X.X° = 1°
.020
.403
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
fax (805) 595-1024
120704
DRAWING NAME
A 120704X_R2_0
SHEET
2 OF 6
REV.DOC
2.0
P120704X COVER
.036
.483 USB
.081
.050
SCALE 2.000
.060
.206
.000
R.025
.206
R.020
.536
G
.614
.433
.000
.045
.010
.496
TEXTURE: MT-11010
EXTERIOR
RECESS
.010"
.020
.172
CLIP GATE BELOW
INTERIOR INTERLOCK
SHELF
.433
.614
SEE DETAIL A
G
SECTION G-G
SCALE 2.000
.282
.050
.191
.312
3.0°
DRAFT TYP.
.031
.050
DETAIL A
SCALE 4.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
fax (805) 595-1024
120704
DRAWING NAME
A 120704X_R2_0
SHEET
3 OF 6
REV.DOC
2.0
P120704X BASE
.532
.081
.036
(.093)
.484 USB
.040
R.020
.073
.453
.463
.034
.065
H
.012
TEXTURE: MT-11010
EXTERIOR
SCALE 2.000
X
X
.906
.488
H
SECTION H-H
.030
SCALE 2.000
CLIP GATE BELOW
INTERIOR INTERLOCK
SHELF
.047
.403
22.3°
.191
.045
.030
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
SECTION X-X
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
fax (805) 595-1024
120704
DRAWING NAME
A 120704X_R2_0
SHEET
4 OF 6
REV.DOC
2.0
P120704X PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.475
.178
.596
.114
USB PLUG CONNECTOR
ACON ADVANCED CONNECTEK INC.
PN. C-UAR70-OO-OO
www.acon.com
PCB
.062" THICK
.108
.080 MAX
.062 THICK
1.025
.040 4x
.200
.125
.000
.125
.200
.030 4x
.020 x 45°
NOT REQUIRED (COSMETIC)
SCALE 2.000
.520
KEEP OUT ZONES
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
fax (805) 595-1024
120704
DRAWING NAME
A 120704X_R2_0
SHEET
5 OF 6
REV.DOC
2.0
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
P120704X COVER
SCALE 2.000
P120704X BASE
SCALE 2.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
STEP NO
1
2
PXX-120704X-XXX COVER
DESCRIPTION
CUTTER
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
FIXTURE
242
242
ORIENTATION
Customer's Part No:
APPROVAL
PROGRAM
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - USB KEY
PXX-120704X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
28-Jan-09
fax (805) 595-1024
120704
DRAWING NAME
A 120704X_R2_0
SHEET
6 OF 6
REV.DOC
2.0
很抱歉,暂时无法提供与“P1A-120704U”相匹配的价格&库存,您可以联系我们找货
