P3A-220705S
P3A-220705S
    NEWAGE
    UTILITY DONGLE
P3A-220705S 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE MT-11007. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. R E V I S I O N DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 2010-Apr-21 D.C. M BOYER REDESIGN TO SQUARE UTILITY SHAPE 2010-Apr-27 D.C. M BOYER MORE SQUARE 2010-Apr-29 D.C. A M BOYER B C ECO No DR XXX D M BOYER ROUNDED EDGES TO CHAMFERS WITH DECORATIVE LIP 2011-Jan-15 D.C. E M BOYER CHANGES PER MEETING 17-Jan-11 2011-Jan-18 D.C. F M BOYER CHANGE PCB POSTS TO 2011-Jan-20 D.C. .047 FROM .062 G M BOYER ADD USB COVER NOTE 2011-Jan-26 D.C. H M BOYER CHANGLE PART NO FROM 220805 TO 220705 2011-Jun-07 D.C. D.C. I M BOYER UPDATE TITLE BLOCK 2011-Jun-22 1.0 M BOYER RELEASED TO MFG BY CUSTOMER 2011-Jun-22 D.C. 2.0 M BOYER REVISE TEXTURE 2013-Apr-05 J.T. J.T. 1813 3.0 M BOYER 00815 REVISE TEXTURE 2015-Feb-13 4.0 M BOYER 04916 UPDATE TO AS BUILT AND REVOVE CAP REFERENCE 2016-Nov-09 2 3 1 SCALE 1.250 MOLDED USB OPENING (OPTIONAL) 220705(x) CONFIGURATIONS 220705 220705 220705 220705 COVER COVER w/ TYPE "A" USB OPENING BASE BASE w/ TYPE "A" USB OPENING -S 1 1 EXPLODED VIEW: 220705-U SCALE 1.250 -U 1 1 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DO NOT SCALE DRAWING 3 220705_PCB 220705 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 220705_COVER 220705X COVER - STANDARD ABS BLACK or WHITE 1 1 220705_BASE 220705X BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2016 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 1 OF 6 REV.DOC 4.0 .512 [13,02] 2.255 [57,28] X X .752 [19,1] THE FRONT OF THE PCB IS SUPPORTED BY CAPTURING THE USB CONNECTOR. WHEN ORDERING A 220705-S ENCLOSURE WITHOUT A PROTRUDING CONNECTOR THE DESIGNER SHOULD DISCUSS MOLDING ALTERNATE FRONT PCB POSTS FOR SUPPORT. SEE 3-D CAD MODEL AND ASK YOUR SALES REP FOR A QUOTE. THIS ENCLOSURE CAN ACCOMODATE VARIOUS PCB THICKNESSES BY ADJUSTING THE MOLDED LENGTH OF TWO REAR POSTS. THE STANDARD PCB THICKNESS IS 0.062" ASK YOUR SALES REP FOR QUOTE. SCALE 1.500 .206 [5,23] SECTION X-X .062 [1,57] .101 [2,57] .080 [2,03] 4.0° (.529 ) [13,44] A SECTION A-A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES A Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 2 OF 6 REV.DOC 4.0 220705 COVER 2.255 [57,28] (.67 ) [16,9] .752 [19,1] MOLDED TYPE A USB OPENING (OPTIONAL) SCALE 1.500 .025 [0,63] .015 [0,38] Y .047 [1,19] R.015 [0,38] .254 [6,45] Y .080 [2,03] .010 ADJUSTABLE POSTS [0,25] FOR PCB CAPTURE (ASK FOR QUOTE) .080 TYP. WALL THICKNESS [2,03] .032 [0,81] .145 [3,68] SECTION Y-Y .067 ±.002 ADJUSTABLE POSTS [1,7] FOR PCB CAPTURE (ASK FOR QUOTE) NO DRAFT 1.128 [28,64] .984 2x [24,99] .750 2x [19,05] .000 [0] .750 2x [19,05] .984 2x [24,99] SECTION G-G 1.128 [28,64] .487 [12,37] .035 [0,89] 4.0° TYP. .376 [9,55] .230 2x [5,84] .230 [5,84] .047 [1,19] .000 [0] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .230 [5,84] G .062 [1,57] G .047 [1,19] .230 2x [5,84] .376 [9,55] X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 3 OF 6 REV.DOC 4.0 220705 BASE 2.255 [57,28] .050 [1,27] X X J .752 [19,1] J SCALE 1.500 .047 [1,19] .080 [2,03] MOLDED TYPE A USB OPENING (OPTIONAL) .310 [7,87] .010 ADJUSTABLE POSTS [0,25] FOR PCB CAPTURE (ASK FOR QUOTE) .135 [3,43] R.015 SECTION X-X D .055±.002 [±0,051,4] .129 ±.002 PCB STANDOFF [3,28] 4.0° [0,38] .055 [1,4] SECTION D-D .015 [0,38] 1.128 [28,64] .984 2x [24,99] .000 [0] .750 2x [19,05] SECTION J-J .750 2x [19,05] .984 2x [24,99] 1.128 [28,64] D .487 [12,37] NO DRAFT .025 [0,63] .255 [6,48] .055 [1,4] .125 [3,18] .062 ±.001 [1,57] .376 [9,55] .230 4x [5,84] .000 [0] .230 4x [5,84] .062 [1,57] .125 [3,18] .376 [9,55] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK .047 [1,19] ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 4 OF 6 REV.DOC 4.0 220705 PCB 1.025 [26,04] .775 [19,69] .000 [0] 1.025 [26,04] SUGGESTED TYPE A USB PLUG CONNECTOR ACON, ADVANCED CONNECTEK INC. PN. C-UAR70-00-00 www.acon.com/en-global/product/detail/378 .725 [18,42] CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .290 [7,37] .230 [5,84] (.165 ) [4,19] (.477 ) [12,12] .000 [0] (.165 ) [4,19] (.178 ) [4,52] .005 [0,13] .230 [5,84] R.065 4PL. [1,65] .290 [7,37] .111 [2,82] .000 [0] (.875 ) [22,23] .913 [23,18] (1.615 ) [41,02] SCALE 1.500 .062 [1,57] .050 [1,27] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 5 OF 6 REV.DOC 4.0 2nd OPERATION DETAILS MOLDED USB OPENING NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY© WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" MOLDED USB OPENING 220705 BASE SCALE 1.000 220705 COVER SCALE 1.000 PXX-220705X-XXX COVER - ABS, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C2 2-C-C2 - T2 = .062" EM T2 = .062" EM 229 229 COVER AND BASE COVER AND BASE o1000 o1001 PXX-220705X-XXX BASE - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 3-B-C1 4-B-C2 - T2 = .062" EM T2 = .062" EM 229 229 COVER AND BASE COVER AND BASE o1000 o1001 BY 4330 Santa Fe Road ph. (805) 595-1310 USB DONGLE - STANDARD PXX-220705X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Apr-21 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 220705 DRAWING NAME A 220705_R4_0 SHEET 6 OF 6 REV.DOC 4.0
P3A-220705S 价格&库存
很抱歉,暂时无法提供与“P3A-220705S”相匹配的价格&库存,您可以联系我们找货
