P1A-260906S
P1A-260906S
    NEWAGE
    MINI REMOTE
P1A-260906S 数据手册
R E V I S I O N P260906(x) CONFIGURATIONS -S -U P260906 COVER 1 P260906 COVER w/ USB 1 P260906 BASE 1 P260906 BASE w/ USB 1 4 M2 SCREW x 4mm - REFERENCE CUSTOMER SUPPLIED CUSTOMER SUPPLIED 4 3 260906 COVER - STANDARD ABS BLACK or WHITE 1 2 260906 BASE - STANDARD ABS BLACK or WHITE 1 1 260906 PCB - REFERENCE CUSTOMER SUPPLIED .062" THICK 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS REV. DRAWN BY 1 M BOYER 2 M BOYER 3 ECO No DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 08-Apr-08 D.C. 3408 REMOVE SHOWN USB CUTOUT 22-Oct-08 D.C. M BOYER 0109 PUT USB CUTOUT BACK AS A MOLDING OPTION 15-Jan-09 D.C. 4 M BOYER 0210 SHOW ONE PCB 27-Jan-10 D.C. 4.1 M BOYER 0710 UPDATE FORMAT 20-Mar-10 D.C. 4.2 M BOYER 3310 UPDATE BOM 31-Aug-10 D.C. 4.3 M BOYER 0411 UPDATE LABEL RECESS TO AS-BUILT 10-Feb-11 D.C. 4.4 M BOYER 1211 INCLUDE PCB SCREW INFORMATION 11-Apr-11 D.C. 4.5 M BOYER 1911 UPDATE PCB HOLE RECOMMENDATIONS 26-May-11 D.C. 4.6 M BOYER 2711 CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT" 21-Oct-11 D.C. 5.0 M BOYER 1113 UPDATE TO AS BUILT 18-Mar-13 D.C. 5.1 R CRUZ 3013 UPDATE TEXTURE CALLOUT 04-Jun-13 D.C. 5.2 R CRUZ 1614 REMOVE PCB SCREW PART NUMBER 02-Apr-14 3 1 4 MOLDED CUTOUT (OPTIONAL) FOR TYPE A USB ON STANDARD PCB ATTACHED TO COVER 2 NOTES: SCALE 1.500 EXPLODED VIEW SCALE 1.000 UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11020. 3. INTERIOR SURFACE TEXTURE: NONE 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. SCALE 1.500 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 8. MOUNTING SCREWS FOR THE PCB ARE CUSTOMER SUPPLIED. 9. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 10. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 11. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE FOR QUOTE. THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DO NOT SCALE DRAWING NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2014 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 1 OF 6 REV.DOC 5.2 2.578 P A U (.006) U A .898 .181 .476 P SCALE 1.500 SECTION U-U SCALE 3.000 .562 SECTION X-X (.123) OPTIONAL CUTOUT SEE BILL OF MATERIALS PCB MOUNTED TO 260906 COVER, BUT ALTERNATE PCB MOUNTING POSTS ARE AVAILABLE IN THE BASE. ALTERNATE POST HEIGHT MAY BE REQUIRED TO ALIGN STANDARD USB OPENING. VARIOUS POST HEIGHTS ARE AVAILABLE UPON REQUEST FOR QUOTE. PRESS FIT CLOSURE SEE NOTES SECTION A-A (.063) (.275) SECTION P-P SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 2 OF 6 REV.DOC 5.2 260906 COVER .115 (.100) OPTIONAL MOLD CUTOUT .062 "PRESS FIT" .020 1.289 1.073 1.148 .000 .094 .786 .708 1.289 SECTION Y-Y .132 X .449 SECTION D-D SCALE 3.000 .308 .037 .268 .476 .000 Y Y .268 .308 .449 X SCALE 1.500 .055 WALL TYP. LABEL RECESS AREA AVAILABLE FOR CUSTOM TOOLING .100 PCB POSTS .270 1.289 1.190 1.000 .000 1.000 1.190 1.289 SECTION X-X .449 .350 .300 .000 .125 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .300 .350 .449 .040 .062 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL D DATE ENG. SCALE "PRESS FIT" BY CHECK D .125 AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 3 OF 6 REV.DOC 5.2 1.125 .000 .093 .734 1.165 260906 BASE .292 .262 LABEL RECESS - .005 STANDARD 2 PLACES CUSTOM INSERTS ARE AVAILABLE F .000 F .262 .292 R.068 R.084 .055 WALL THICKNESS TYP. .048 .122 5.0° .155 OPTIONAL MOLD CUTOUT SECTION F-F 1.289 1.190 1.000 .000 1.000 1.190 .107 1.289 .115 .449 .350 .300 .000 .475 .300 .350 .449 R.015 SCALE 1.500 "PRESS FIT" .125 .062 .040 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .312 NEW AGE ENCLOSURES Customer's Part No: APPROVAL .030 R1.000 .410 BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 4 OF 6 REV.DOC 5.2 P260906 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.210 1.000 .000 1.000 1.210 (2.420) .368 .300 .000 (.735) .300 .368 SCALE 1.500 .092 .130 x 45° 4 PLACES .063 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 5 OF 6 REV.DOC 5.2 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" MOLDED TYPE A USB OPENING MOLDED TYPE A USB OPENING P260906 COVER SCALE 1.000 STEP NO 1 2 STEP NO 4 5 P260906 BASE SCALE 1.000 PXX-260906X-XXX COVER DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM PXX-260906X-XXX BASE DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE 106 106 - ORIENTATION - ABS, BLACK FIXTURE 106 106 ORIENTATION - PROGRAM - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL PROGRAM - BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MINI REMOTE PXX-260906X ASSEMBLY SIZE 08-Apr-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 260906 DRAWING NAME A 260906_R5_2 SHEET 6 OF 6 REV.DOC 5.2
P1A-260906S 价格&库存
很抱歉,暂时无法提供与“P1A-260906S”相匹配的价格&库存,您可以联系我们找货
