P1A-401108
P1A-401108
    NEWAGE
    ELECTRONIC DONGLE
P1A-401108 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. DATE APPROVED 14-May-08 D.C. 1507 ADJUST RECOMMENDED PCB SIZE 25-Sep-07 D.C. M BOYER 0208 UPDATE FORMAT AND RELEASE 14-May-08 D.C. M BOYER 2 M BOYER 3 DESCRIPTION R E V I S I O N PRELIMINARY RELEASE 1 ECO No 4 M BOYER 2709 MODIFY RIBS ON COVER 20-May-09 D.C. 4.1 M BOYER 0710 UPDATE FORMAT 26-Mar-10 D.C. 4.2 M BOYER 2711 CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT" 21-Oct-11 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH O.E.M. 9. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 3 1 2 EXPLODED VIEW SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. THIRD ANGLE PROJECTION X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° 3 401108 COVER - STANDARD ABS BLACK or WHITE 1 2 401108 BASE - STANDARD ABS BLACK or WHITE 1 1 401108 PCB - REFERENCE REFERENCE ONLY .062" THICK 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 = 1° NEW AGE ENCLOSURES DO NOT SCALE DRAWING Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 1 OF 6 REV.DOC 4.2 .895 1.095 S R19.181 3.880 2.775 SCALE 1.000 S .465 .095 SECTION S-S .595 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° .490 = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 2 OF 6 REV.DOC 4.2 401108 COVER Y .710 SECTION Y-Y .060 Y "PRESS FIT" 3.880 .035 X X .080 2.100 1.580 1.223 .000 1.273 1.580 .640 1.750 .540 SECTION X-X SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 3 OF 6 REV.DOC 4.2 401108 BASE .025 Z .031 SECTION Z-Z Z .215 3.850 "PRESS FIT" .770 Y .095 1.750 1.580 1.160 .000 1.250 .350 .640 1.580 .600 2.100 1.095 Y .030 SECTION Y-Y .080 SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 4 OF 6 REV.DOC 4.2 P401108 PCB - CUSTOMER SUPPLIED 1.835 1.700 1.400 1.500 .000 .990 1.040 1.835 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 401108 PROPOSED PCB SIZE TOP OF BOARD .370 .520 .765 KEEP OUT ZONE 4x .125 1.835 1.700 1.640 .000 1.290 1.390 .060 .220 .120 1.040 .940 1.835 .125 401108 PROPOSED PCB SIZE BOTTOM OF BOARD .303 .323 .100 .050 .100 .050 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. KEEP OUT ZONE 8x X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: SCALE 1.500 APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 5 OF 6 REV.DOC 4.2 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 401108 BASE SCALE 1.000 401108 COVER SCALE 1.000 PXX-401108-XXX COVER STEP NO 1 2 DESCRIPTION - STEP NO 3 4 DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM PXX-401108-XXX BASE CUTTER T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE 133 133 - ORIENTATION - PROGRAM oXXXX oXXXX ABS, BLACK FIXTURE 141 141 ORIENTATION - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° Customer's Part No: APPROVAL PROGRAM oXXXX oXXXX = 1° NEW AGE ENCLOSURES BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ELEC. DONGLE PXX-401108 ASSEMBLY SIZE 14-May-08 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 401108 DRAWING NAME A 401108_R4_2 SHEET 6 OF 6 REV.DOC 4.2
P1A-401108 价格&库存
很抱歉,暂时无法提供与“P1A-401108”相匹配的价格&库存,您可以联系我们找货
