S3L-452715-BW
S3L-452715-BW
    NEWAGE
    INDUSTRIAL UTILITY BW
S3L-452715-BW 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifiying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED REV. DRAWN BY A M BOYER PRELIMINARY RELEASE J M BOYER REMOVE SHOWN USB CUTOUT 27-Jan-12 D.C. 1.0 M BOYER UPDATE TO AS-BUILT AND RELEASED TO MFG 23-May-12 D.C. 1.1 M BOYER 2612 REVISE STANDARD B.O.M. & INSERT SHEET 3 26-Jul-12 D.C. 2.0 R CRUZ 8513 UPDATE CONFIGURATION TABLE TO INCLUDE O-RINGS WITH ENCLOSURE 30-Dec-13 D.C. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 2.1 R CRUZ 0414 UPDATE CONFIG TABLE - REMOVE BATTERY O-RING FROM -Sx CONFIGS 24-Jan-14 D.C. 2.2 M BOYER 1314 REVISE INSERT SIZE ON BOM 29-May-14 D.C. 3.0 M BOYER 1514 INCREASE ORING THICKNESS 02-Jul-14 D.C. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 3.1 R CRUZ 02115 UPDATE NOTE 8 20-May-15 D.C. 4.0 R CRUZ 03115 CHANGED O-RING COLOR FROM NATURAL TO BLUE 07-Jul-15 D.C. 7. ASSEMBLY SCREWS FOR THE ENCLOSURE ARE INCLUDED. FOR THE PCB AND WALL ARE SOLD SEPERATELY. 4.1 M BOYER 02516 INCLUDE NOTE 10 2016-May-04 D.C. 5.0 M BOYER 01718 CHANGE ORING TO BE OFF-THE-SHELF OR EQUIV. 2018-Jun-19 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020. CENTER PART TO BE POLISHED. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. MOUNTING SCREWS ECO No DESCRIPTION DATE APPROVED 2010-Sep-17 D.C. 8. MATERIAL / COLOR: ENCLOSURE IN ASA PLASTIC IS STANDARD IN BLACK OR GREY. SLIGHT COSMETIC SWIRLING, BLUSHING, AND/OR DISCOLORATION CAN OCCUR IN THIS ENCLOSURE DUE TO UV INHIBITORS IN THE RESIN. O-RING IN TPE IS STANDARD IN BLUE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 3 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF OEM. 6 10. THIS ENCLOSURE IS CONSTRUCTED FOR INDOOR OR OUTDOOR USE TO PROVIDE A DEGREE OF PROTECTION TO THE EQUIPMENT INSIDE AGAINST THE INGRESS OF SOLID FORIEGN OBJECTS (FALLING DIRT); AND TO PROVIDE A DEGREE OF PROTECTION WITH RESPECT TO TO HARMFUL EFFECTS ON THE EQUIPMENT DUE TO THE INGRESS OF WATER (DRIPPING OR SPLASHING). 452715(x) CONFIGURATIONS -SW 452715 BATTERY COVER 452715 COVER (w/o BATTERY) 1 452715 BASE 452715 WALL BASE 1 452715 HATCH 6-32 PHILLIPS HEAD SCREW x .500" 4 8-32 PHILLIPS HEAD SCREW x .500" 6-32 x .281" OVERMOLD BRASS INSERT 4 6-32 x .625" OVERMOLD BRASS INSERT MAIN SEAL O-RING BATTERY COMPARTMENT O-RING 1 12 THIS ENCLOSURE CAN ACCOMODATE A 9 VOLT BATTERY AND CONNECTOR, DUAL "AA" CARRIAGE, DUAL "AAA", OR ANY BATTERY OF EQUIVALANT SIZE. -BS -SS -BW 1 1 1 1 1 1 1 1 4 4 4 2 2 4 4 4 1 1 1 7 13 4 5 8 9 11 1 1 10 14 No6 SHEET METAL SCREW x 1.00" 410 STAINLESS CUSTOMER SUPPLIED 4 13 12 BATTERY CARRIAGE AA - REFERENCE KEYST # 2463 CUSTOMER SUPPLIED 1 AA BATTERY - REFERENCE "AA" BATTERY SIZE CUSTOMER SUPPLIED 2 11 #4 HiLo x .250" SCREW ZINK PLATED SOLD SEPERATELY 4 10 452715 WALL BASE - STANDARD ASA BLACK or GRAY 1 1 9 452715 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 8 452715 O-RING, MAIN SEAL OR-156 or EQUIV. INCLUDED 1 7 452715 O-RING, BATT COMP OTS INCLUDED 1 6 452715 HATCH - STANDARD ASA BLACK or GRAY 1 5 452715 BATTERY COVER - STANDARD ASA BLACK or GRAY 1 4 8-32 x .344" CLOSED-END INSERT TRISTAR 832X344MC OVER-MOLDED BRASS 2 3 8-32 SCREW x .500 STAINLESS STEEL - PHILLIPS .375" LONG 2 2 6-32 x .625" INSERT TRISTAR 632X625C OVER-MOLDED BRASS 4 1 6-32 SCREW x .500 STAINLESS STEEL - PHILLIPS .500" LONG 4 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS - Wall Base & Battery Cover (See Sheet 3 for Standard Cover and Standard Base) 14 MODEL: 452715-BW EXPLODED VIEW SCALE 0.500 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES 1 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 1 OF 12 REV.DOC 5.0 4.583 1.100 SLOT R 452715-BW ASSEMBLY 1.456 1.374 COVER w/ BATTERY - WALL BASE Y Y 3.590 .715 2.773 R SEE DETAIL C DETAIL ASSEMBLY VIEW: 452715-BW SCALE 0.500 .090 C: 452715-BW SCALE 1.500 R.230 1.450 2.576 2.494 SECTION X-X SEE DETAIL B .200 .077 SECTION R-R CENTER TO BE POLISHED SEE DETAIL A .020 SECTION Y-Y 2.000 .145 .083 DETAIL B SCALE 2.000 .088 ISO VIEW: 452715-BW SCALE 0.600 .090 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. 3.100 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. DETAIL A SCALE 4.000 SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 2 OF 12 REV.DOC 5.0 452715-SS ASSEMBLY STANDARD COVER - STANDARD BASE .570 1.450 452715 STANDARD COVER 4.539 MAIN SEAL O-RING (INCLUDED) 2.729 452715 STANDARD BASE SCALE 0.500 SCALE 0.600 452715(x) CONFIGURATIONS -SW 452715 BATTERY COVER 452715 COVER (w/o BATTERY) 1 452715 BASE 452715 WALL BASE 1 452715 HATCH 6-32 PHILLIPS HEAD SCREW x .500" 4 8-32 PHILLIPS HEAD SCREW x .500" 6-32 x .281" OVERMOLD BRASS INSERT 4 6-32 x .625" OVERMOLD BRASS INSERT MAIN SEAL O-RING BATTERY COMPARTMENT O-RING 1 .281 -BS -SS -BW 1 1 1 1 1 1 1 1 4 4 4 2 2 4 4 4 1 1 1 SECTION R-R 1 1 7 #4 HiLo x .250" SCREW ZINK PLATED SOLD SEPERATELY 4 6 452715 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 5 452715 O-RING, MAIN SEAL OR-156 or EQUIV. INCLUDED 1 4 452715 COVER - STANDARD ASA BLACK or GRAY 1 3 452715 BASE - STANDARD ASA BLACK or GRAY 1 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: 2 6-32 x .281" INSERT 832X281C OVER-MOLDED BRASS 4 APPROVAL 1 6-32 SCREW x .500 STAINLESS STEEL - PHILLIPS .500" LONG 4 CHECK ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS - Standard Base & Stamdard Cover (See Sheet 1 for Battery Cover and Wall Base) BY 452715 DATE 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 3 OF 12 REV.DOC 5.0 452715-SS ASSEMBLY .682 .110 COVER - BASE 4.539 R 2.729 3.019 SECTION ASSEMBLY VIEW: 452715-SS SCALE 0.500 R R-R: 452715-SS SCALE 1.000 .095 .501 1.450 CENTER SECTION TO BE POLISHED SECTION Y-Y 2.800 ISO VIEW: 452715-SS SCALE 0.600 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. 1.775 2.500 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 4 OF 12 REV.DOC 5.0 .110 P 1.250 2x -BW .830 2x -BS Y .000 452715 BATTERY COVER FOR USE IN CONFIG: 2.729 .830 2x 1.250 2x 3.019 SEE DETAIL G .230 P .220 1.400 2x 1.000 2x .937 .245 .070 4.539 .000 .805 1.000 2x 1.400 2x SCALE 0.750 3.0° Y SECTION SEE DETAIL H R.015 .099 -2° DRAFT/SIDE 1.033 .815 .100 .130 3.0° R.230 Y-Y .095 -2° DRAFT/SIDE DETAIL H SCALE 3.000 R.025 OVER-MOLDED PEM 8-32 x .344" CLOSED-END BRASS INSERTS (NOT SHOWN) QUANTITY 2 .068 SECTION P-P OVER-MOLDED PEM 6-32 x .625" BRASS INSERTS (NOT SHOWN) QUANTITY 4 DETAIL G SCALE 3.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 5 OF 12 REV.DOC 5.0 452715 COVER FOR USE IN CONFIG: -SW 2.500 -SS 1.660 .860 .180 .110 4.539 2.000 2.800 A A SCALE OVER-MOLDED PEM 6-32 x .281" BRASS INSERTS (NOT SHOWN) QUANTITY 4 0.750 SECTION R.230 Y-Y 3.0° .219 .084 .640 .170 SECTION A-A .160 2.729 .068 SEE DETAIL D R.025 3.019 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. +.001 -.002 .130 DETAIL D SCALE 3.000 .099 -2° DRAFT/SIDE X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 6 OF 12 REV.DOC 5.0 452715 WALL BASE 3.590 FOR USE IN CONFIG: 2.643 -SW -BW (.337 INSIDE CLEARANCE) 3.100 (.262 INSIDE CLEARANCE) Y 1.525 1.025 S 1.100 .155 4.583 1.100 .077 2.000 S .080 SCALE 0.750 SECTION Y .145 +2° DRAFT 8 PLACES .020 +.002 -.002 .070 .020 .467 .397 .200 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. SEE DETAIL E DETAIL E SCALE 1.500 SECTION Y-Y X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL S-S BY 452715 DATE CHECK OPENING FOR STRAP 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 7 OF 12 REV.DOC 5.0 452715 BASE FOR USE IN CONFIG: 3.019 -SS -BS 2.729 1.775 .150 .095 4.539 P P R.259 .075 SCALE 0.750 +.002 -.002 SECTION Y-Y .180 .070 (.640) .570 .020 INSIDE RIBS .070 .020 SEE DETAIL F TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION P-P R.200 3.0° DETAIL F SCALE 2.000 Customer's Part No: .108 APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 8 OF 12 REV.DOC 5.0 452715 HATCH FOR USE IN CONFIG: -BS -BW 1.772 -5° DRAFT/SIDE .150 Y 1.665 .210 .015 .006 R.015 .372 X X 3.562 -5° DRAFT/SIDE 2.785 .352 ( .170) 3.155 ( .330) R.190 SCALE 0.750 .330 +5° DRAFT/SIDE 2 PLACES R.139 Y R.207 SECTION Y-Y .170 +2° DRAFT/SIDE 2 PLACES .120 .090 .372 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .282 NEW AGE ENCLOSURES SEE DETAIL I Customer's Part No: DETAIL I SCALE 3.000 SECTION X-X APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 9 OF 12 REV.DOC 5.0 452715 BATTERY O-RING 452715 MAIN O-RING .808 .808 1.091 2x 1.265 .000 1.265 1.091 2x .000 FOR USE IN CONFIG: FOR USE IN ALL CONFIGURATIONS -BS -BW R.155 4x 2.170 1.368 1.400 X X .000 X X .000 1.368 R.159 4x R.125 8x SCALE 0.750 R.044 .0880 1.400 .103 2.170 SCALE 0.750 OD SCALE 0.250 R.125 4x ID .0900 .090 2.7726 2.5966 SECTION X-X SCALE 5.000 R.044 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: .090 OD OR-156 or EQUIV. SCALE 0.250 ID APPROVAL 4.5769 4.3969 BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SECTION X-X SCALE 5.000 SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 10 OF 12 REV.DOC 5.0 452715 PCB - Customer Supplied PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 2.050 1.400 2x 1.000 2x .937 .000 1.000 2x 1.400 2x 2.050 (4.100) R.250 4x 1.250 2x 1.150 .830 2x .250 KEEP OUT ZONE 4 PLACES .063 (2.300) .000 .830 2x 1.150 1.250 2x .125 4 PLACES SCALE 1.000 CONNECTOR OPENING REFERENCE .245 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 11 OF 12 REV.DOC 5.0 452715 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 SXL-452715-XXX COVER - ASA, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 266 266 266 - o1000 o1000 o1000 SXL-452715-XXX COVER STEP TYPE FIXTURE INK COLOR 4-P-P1 PAD PRINT 267 - - ASA, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 452715 DATE CHECK 2240 South Thornburg Street ph. (805) 595-1310 INDUSTRIAL UTILITY - STANDARD SXL-452715X-XXX ENG. CLICHE DESCRIPTION CLICHE No. - CLxxxx R1 SCALE AS NOTED DRAWN BY M BOYER SIZE 2010-Sep-17 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 452715_R5_0 SHEET 12 OF 12 REV.DOC 5.0
S3L-452715-BW 价格&库存
很抱歉,暂时无法提供与“S3L-452715-BW”相匹配的价格&库存,您可以联系我们找货
