S1A-201209
S1A-201209
    NEWAGE
    2 INCH DONGLE
S1A-201209 数据手册
R E V I S I O N REV. DRAWN BY ECO No DATE APPROVED A M BOYER PRELIMINARY RELEASE 15-Feb-13 D.C. B M BOYER CHANGE TITLE 21-Feb-13 D.C. C M BOYER REVISE TEXTURE AND DRAFT ON ENDS 03-Apr-13 D.C. D M BOYER ADD INSPECTION DIMENSIONS 10-Jul-13 D.C. 1.0 R CRUZ UPDATE TO AS BUILT AND RELEASE TO MFG 10-Sep-13 D.C. 2.0 R CRUZ UPDATE TO AS BUILT, SEE DIR 0505 13-Aug-15 03815 DESCRIPTION 2 SCALE 1.500 3 NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-1055-2, EXCEPT WHERE NOTED 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 1 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 4 SCALE 1.500 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 NO2_HI-LO S-HiLo #2 x 3/8" ZINK INCLUDED 4 3 201209_PCB 201209 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 201209_COVER 201209 COVER - STANDARD ABS BLACK or WHITE 1 1 201209_BASE 201209 BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2015 Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 1 OF 6 REV.DOC 2.0 201209 ASSEMBLY 2.000 .062 PCB 1.250 DETAIL A SCALE 2.000 #2 Hi Lo SCREW x 3/8" LONG SCALE 1.000 R1.500 .633 CLEAR P .710 .950 .020 GAP P .220 SECTION P-P SEE DETAIL A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 2 OF 6 REV.DOC 2.0 201209 COVER 2.000 P Y X X 1.250 SCALE 1.000 Y P .075 1.5° DRAFT BOTH ENDS 50% TEXTURE DEPTH R1.500 24.1° 3.0° DRAFT SIDES SECTION X-X .780 1.925±.002 -5° DRAFT/SIDE SECTION Y-Y .070 .078 (.710) 1.177±.002 -5° DRAFT/SIDE .054 SECTION P-P 1.300 SEE DETAIL B .038 .030 +1° DRAFT/SIDE TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .820 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .078 DETAIL B SCALE 2.000 .187 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 3 OF 6 REV.DOC 2.0 201209 BASE 2.000 .080 Y P .201 -5° DRAFT/SIDE X X .010±.002 1.250 (.025 x 45° CHAMFER TYP.) .076 .050 60.0° P SCALE 1.000 Y SECTION X-X .250 (R.020) .156 DETAIL C SCALE 3.000 .075 .050±.002 .050±.002 .109 -1° DRAFT/SIDE 3.0° DRAFT TYP. 1.925±.002 +5° DRAFT/SIDE .075 .220 SECTION P-P SEE DETAIL C 1.175±.002 +5° DRAFT/SIDE 1.300 SECTION Y-Y .820 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 4 OF 6 REV.DOC 2.0 201209 PCB .906 .650 2x .000 .650 2x .906 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .030 CHAMFER TYP. .532 .410 2x .000 .260 KEEP OUT ZONES 4 PLACES .410 2x .532 SCALE 1.000 .160 4x .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 5 OF 6 REV.DOC 2.0 201209 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° STEP NO SXX-201209-XXX DESCRIPTION CUTTER COVER T2 = .062" EM T2 = .062" EM T2 = .062" EM - FIXTURE ABS, BLACK ORIENTATION NEW AGE ENCLOSURES Customer's Part No: PROGRAM APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - 2in DONGLE SXX-201209-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 15-Feb-13 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 201209 A DRAWING NAME 201209_R2_0 SHEET 6 OF 6 REV.DOC 2.0
S1A-201209 价格&库存
很抱歉,暂时无法提供与“S1A-201209”相匹配的价格&库存,您可以联系我们找货
