S1A-202010
S1A-202010
    NEWAGE
    NETWORK CUBE
S1A-202010 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. REV. DRAWN BY DATE APPROVED A M BOYER PRELIMINARY RELEASE 28-Jun-12 D.C. B M BOYER ADD SUBGATE 07-Dec-12 D.C. C M BOYER UPDATE TO AS BUILT 03-Apr-13 D.C. 1.0 M BOYER RELEASED 03-May-13 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11006. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. ECO No DESCRIPTION 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. SCALE 1.500 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 202010_PCB 202010 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 202010_COVER 202010 COVER - STANDARD ABS BLACK or WHITE 1 2 202010_BASE 202010 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2012 Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 1 OF 6 REV.DOC 1.0 202010 ASSEMBLY 1.995 [50,67] A .605 [15,37] 1.995 [50,67] R.301 [7,63] SCALE 1.000 .173 [4,39] .062 [1,57] DETAIL A SCALE 2.000 A 3.0° DRAFT TYP. 1.000 [25,4] .666 [16,92] .316 [8,03] 1.400 [35,56] 1.400 [35,56] SECTION A-A R.175 [4,45] SEE DETAIL A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 2 OF 6 REV.DOC 1.0 202010 COVER 1.995 [50,67] .015 [0,38] C .050 [1,27] .080 [2,03] 1.995 [50,67] .044 [1,12] .058 [1,47] DETAIL B SCALE 2.000 5.0° R.186 [4,71] SCALE 1.000 .041 [1,03] C 1.765 SQ. [44,84] SEE DETAIL B .666 [16,92] SECTION C-C .058 [1,47] 1.400 [35,56] 1.400 [35,56] .187 OD [4,75] .072 ID [1,83] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 3 OF 6 REV.DOC 1.0 202010 BASE 1.995 [50,67] .131 +5° DRAFT/SIDE [3,32] B .312 -2° DRAFT/SIDE [7,92] .040 [1] 1.995 [50,67] .173 [4,39] 5.0° .040 [1,02] .023 [0,58] DETAIL C SCALE 2.000 .230 +5° DRAFT/SIDE [5,84] SCALE 1.000 R.301 [7,63] B .316 [8,03] 3.0° SECTION B-B 1.400 [35,56] .080 [2,03] R.175 [4,45] SEE DETAIL C 1.400 [35,56] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 4 OF 6 REV.DOC 1.0 202010 PCB .898 [22,81] .700 [17,78] .000 [0] .700 [17,78] .898 [22,81] CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .898 [22,81] .700 [17,78] (1.400 ) S.Q. [35,56] .000 [0] (1.796 ) S.Q. [45,62] .700 [17,78] .898 [22,81] R.201 [5,11] SCALE 1.000 .125 4x [3,18] .325 KEEP OUT ZONE 4x [8,26] .062 [1,57] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 5 OF 6 REV.DOC 1.0 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 SCALE 1.000 Sxx-202010-xxx COVER STEP NO DESCRIPTION CUTTER 1 2 - T2 = .062" EM T2 = .062" EM STEP NO DESCRIPTION 3 PAD PRINT Sxx-202010-xxx INK COLOR - FIXTURE ABS, BLACK ORIENTATION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. PROGRAM 240 240 COVER - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL ABS, BLACK CLICHE DESCRIPTION BY DATE CHECK ENG. CLICHE No. CLXXXX R1 SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - NETWORK CUBE SXX-202010 ASSEMBLY SIZE 28-Jun-12 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 202010 DRAWING NAME A 202010_CUBE_R1_0 SHEET 6 OF 6 REV.DOC 1.0
S1A-202010 价格&库存
很抱歉,暂时无法提供与“S1A-202010”相匹配的价格&库存,您可以联系我们找货
