S1A-272008
S1A-272008
    NEWAGE
    SMALL UTILITY
S1A-272008 数据手册
4330 Santa Fe Road San Luis Obispo, CA 93401 T 805.595.1310 F 805.595.1024 www.NewAgeEnclosures.com Fast and Affordable Customization. Ordering a market-ready enclosure© is made fast and affordable with our complete in-house capabilities. New Age provides machined openings to fit your PCB, pad printing for your company graphics, complete custom enclosures, custom colors, cable assemblies, wire harnesses, final assembly, testing and fulfillment services to save you additional time and money. Ask your representative for a free quote today 805-595-1310. Sample CNC modifications, pad printing, colored resins, cable assembly, custom enclosure, and assembled remote control with key pad are shown below. CNC Machining Pad Printing Custom Colors Cables & Wire Harnesses Custom Enclosures Assembly & Testing “Market-Ready Enclosures© For Today’s Electronics.” R E V I S I O N NOTES: REV. DRAWN BY ECO No 1 M BOYER 2 M BOYER 0208 2.1 M BOYER 0710 DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 09-Nov-04 D.C. UPDATE FORMAT AND RELEASE 10-Apr-08 D.C. UPDATE FORMAT 20-Mar-10 UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF O.E.M. EXPLODED VIEW SCALE 1.500 9. ASSEMBLY HARDWARE PROVIDED. 10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. THIRD ANGLE PROJECTION X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° #4 HiLo x 3/8" HiLo SCREW ZINC PLATED 4 3 272008 COVER - STANDARD ABS BLACK or WHITE 1 2 272008 BASE - STANDARD ABS BLACK or WHITE 1 1 272008 PCB - REFERENCE CUSTOMER SUPPLIED .062" THICK 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 = 1° NEW AGE ENCLOSURES DO NOT SCALE DRAWING 4 Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SMALL UTILITY SXX-272008 ASSEMBLY SIZE 09-Nov-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 272008 DRAWING NAME A 272008_R2_1 SHEET 1 OF 5 REV.DOC 2.1 2.000 .062 PCB B 1.300 .090 WALL R.109 2.750 B SCALE 1.000 1.750 (.570 ) (R 3.108 ) AREA AVAILABLE FOR CUSTOM TOOLING 1.40 X 1.96 COVER R.250 SECTION B-B AREA AVAILABLE FOR CUSTOM TOOLING 1.300 X 1.750 BASE R7.333 .468 .800 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL .315 (.018 ) BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SMALL UTILITY SXX-272008 ASSEMBLY SIZE 09-Nov-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 272008 DRAWING NAME A 272008_R2_1 SHEET 2 OF 5 REV.DOC 2.1 1.000 .650 R.3750 .000 C .650 1.000 272008 COVER .264 1.375 .975 .063 .000 .090 R19.884 .975 1.375 SECTION C-C SCALE 1.000 .2485 R3.108 C TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .468 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SMALL UTILITY SXX-272008 ASSEMBLY SIZE 09-Nov-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 272008 DRAWING NAME A 272008_R2_1 SHEET 3 OF 5 REV.DOC 2.1 272008 BASE 1.300 .242 F .090 A .080 .030 R.250 .315 .208 .188 .311 (2.750 ) 1.950 1.750 27.4° 5.0° A SECTION F-F SECTION A-A .395 F .311 1.300 1.750 SCALE 1.300 1.000 R.375 S272008 PCB - CUSTOMER SUPPLIED .062 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. RECOMMENDED PCB DIMENSIONS 2.450 1.950 KEEP AWAY .325 FROM POSTS 4X .203 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SMALL UTILITY SXX-272008 ASSEMBLY SIZE 09-Nov-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 272008 DRAWING NAME A 272008_R2_1 SHEET 4 OF 5 REV.DOC 2.1 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° SXX-272008-XXX COVER STEP NO 1 2 3 DESCRIPTION - CUTTER T2 = .062" EM T2 = .062" EM T2 = .062" EM - ABS, BLACK FIXTURE - ORIENTATION - = 1° NEW AGE ENCLOSURES Customer's Part No: PROGRAM - APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SMALL UTILITY SXX-272008 ASSEMBLY SIZE 09-Nov-04 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 272008 DRAWING NAME A 272008_R2_1 SHEET 5 OF 5 REV.DOC 2.1
S1A-272008 价格&库存
很抱歉,暂时无法提供与“S1A-272008”相匹配的价格&库存,您可以联系我们找货
推荐型号
