S3A-281109-K
S3A-281109-K
    NEWAGE
    COMPACT AAA - KIT
S3A-281109-K 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. REV. DRAWN BY ECO No DESCRIPTION DATE APPROVED A-G M BOYER PRELIMINARY THROUGH CONCEPT - SEE REV G 14-Jun-2012 D.C. 1.0 M BOYER RELEASED TO MFG PER CUSTOMER 27-Nov-2012 D.C. 1.1 R CRUZ 4614 UPDATE TEXTURE CALLOUT 21-Oct-2014 D.C. 2.0 M BOYER 4914 INCLUDE WALL CRADLE 01-Dec-2014 D.C. 2.1 M BOYER INCLUDE CRADLE TEXTURE CALLOUT 03-Apr-2015 D.C. 2.2 R CRUZ 02615 UPDATE WALL CRADLE NOTCH TOLERANCE ON BASE 22-May-2015 D.C. 2.3 M BOYER 04815 REVISE ASSY SCREW LENGTH 2015-Nov-05 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 5 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 2 9. ASSEMBLY SCREWS FOR THE ENCLOSURE ARE PROVIDED. MOUNTING SCREWS FOR PCB AND BATTERY CONTACTS SOLD SEPERATELY. 4 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 1 10 11 281109(x) CONFIGURATIONS -Blank 281109 COVER 1 281109 BASE 1 281109 BASE MODIFIED (2nd OP) 281109 WALL CRADLE 281109 HATCH 1 #2 HiLo SCREW .312" 4 9 -K 1 -W SCALE 0.900 1 1 1 4 6 1 7 11 AAA-SINGL-CONTACT-POS ACC-AAAPOS-5226 SPRING STEEL SOLD SEPERATELY 10 AAA-SINGL-CONTACT-NEG ACC-AAANEG-5204 SPRING STEEL SOLD SEPERATELY 1 1 9 AAA-DBL-CONTACT ACC-AAADBL-5214L SPRING STEEL SOLD SEPERATELY 1 8 SCREW-DRYWALLX750 DRYWALL SCREW - REFERENCE CUSTOMER SUPPLIED DRYWALL SCREW 2 7 281109_WALL-CRADLE 281109 WALL CRADLE - STANDARD ABS BLACK or WHITE 1 6 281109_HATCH 281109 HATCH - STANDARD ABS BLACK or WHITE 1 5 281109_COVER 281109 COVER - STANDARD ABS BLACK or WHITE 1 4 281109_BASE-MODIFIED 281109 BASE - MODIFIED ABS BLACK or WHITE 1 3 SCREW_HILO-NO2X312 #2 HiLo x .312" SCREW ZINK PLATED 5/16" LONG 4 2 281109_PCB REFERENCE ONLY CUSTOMER SUPPLIED .062" THICK 1 1 AAA-BATTERY REFERENCE ONLY CUSTOMER SUPPLIED "AAA" SIZE 2 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS 8 EXPLODED VIEW SCALE 0.950 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2015 Customer's Part No: APPROVAL BY DATE ENG. QUALITY SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 1 OF 8 REV.DOC 2.3 3.0° DRAFT TYP. .040 .940 .198 R.150 SECTION C-C DETAIL A SCALE 3.000 1.095 SEE DETAIL A .020 B C 2.809 C SCALE 1.000 SECTION B-B B .075 x 45° CHAMFER DOUBLE BATTERY CONTACT (BRIDGE) SHOULD BE INSTALLED ON THIS END OF THE ENCLOSURE. R.150 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 2 OF 8 REV.DOC 2.3 281109 COVER SEE DETAIL D .025 .025 .163 SECTION F-F DETAIL D SCALE 4.000 .222 1.095 .600 R 3.0° .035 F F (.197) .075 .075 2.809 .075 CHAMFER D1 .071 CHAMFER D2 2.350 SECTION R-R .062 R .188 R.150 SCALE 1.000 .460 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 3 OF 8 REV.DOC 2.3 281109 BASE .250 +3° .662 .045 .460 .100 3.0° 3.0° 1.095 .157 R.150 .600 .875 R.050 .093 THRU SEE DETAIL B .015 .028 1.940 .150 -3° .960 INSIDE LABEL AREA 2.350 2.809 E E SCALE 1.000 .250 SEE DETAIL C .175 .057 6.0° .495 DETAIL B SCALE 3.000 .020 .250 SECTION E-E R.207 .028 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .982-3° DRAFT/SIDE X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL .095 DETAIL C SCALE 3.000 BY DATE CHECK ENG. .252 SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 4 OF 8 REV.DOC 2.3 281109 HATCH 2.390 X X 1.073 .150 +5° DRAFT/SIDE SCALE 1.000 R.200 R.150 .176 .105 .057 .450 .250 .018 3.0° 30.0° .148 .075 .094 R.050 .974 -3° R3.000 .500 .050 .018 .070 .050 SECTION X-X SCALE 2.000 .105 .038 5.0° .168 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 5 OF 8 REV.DOC 2.3 281109 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.310 1.175 2x .955 x2 .375 .000 .040 .375 .955 x2 1.175 2x 1.310 (2.620) FOUR BATTERY CONTACT LOCATIONS SHOWN TO ACCOMODATE POLARITY VARIATIONS. R.125 .450 .300 2x .225 2x (.900) .150 4x .000 .225 2x .300 2x .450 SCALE 2.000 .040 4x .081 .156 4x .015 .040 R.125 .063 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL NOTE 1. BATTERY CONNECTION POINTS SHOWN AT BOTH ENDS TO ALLOW ALTERNATE ASSEMBLY OPTION. BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 6 OF 8 REV.DOC 2.3 281109 WALL CRADLE & 281109 BATTERY BASE 2nd OPERATION DETAILS - PAGE 1 of 2 3.0° 281109(x) CONFIGURATIONS -Blank 281109 COVER 1 281109 BASE 1 281109 BASE MODIFIED (2nd OP) 281109 WALL CRADLE 281109 HATCH 1 #2 HiLo SCREW .312" 4 NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 3.0° .575 A -K 1 1 1 1 4 -W 1 .370 .085 .100 100.0° C MT-11010 TEXTURE C 2.948 2.000 1.050 2.806 -2° DRAFT/SIDE .125 .187 .065 .370 .350 A .250 -10° DRAFT/SIDE .600 .056 CHAMFER D1 2.0° .015 CHAMFER D2 SECTION A-A 281109 WALL CRADLE SCALE 1.000 281109 BASE MODIFIED SCALE 1.000 .60 .888 45.0° .32 R.04 (.070) .60 SECTION C-C 2.2 .065 .368±.005 R.100 .368±.005 2.2 .125 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. NOTCHES MUST BE ADDED TO SECURE BASE TO WALL CRADLE 4 PLACES 1.100 SXX-281109-XXX BASE - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: ABS, BLACK APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-B-C1 2-B-C2 2 WALL SLOTS ON END 2 WALL SLOTS ON END T2 = .062" EM T2 = .062" EM 297 297 DUAL DUAL o4901 o4901 BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 7 OF 8 REV.DOC 2.3 2nd OPERATION DETAILS - PAGE 2 of 2 281109(x) CONFIGURATIONS -Blank 281109 COVER 1 281109 BASE 1 281109 BASE MODIFIED (2nd OP) 281109 WALL CRADLE 281109 HATCH 1 #2 HiLo SCREW .312" 4 NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" -K 1 1 1 1 4 -W 1 281109 COVER SCALE 1.000 STEP NO 1-C-C1 2-C-C2 STEP NO 3-C-P1 SXX-281109-XXX DESCRIPTION DESCRIPTION PAD PRINT COVER CUTTER T2 = .062" EM T2 = .062" EM SXX-281109-XXX INK COLOR ABS, BLACK FIXTURE 290 290 COVER FIXTURE 291 - - ORIENTATION - ABS, BLACK CLICHE DESCRIPTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. PROGRAM - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. CLICHE No. -- SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - COMPACT AAA SXX-281109X-XXX SIZE 2012-Jun-15 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 281109 DRAWING NAME A 281109_R2_3 SHEET 8 OF 8 REV.DOC 2.3
S3A-281109-K 价格&库存
很抱歉,暂时无法提供与“S3A-281109-K”相匹配的价格&库存,您可以联系我们找货
