S3A-301810
S3A-301810
    NEWAGE
    MULTI-PORT BAR
S3A-301810 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED V I S I O N DATE APPROVE A R. CRUZ PRELIMINARY RELEASE 2016-Jul-07 D.C. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. B R. CRUZ UPDATE NOTE 2, CASE SIZE, PRODUCT NAME, RECESS 2016-Jul-14 D.C. C M. BOYER UPDATE DIMENSIONS 2016-Sep-08 D.C. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. D R. CRUZ UPDATE NOTE 2, ENCLOSURE NAME, PCB SHAPE 2016-Oct-06 D.C. E R. CRUZ ADD RIBS ON BASE, REVISE PCB SHAPE AND ADD NOTE 2016-Nov-30 D.C. 1.0 M. BOYER RELEASED TO MFG PER CUSTOMER 2017-Feb-15 D.C. 2.0 R. CRUZ UPDATE TO AS-BUILT 2019-Nov-13 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 03019 DESCRIPTION E DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. ECO No R REV. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.015 MAX. 3 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.015" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. 4 2 1 301810 EXPLODED VIEW SCALE 1.000 SCALE 0.750 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 301810_PCB_062 301810 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 301810_COVER 301810 COVER - STANDARD ABS BLACK or WHITE 1 2 301810_BASE 301810 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINC PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2019 Customer's Part No: APPROVAL BY 301810 DATE CHECK ENG. SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 1 OF 6 REV.DOC 2.0 301810 ASSEMBLY 3.000 [76,2] A .595 CLEAR [15,11] 1.750 [44,45] .020 [0,51] .062 PCB REF [1,57] SCALE 1.000 .173 CLEAR [4,39] A 1.000 [25,4] DETAIL A SCALE 2.000 (.665 ) [16,89] (.315) [8] SECTION A-A SEE DETAIL A 1.668 [42,36] .949 [24,1] 1.085 [27,55] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 301810 DATE CHECK ENG. 2.199 [55,85] SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 2 OF 6 REV.DOC 2.0 1.500 [38,1] 1.385 [35,18] .000 [0] 1.385 [35,18] 1.500 [38,1] C 301810 COVER .015 [0,38] .060 [1,52] .875 [22,22] .760 [19,306] .090 [2,29] .000 [0] .875 [22,22] .060 [1,52] .045 [1,14] .760 [19,306] R.185 [4,7] R.300 [7,62] SCALE 1.000 C DETAIL B SCALE 2.000 5.0° 3.0° DRAFT .725 [18,42] .060 [1,52] .000 [0] SECTION C-C 2.911 -5° [73,94] DRAFT/SIDE 8X .035 +1° [0,89] 8X .185 [4,7] 2X .474 [12,05] SEE DETAIL B 1.661 -5° [42,19] DRAFT/SIDE .187 OD [4,75] .000 [0] .072 ID [1,83] 2X .474 [12,05] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: 2X 1.099 [27,93] .000 [0] 2X 1.099 [27,93] APPROVAL BY 301810 DATE CHECK ENG. SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 3 OF 6 REV.DOC 2.0 1.500 [38,1] .000 [0] 1.500 [38,1] B 301810 BASE .875 [22,22] .000 [0] (5.0° ) .022 [0,56] .040 [1,02] .080 [2,03] C C .173 [4,39] SCALE 1.000 .875 [22,22] R.300 [7,62] .230 + 5°DRAFT/SIDE [5,84] DETAIL D SCALE 3.000 B .115 + 1°DRAFT/SIDE [2,92] 2.910 +5° [73,91] DRAFT/SIDE 1.660 +5° [42,16] DRAFT/SIDE .315 [8] SECTION C-C SEE DETAIL D .080 THICK [2,03] 3.0° DRAFT R.175 [4,45] .020 [0,51] R.100 [2,54] SECTION B-B .542 [13,78] .010 RECESS [0,25] 2X .474 [12,05] LABEL RECESS .01 .000 [0] 2X .474 [12,05] .542 [13,78] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: .834 [21,18] 2X 1.099 [27,93] .000 [0] 2X 1.099 [27,93] .834 [21,18] APPROVAL BY 301810 DATE CHECK ENG. SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 4 OF 6 REV.DOC 2.0 1.375 [34,94] 2X 1.099 [27,93] 2X .474 [12,05] .750 [19,06] .039" THICK PCB SCALE 1.000 .000 [0] .062" THICK PCB SCALE 1.000 .750 [19,06] 2X .474 [12,05] PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 2X .474 [12,05] .750 [19,06] .000 [0] .750 [19,06] 2X .474 [12,05] 301810 PCB - CUSTOMER SUPPLIED 1.375 [34,94] 2X 1.099 [27,93] (2.751 ) [69,87] .000 [0] 4X 2.751 [69,87] .000 [0] (2.199 ) [55,85] 4X .195 [4,95] (2.199 ) [55,85] .120 [3,05] 2X 1.099 [27,93] 1.375 [34,94] 2X 1.099 [27,93] 1.375 [34,94] .200 CHAMFER 4x [5,08] .949 [24,1] .200 CHAMFER 4x [5,08] (.949 ) [24,1] .325 [8,26] KEEP OUT ZONES 4X 4X .325 [8,26] KEEP OUT ZONES .039 [1] .062 [1,57] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL NOTE: ENCLOSURE WILL ACOMMODATE EITHER A .039" PCB OR A .062"PCB, NOT BOTH. BOARDS SHOWN ARE MAXIMUM ENVELOPE DIMENSIONS THIS ENCLOSURE CAN HOUSE. BOARD SIZE AND SHAPE ARE UP TO THE DESIGNER'S DESGRETION AS LONG AS IT'S KEPT WITHIN ENVELOPE DIMENSIONS SHOWN AND PCB MOUNTING HOLE PATTERN IS MAINTAINED. BY 301810 DATE CHECK ENG. SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 5 OF 6 REV.DOC 2.0 301810 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 301810 COVER SCALE 1.000 301810 BASE SCALE 1.000 SXX-301810-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM STEP NO DESCRIPTION 3-C-P1 PAD PRINT SXX-301810-XXX INK COLOR - - FIXTURE COVER ORIENTATION PROGRAM - o1001 o1002 414 414 - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. ABS, BLACK ABS, BLACK X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 301810 DATE CHECK ENG. CLICHE DESCRIPTION FIXTURE CLICHE No. - - CLXXXX R1 SCALE MULTI PORT BAR - STANDARD SXX-301810-XXX SIZE 2016-Jul-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com AS NOTED DRAWN BY R. CRUZ 2240 South Thornburg Street ph. (805) 595-1310 A DRAWING NAME 301810_R2_0 SHEET 6 OF 6 REV.DOC 2.0
S3A-301810 价格&库存
很抱歉,暂时无法提供与“S3A-301810”相匹配的价格&库存,您可以联系我们找货
推荐型号
