S3A-302112-K
S3A-302112-K
    NEWAGE
    MINI AA BATTERY BOX - KIT
S3A-302112-K 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifiying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. A H 1.0 2.0 2.1 3.0 4.0 5.0 5.1 6.0 6.1 7.0 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. S302112(x) CONFIGURATIONS -Blank -K 302112 COVER 1 1 302112 BASE 1 302112 MACHINED BASE 1 302112 HATCH 1 1 302112 WALL CRADLE 1 #4 HiLo SCREW .500" 4 4 M BOYER M BOYER M BOYER M BOYER M BOYER R CRUZ M BOYER R CRUZ R CRUZ M BOYER R CRUZ M BOYER R E V I S I O N DESCRIPTION ECO No 3810 3810 7613 8613 2214 5014 00615 02217 03218 PRELIMINARY RELEASE ADD RIBS AFTER REVIEW 7-12-10 RELEASED BY CUSTOMER ADJUST PCB INFO AND PCB POSTS UNAPPROVED REV 2.0, UPDATE FORMAT ADD "TALL" CONFIGURATION INCLUDE WALL CRADLE OPTION UPDATE CONFIGURATION TABLE REMOVE SCREW HOLE ON CRADLE, "TALL" CONFIGURATION INCLUDE KEEP OUT ZONE AND ADD NOTCHES TO PCB REMOVE "TALL" OPTIONS ON CONFIGURATION TABLE UPDATE BATTERY HATCH TAB FOR IMPROVED ENGAGEMENT DATE APPROVED 21-Nov-09 13-Jul-10 21-Jul-10 28-Sep-10 30-Sep-10 18-Oct-13 16-Dec-13 19-May-14 26-Nov-14 23-Jan-15 2017-Sep-13 2018-Nov-26 D.C. D.C. D.C. D.C. D.C. D.C. D.C. D.C. D.C. D.C. D.C. -WP 1 4 2 3 1 8 6 9 5 302112 STANDARD SCALE 0.750 7 EXPLODED VIEW SCALE 0.750 9 8 7 6 5 4 3 2 1 ITEM SCREW_HILO-NO4X500 AA-SINGL-CONTACT-POS AA-SINGL-CONTACT-NEG AA-DBL-CONTACT 302112_HATCH 302112_COVER 302112_BASE 302112_PCB AA-BATTERY FILE NAME #4 HiLo x .500" SCREW ACC-AAPOS-5223 ACC-AANEG-5201 ACC-AADBL-5212 302112 HATCH - STANDARD 302112 COVER - STANDARD 302112 BASE - STANDARD 302112 PCB - REFERENCE AA BATTERY - REFERENCE STEEL SPRING STEEL SPRING STEEL SPRING STEEL ABS ABS ABS CUSTOMER SUPPLIED CUSTOMER SUPPLIED ZINC PLATED SOLD SEPARATELY SOLD SEPARATELY SOLD SEPARATELY BLACK or WHITE BLACK or WHITE BLACK or WHITE .062" THICK "AA" SIZE 4 1 1 1 1 1 1 1 2 DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2019 Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 1 OF 9 REV.DOC 7.0 3.0° DRAFT TYP. .060 CLEARANCE [1,52] SECTION C-C N R.195 [4,95] 2.100 [53,34] 1.270 [32,26] C 3.020 [76,71] C K SECTION N-N K SCALE 0.750 N .343 CLEARANCE [8,7] 1.270 [32,26] SECTION K-K 1.295 [32,89] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 2 OF 9 REV.DOC 7.0 302112 - COVER .025 [0,64] .085 [2,16] SECTION F-F .625 [15,88] .095 [2,41] 2.100 [53,34] .188 [4,78] 1.620 [41,15] .010 [0,25] F F 3.020 [76,71] 302112 STANDARD SECTION D-D 2.250 [57,15] SCALE 1.000 R.195 [4,95] .030 [0,76] .084 [2,13] 1.295 [32,89] .153 .060 [3,89] [1,52] .188 [4,76] 3.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK .035 [0,89] ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 3 OF 9 REV.DOC 7.0 302112 - BASE .180 [4,57] .057 [1,45] .280 [7,11] .625 [15,88] .100 [2,54] .045 [1,14] 1.620 [41,15] .125 [3,18] J .021 [0,53] 1.170 [29,72] E INSIDE LABEL AREA POS/NEG NOT NOTED 2.250 [57,15] .960 [24,38] E SECTION J-J SCALE 1.000 J .085 [2,16] 3.0° SECTION E-E .177 [4,49] R.020 [0,51] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: .175 [4,45] APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 4 OF 9 REV.DOC 7.0 302112 - HATCH 2.0° .153 [3,88] 5.0° .062 [1,57] .185 [4,7] .130 [3,3] .020 [0,51] .109 [2,77] .072 [1,82] SEE DETAIL B .070 [1,78] DETAIL B SCALE 4.000 DETAIL C SCALE 4.000 X DETAIL D SCALE 4.000 SEE DETAIL D .150 [3,81] Y Y 2.366 [60,11] .085 [2,16] .065 [1,65] SCALE 1.000 3.0° X .100 [2,54] SECTION X-X SEE DETAIL C 1.204 [30,58] SECTION Y-Y .040 +5° DRAFT/SIDE [1,02] 1.286 [32,66] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE .260 [6,6] AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 5 OF 9 REV.DOC 7.0 302112 - WALL CRADLE 1.980 [50,29] .450 [11,43] .193 [4,9] SECTION Y-Y 1.300 [33,02] .790 [20,07] .165 [4,19] 3.234 [82,16] 2.000 [50,8] 2nd OPERATION REQUIRED ON 302112 BASE TO ACCEPT CRADLE TABS 2.991 +1° [75,97] DRAFT/SIDE SCALE 0.750 SECTION Y-Y .180 [4,57] .374 [9,5] .450 [11,43] SECTION X-X TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 6 OF 9 REV.DOC 7.0 1.320 x2 [33,53] 1.390 [35,31] 1.125 x2 [28,58] .800 x2 [20,32] .020 x4 [0,51] .000 [0] .840 x2 .800 x2 [21,32] [20,32] 1.125 x2 [28,58] 1.390 [35,31] 302112 - PCB PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. R.125 [3,18] .920 [23,37] .810 x2 [20,57] .300 KEEP OUT [7,62] ZONE 4 PLACES .280 x2 [7,11] .000 [0] THE TWO BATTERY CONTACTS ON THIS SIDE OF THE BOARD ARE ONLY NESSESARY IF THE BATTERIES ARE WIRED IN PARALLEL OR UTILIZING 4 SINGLE CONTACTS INSTEAD OF THE BRIDGE. .280 x2 [7,11] .810 x2 [20,57] .920 [23,37] R.094 [2,37] SCALE 1.500 .030 [0,76] (.204 ) [5,17] .160 [4,06] .063 [1,59] BOTTOM SIDE TOWARD BATTERIES TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 7 OF 9 REV.DOC 7.0 2nd OPERATION DETAILS - Page 1 of 2 for Wall Cradle Attachment ONLY NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" .449 [11,4] (.141 ) [3,58] NOTCHES FOR WALL CRADLE .080 4x [2,03] .280 4x [7,11] .650 [16,51] .000 [0] .650 [16,51] SCALE 1.000 STEP 1 STEP 2 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-302112X-XXX BASE - ABS, BLACK Customer's Part No: APPROVAL STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 CRADLE NOTCHES CRADLE NOTCHES T2 = .062" EM T2 = .062" EM 193 193 SINGLE SINGLE o6101 o6101 BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 8 OF 9 REV.DOC 7.0 2nd OPERATION DETAILS - Page 2 of 2 NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 302112 COVER SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° SXX-302112X-XXX COVER - ABS, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 193 193 193 SINGLE - NEW AGE ENCLOSURES Customer's Part No: PROGRAM APPROVAL BY 302112 2240 South Thornburg Street ph. (805) 595-1310 MINI AA - STANDARD SXX-302112X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2009-Nov-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 302112_R7_0 SHEET 9 OF 9 REV.DOC 7.0
S3A-302112-K 价格&库存
很抱歉,暂时无法提供与“S3A-302112-K”相匹配的价格&库存,您可以联系我们找货
S3A-302112-K
  • 1+98.960211+12.27597
  • 5+84.542995+10.48752
  • 10+79.0032510+9.80032
  • 25+72.2379525+8.96109
  • 50+67.5074450+8.37427
  • 100+63.08675100+7.82589
  • 250+59.27037250+7.35247
库存:39
