S3A-303010
S3A-303010
    NEWAGE
    ROUTER CUBE
S3A-303010 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. A M BOYER B 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11007. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. R E V I S I O N DESCRIPTION ECO No DATE APPROVED PRELIMINARY RELEASE 30-Jan-14 D.C. R CRUZ CLEAN UP DIMENSIONS 17-Feb-14 D.C. C R CRUZ REVISE PER MEETING 17-Feb-14 17-Feb-14 D.C. D M BOYER ADD .031" PCB OPTION 20-Jun-14 D.C. E M BOYER REVISE .031" PCB THICKNESS TO .039" 27-Jun-14 D.C. F M BOYER REVISE ASSY POST ID 04-Sep-14 D.C. REVISE TEXTURE CALLOUT 08-Oct-14 D.C. UPDATE TO AS BUILT AND RELEASE 21-Nov-14 G R CRUZ 1.0 R CRUZ DR XXX 0427 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.015 MAX. 3 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.015" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. 4 2 1 303010 EXPLODED VIEW SCALE 1.000 SCALE 0.500 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 4 303010_PCB_062 303010 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 303010_COVER 303010 COVER - STANDARD ABS BLACK or WHITE 1 2 303010_BASE 303010 BASE - STANDARD ABS BLACK or WHITE 1 1 SCREW_HILO-NO4X375 #4 HiLo x .375" SCREW ZINK PLATED 3/8" LONG 4 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2014 Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 1 OF 7 REV.DOC 1.0 303010 ASSEMBLY A .595 CLEAR [15,11] .018 [0,46] 3.000 [76,2] .062 PCB [1,57] R.401 [10,17] A .173 CLEAR [4,39] DETAIL A SCALE 2.000 SCALE 0.750 3.0° DRAFT TYP. 1.000 [25,4] .666 [16,92] .316 [8,03] R.175 [4,45] SECTION A-A SEE DETAIL A 2.200 [55,88] 1.750 [44,45] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 2 OF 7 REV.DOC 1.0 303010 COVER C .015 [0,38] 1.500 [38,1] .060 [1,52] .090 [2,29] .000 [0] .058 [1,47] .044 [1,12] DETAIL B SCALE 2.000 1.500 [38,1] SCALE 0.750 5.0° R.401 [10,17] C .724 [18,39] .058 [1,47] .000 [0] 2.909 -5° DRAFT/SIDE [73,89] SECTION C-C SEE DETAIL B 2x 1.100 [27,94] .000 [0] .187 OD [4,75] .072 ID [1,83] 2x 1.100 [27,94] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 3 OF 7 REV.DOC 1.0 303010 BASE ( .119 -1° DRAFT/SIDE) [3,01] .190 [4,83] B .312 +5° DRAFT/SIDE [7,92] 1.500 [38,1] .023 [0,58] 5.0° .173 [4,39] .000 [0] .040 [1,02] DETAIL C SCALE 2.000 .023 [0,58] .230 +5° DRAFT/SIDE [5,84] .115 +1° DRAFT/SIDE [2,92] 1.500 [38,1] SCALE 0.750 B R.401 [10,17] 2.914 +5° DRAFT/SIDE [74,02] 3.0° SECTION B-B R.175 [4,45] 2x 1.100 [27,94] .316 [8,03] .080 [2,03] SEE DETAIL C R.100 [2,54] .875 [22,23] .000 [0] .875 [22,23] 2x 1.100 [27,94] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 4 OF 7 REV.DOC 1.0 303010 PCB .062" - CUSTOMER SUPPLIED 1.401 [35,57] 1.100 [27,94] .000 [0] 1.100 [27,94] 1.401 [35,57] PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.401 [35,57] 1.100 [27,94] (2.200 [55,88] .000 [0] ) (2.801 [71,15] ) 1.100 [27,94] 1.401 [35,57] SCALE 1.000 .195 4x [4,95] R.301 [7,65] .325 KEEP OUT ZONE 4x [8,26] .062 [1,57] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 5 OF 7 REV.DOC 1.0 303010 PCB .039" - CUSTOMER SUPPLIED 1.401 [35,57] 1.100 [27,94] .000 [0] 1.100 [27,94] 1.401 [35,57] PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.401 [35,57] 1.100 [27,94] (2.801 [71,15] .125 4x [3,18] (2.200 [55,88] .000 [0] ) ) .325 KEEP OUT [8,26] 1.100 [27,94] 1.401 [35,57] SCALE 1.000 .039 [0,99] TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 6 OF 7 REV.DOC 1.0 303010 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 303010 COVER SCALE 1.000 303010 BASE SCALE 1.000 SXX-303010-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM STEP NO DESCRIPTION 3-C-P1 PAD PRINT SXX-303010-XXX INK COLOR - FIXTURE ABS, BLACK ORIENTATION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. PROGRAM 292 292 COVER - X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL ABS, BLACK CLICHE DESCRIPTION BY DATE CHECK ENG. CLICHE No. CLXXXX R1 SCALE AS NOTED DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - ROUTER CUBE SXX-303010-XXX SIZE 30-Jan-14 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 303010 A DRAWING NAME 303010_CUBE_R1_0 SHEET 7 OF 7 REV.DOC 1.0
S3A-303010 价格&库存
很抱歉,暂时无法提供与“S3A-303010”相匹配的价格&库存,您可以联系我们找货
