S6L-373717
S6L-373717
    NEWAGE
    OUTDOOR NODE
S6L-373717 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.010 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE MT-11020, UNLESS SPECIFIED OTHERWISE 3. ALL INSIDE RADII .020R. UNLESS OTHERWISE SPECIFIED. 4. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 5. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 6. MATERIAL / COLOR: ENCLOSURE IS STANDARD IN BLACK OR GRAY ASA PLASTIC. SLIGHT COSMETIC VARIATIONS CAN OCCUR IN THIS ENCLOSURE DUE TO UV INHIBITORS IN THE RESIN. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 7. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 8. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS FOR THE PCB ARE CUSTOMER SUPPLIED. R E V I S I O N DESCRIPTION DATE APPROVED PRELIMINARY RELEASE 07-Nov-2013 D.C. R CRUZ INCREASE COVER HEIGHT, WIDEN STRAP GUIDE 07-Nov-2013 D.C. C R CRUZ ADJUST COVER DRAFT & PART NUMBER 08-Nov-2013 D.C. D R CRUZ O-RING INCLUDED WITH ENCLOSURE 26-Nov-2013 D.C. E R CRUZ ADD RIBS TO ALL WALLS 07-Apr-2014 D.C. 1.0 R CRUZ 0407 UPDATE TO AS-BUILT AND RELEASE 31-Oct-2014 D.C. 1.1 R CRUZ 02115 UPDATE NOTE 6 20-May-2015 D.C. 2.0 R CRUZ 03115 CHANGED O-RING COLOR FROM NATURAL TO BLUE 07-Jul-2015 D.C. 3.0 R CRUZ 00518 UPDATE O-RING AND NOTES, INCREASE COVER LIP 2018-Jun-07 A R CRUZ B ECO No DR XXX 9. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 10. ALLOWABLE FLASH: 0.010 MAX. 11. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 1 9 12. TRIM GATE WITHIN 0.030" OF FLUSH. 13. THIS ENCLOSURE IS CONSTRUCTED FOR INDOOR OR OUTDOOR USE TO PROVIDE A DEGREE OF PROTECTION TO THE EQUIPMENT INSIDE AGAINST THE INGRESS OF SOLID FORIEGN OBJECTS (FALLING DIRT); AND TO PROVIDE A DEGREE OF PROTECTION WITH RESPECT TO TO HARMFUL EFFECTS ON THE EQUIPMENT DUE TO THE INGRESS OF WATER (DRIPPING OR SPLASHING). 7 TEXTURE: MT-11020 3 6 8 2 5 4 TEXTURE: B2 POLISH SCALE 0.400 SCALE 0.500 9 6-32_PHILLIPS_SCREW 6-32 PHILLIPS SCREW x .375" 18-8 STAINLESS S-MS 6-32.375 4 8 6-32X344_BRASS-INSERT 6-32 BRASS INSERT x .344" 632x344MB OVER-MOLDED 4 7 373717_ORING OR-045 ORING SHORE A INCLUDED 1 6 SCREW_HILO-NO4 #4 HiLo SCREW x .250" ZINC PLATED CUSTOMER SUPPLIED 4 5 SCREW-DRYWALLX750 DRYWALL SCREW REFERENCE ONLY CUSTOMER SUPPLIED 4 4 373717_STRAP MOUNTING STRAP x 1.000" WIDE REFERENCE ONLY CUSTOMER SUPPLIED 1 3 373717_PCB 373717 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 373717_WALL-BASE 373717 WALL BASE - STANDARD ASA BLACK or GRAY 1 1 373717_COVER 373717 COVER - STANDARD ASA BLACK or GRAY 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 373717 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 1 OF 6 REV.DOC 3.0 373717 ASSEMBLY .285 CLEAR 1.175 CLEAR 4.771 1.108 1.700 3.700 4.100 Y S S 3.779 1.075 2.890 2.900 LABEL RECESS x2 0.012" SECTION Y-Y Y .800 RECESS R.194 3.125 RECESS 2.890 20.0° SCALE 0.500 .199 .093 4.3 DRAFT INTERIOR .314 5.0° DRAFT EXTERIOR (R.048) .075 SECTION S-S SEE DETAIL A TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DETAIL A SCALE 2.000 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 373717 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 2 OF 6 REV.DOC 3.0 373717 COVER 4.450 3.700 .085 TYP. 2.890 1.250 3.950 .085 Y E 3.700 -5° DRAFT/SIDE 2.890 E 3.700 1.800 .175 R.072 SECTION Y-Y R.477 SCALE 0.500 Y R.250 20.0° .120 SEE DETAIL E SECTION E-E DETAIL E SCALE 2.000 .065 .020 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 373717 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 3 OF 6 REV.DOC 3.0 373717 WALL BASE 4.771 4.100 R.194 2.800 3.125 .175 Y .800 .285 3.779 2.800 E .105 2.900 E 1.108 .185 .175 SCALE 0.500 Y OVER-MOLDED BRASS INSERT SEE B.O.M. ON SHEET 1 .187 .335 5.0° SECTION Y-Y SEE DETAIL B .060 .101 -2° DRAFT .140 SECTION E-E DETAIL B SCALE 3.000 5.0° TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL .430 BY 373717 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 4 OF 6 REV.DOC 3.0 373717 PCB - CUSTOMER SUPPLIED 1.670 2X 1.400 .000 2X 1.400 1.670 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.670 2X 1.400 .000 2X 1.400 R.320 1.670 .120 4X SCALE 1.000 .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 373717 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 5 OF 6 REV.DOC 3.0 373717 - 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 373717 COVER SCALE 0.750 SXL-373713-XXX COVER - ASA, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 298 298 298 - - SXL-373713-XXX COVER - TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 373717 DATE CHECK ASA, BLACK ENG. STEP TYPE FIXTURE INK COLOR CLICHE DESCRIPTION CLICHE No. 4-C-P1 PAD PRINT 299 WHITE LOGO AND LABELS CLXXXXn R1 SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - OUTDOOR NODE SXX-373717-XXX SIZE 2013-Nov-07 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 373717_R3_0 SHEET 6 OF 6 REV.DOC 3.0
S6L-373717 价格&库存
很抱歉,暂时无法提供与“S6L-373717”相匹配的价格&库存,您可以联系我们找货
推荐型号
