S1A-434313FW
S1A-434313FW
    NEWAGE
    SQUARE UTILITY, FW
S1A-434313FW 数据手册
R E V I S I O N NOTES: UNLESS OTHERWISE SPECIFIED REV. 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. DRAWN BY ECO No A-J M BOYER 1.0 M BOYER N/A 1.1 M BOYER 04515 DESCRIPTION DATE APPROVED DEVELOPMENT 2009-Aug-24 D.C. UPDATE TO AS-BUILT AND RELEASE 2010-Mar-29 D.C. REVISE ASSEMBLY SCREW LENGTH 2015-Sep-14 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 2 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7 7. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. MOUNTING SCREWS FOR THE PCB ARE SOLD SEPERATELY. 4 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 5 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. 8 10. STANDARD OR CUSTOM LABEL RECESSES ARE AVAILABLE UPON REQUEST FOR QUOTE. 434313 ENCLOSURE SHOWN WITH 2 PCB SIZE OPTIONS. THIS ENCLOSURE DOES NOT SUPPORT TWO PCB BOARDS AT ONCE. 1 3 S434313 S434313 S434313 S434313 S434313 S434313 #4 HiLo S434313 S434313(x) CONFIGURATIONS -S -SW -F COVER COVER w/ OPENING BASE BASE w/ OPENING WALL BASE WALL BASE w/ OPENING SCREW .500" FACEPLATE 1 1 1 1 4 4 1 -FW -FP 1 6 1 4 EXPLODED VIEW SCALE 0.666 1 4 1 8 434313_FACEPLATE 434313 FACEPLATE - STANDARD 6061 ALUMINUM SOLD SEPERATELY 1 7 NO_4_375_SCREW No4 HiLo x .375" - PCB #4 HiLo x 3/8" SOLD SEPERATELY 4 6 NO_4_500_SCREW No4 HiLo x .500" - ASSEMBLY #4 HiLo x 1/2" INCLUDED 4 5 434313_PCB-4X4 434313 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 4 434313_PCB-4X3 434313 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 434313_WALL-BASE 434313 WALL - STANDARD ABS BLACK or WHITE 1 2 434313_COVER 434313 COVER - STANDARD ABS BLACK or WHITE 1 1 434313_BASE 434313 BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DO NOT SCALE DRAWING NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2010 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 1 OF 8 REV.DOC 1.1 4.284 3.0° 4.284 3.500 SQ. RECESS .015 SCALE 0.500 .900 X THIS ENCLOSURE CAN BE MOLDED WITH OR WITHOUT THE FACEPLATE OPENING. ASK YOUR SALES REP FOR DETAILS. 26.4° X DETAIL A SCALE 1.000 SECTION X-X SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL SEE DETAIL A BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 2 OF 8 REV.DOC 1.1 434313 COVER 4.284 3.500 X 3.600 R.199 .020 R.060 Y 4.284 Y 3.500 2.400 P SCALE 0.500 P SECTION X-X X .092 .900 SECTION P-P .250 4x .980 .110 WALL THICKNESS .010 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK SECTION Y-Y ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 3 OF 8 REV.DOC 1.1 2.142 1.450 2x 1.800 2x .000 1.450 2x 4.284 1.800 2x 2.142 434313 BASE 2.010 H 2.142 1.800 2x 1.200 2x Y 4.284 2.010 Y RECESS .01 G G .000 2.025 1.200 2x 1.800 2x .052 SECTION H-H 2.142 SCALE 0.500 .385 x .02 4 PLACES H .110 R.150 .052 slot 1.500 .281 .092 .250 3.0° .390 .150 3.700 .203 +1° DRAFT/SIDE .060 .246 SECTION G-G .110 WALL THICKNESS .010 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. SECTION Y-Y 4.057 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 4 OF 8 REV.DOC 1.1 434313 WALL 5.080 2.010 5.0° G .246 R.050 Y Y .125 4.355 2.010 RECESS x .010 .250 SECTION G-G .092 SCALE 0.500 G .140 4.650 29.7° 3.700 .390 SECTION Y-Y .080 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 5 OF 8 REV.DOC 1.1 434313 FACE PLATE 3.800 3.700 AVAILABLE .268 FROM CENTERLINE TO TOP OF ASSEMBLED PCB BOARD (REFERENCE) .835 .935 AVAILABLE (.200) .030 x 45° TYP. 434313 FACEPLATE SCALE 1.000 .048 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 6 OF 8 REV.DOC 1.1 434313 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. SEE SHEET 4 FOR POST CLEARANCE DETAILS. ENCLOSURE DESIGNED TO ACCOMODATE ONE OF THE TWO PCB CONFIGURATIONS SHOWN BELOW (NOT BOTH AT THE SAME TIME). 4.000 3.300 3.600 2.900 4.000 2.400 4.000 3.600 .125 4x ALLOWANCES MUST BE MADE FOR THE EXTRA PCB POSTS IN ENCLOSURE OR POSTS SHOULD BE CLIPPED BY CUSTOMER. .064 4x4 PCB SCALE 0.500 FRONT FACE (FACEPLATE SIDE) FRONT FACE (FACEPLATE SIDE 4x3 PCB SCALE 0.500 .125 4x .064 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 7 OF 8 REV.DOC 1.1 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 434313 COVER SCALE 0.500 SXX-434313-XXX COVER 434313 BASE SCALE 0.500 - ABS, BLACK STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 3-C-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 207 207 207 - o1000 o1000 o1000 SXX-434313-XXX BASE - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: STEP NO DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-B-C1 2-B-C2 3-B-C3 - T2 = .062" EM T2 = .062" EM T2 = .062" EM 234 234 234 - o1000 o1000 o1000 APPROVAL BY DATE CHECK ENG. SCALE DRAWN BY M BOYER 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - SQUARE UTIL. SXX-434313X-XXX SIZE 2009-Aug-24 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 434313 DRAWING NAME A 434313X_R1_1 SHEET 8 OF 8 REV.DOC 1.1
S1A-434313FW 价格&库存
很抱歉,暂时无法提供与“S1A-434313FW”相匹配的价格&库存,您可以联系我们找货
