S1A-332010
S1A-332010
    NEWAGE
    UTILITY BAR
S1A-332010 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. V I S I O N DATE APPROVE A M BOYER PRELIMINARY RELEASE 2017-May-30 D.C. B M BOYER REVISE SIZE 2017-May-31 D.C. C M BOYER REVISE SIZE FOR ETHERNET 2017-Jun-02 D.C. D R CRUZ REVISE ENVELOPE DIMENSIONS 2017-Jun-06 D.C. E R CRUZ REVISE ENCLOSURE NAME 2017-Jul-25 D.C. 1.0 M BOYER UPDATE SHEETS AND RELEASE TO REV 1 PER CUSTOMER 2017-Jul-28 D.C. 2.0 R CRUZ UPDATE TO AS-BUILT DIMENSIONS 2019-Jun-26 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 01919 DESCRIPTION E DRAWN BY 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVALENT TO MT-11010. TEXTURE ON ENCLOSURE WILL VARY FROM TIME TO TIME AS THE TOOL WEARS AND IT BECOMES NESSESARY TO REAPPLY. ECO No R REV. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. ALTERNATE RESINS HAVE DIFFERENT SHRINK RATES, AND WILL EFFECT DIMENSIONS. 2 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF EACH CUSTOMER. 9. ASSEMBLY SCREWS FOR THE ENCLOSURE INCLUDED. FOR THE PCB ARE SOLD SEPARATELY. MOUNTING SCREWS 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. 4 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 13. TRIM GATE WITHIN 0.030" OF FLUSH. 5 3 1 SCALE 1.000 6 SCALE 1.000 6 SCREW_HILO-NO4X375 #4 HiLo SCREW x .375" ZINC PLATED INCLUDED 4 5 SCREW_HILO-NO4X250 #4 HiLo SCREW x .250" ZINC PLATED CUSTOMER SUPPLIED 8 4 332010_PCB-TOP 332010 TOP PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 3 332010_PCB-BOT 332010 BOTTOM PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 332010_COVER 332010 COVER - STANDARD ABS BLACK or WHITE 1 1 332010_BASE 332010 BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 332010 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 1 OF 6 REV.DOC 2.0 332010 ASSEMBLY 3.250 2.000 R.400 R5.970 SCALE 1.000 .561 .226 X .690 1.030 X SECTION X-X .320 .153 .488 R.105 1.020 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 332010 DATE CHECK 2.050 ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 2 OF 6 REV.DOC 2.0 332010 COVER 1.351 P X X 3.161 -5° DRAFT/SIDE 2.450 1.750 4X SCALE 1.000 4X P SECTION P-P .090 .090 SEE DETAIL A .385 .007 1.911 -5° DRAFT/SIDE TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 332010 DATE CHECK SECTION X-X ENG. DETAIL A SCALE 2.000 .070 SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 3 OF 6 REV.DOC 2.0 332010 BASE .320 P 4X X X RECESS .015" SCALE 1.000 .090 4X P .137 SECTION P-P SEE DETAIL B .090 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .012 SECTION X-X X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL DETAIL B SCALE 2.000 BY 332010 DATE CHECK ENG. .050 SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 4 OF 6 REV.DOC 2.0 332010 PCB .880 .550 .675 2x .000 .675 2x .550 .880 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .062 1.490 1.100 .875 2x .800 2x .000 R.063 .800 2x .875 2x .125 4x 1.100 .215 4x KEEP OUT ZONE 1.490 R.125 4x 332010 PCB SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 332010 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 5 OF 6 REV.DOC 2.0 332010 2nd OPERATION NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 332010 COVER SCALE 1.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SXX-332010-XXX COVER - Customer's Part No: ABS, BLACK APPROVAL STEP DESCRIPTION CUTTER FIXTURE ORIENTATION PROGRAM 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM 424 424 - o1001 o1002 BY 332010 DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 UTILITY BAR - STANDARD SXX-332010-XXX SIZE 2017-May-30 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 332010_R2_0 SHEET 6 OF 6 REV.DOC 2.0
S1A-332010 价格&库存
很抱歉,暂时无法提供与“S1A-332010”相匹配的价格&库存,您可以联系我们找货
推荐型号
