Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 9008A
Construction
Diameters (In)
1) Component 1
1 X 1 COAX
a) Conductor
13 (7/21) AWG BC
b) Insulation
0.0995" Wall, Nom. Polyethylene(PE)
0.285
Cond
Cond
(1) Color(s)
Cond
Color
1
CLEAR
Color
2) Shield
BC BRAID Shield,95% Coverage, Min.
3) Jacket
0.044" Wall, Nom.,Type IIA PVC
a) Color(s)
BLACK
b) Print
ALPHA WIRE-* P/N 9008A
RG 8A/U RU AWM STYLE 1354 ROHS
* = Factory Code
Color
0.405+/- 0.010
Applicable Specifications
1) UL
AWM/STYLE 1354
60°C / 30 VRMS
2) Military
MIL-C-17D/3A RG-8A/U
60°C / 3700 VRMS
Environmental
1) EU Directive 2002/95/EC(RoHS):
All materials used in the manufacture of this part are in compliance with EU Directive
2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and
electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture.
2) California Proposition 65:
Properties
The outer surface materials used in the manufacture of this part meet the requirements of
California Proposition 65.
Physical &Mechanical Properties
1) Temperature Range
-20 to 60°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
61 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
3700 VRMS
2) Characteristic Impedance
52 +/- 2
3) Ground Capacitance
29.5 pf/ft @1 kHz, Nominal
4) Velocity of Propagation
66 %
5) Conductor DCR
1.9 /1000ft @20°C, Nominal
6) OA Shield DCR
1.2 /1000ft @20\°C, Nominal
7) Voltage Withstanding
10 kV, Minimum
8) Corona Extinction
5 kV, Minimum
9) Attenuation, Max dB/100ft
6 @ 400 MHz
Other
1) Packaging
a) 1000 FT
b) 500 FT
c) 100 FT
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
RoHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number:9008A
9008A , RoHS-Compliant Commencing With8/1/2005Production
This document certifies that the Alpha part numbers cited above are manufactured in accordance with Directive 2002/95/EC of the European
Parliament and of the Council of 27 January 2003, better known as the RoHS Directives, with regards to restrictions of the use of certain hazardous
substances used in the manufacture of electrical and electronic equipment. The reader is referred to these Directives for the specific definitions and
extents of these Directives. No Exemptions are required for RoHS Compliance on this item.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.1% by weight (100 ppm)
Hexavalent Chromium
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE)
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its
release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or
the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is
for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering &QA
11/3/2010
很抱歉,暂时无法提供与“9008A BK005”相匹配的价格&库存,您可以联系我们找货
