Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. V16108
Construction
Diameters (In)
1) Component 1
4 X 1 COND
a) Conductor
8 (133(7x19)/29) AWG TC
0.167
b) Insulation
0.061" Wall, Nom. XLPE
0.288
Cond
(1) Color(s)
Cond
Color
Cond
Color
1
BLACK#1
3
BLACK#3
2
BLACK#2
4
GREEN OR
GREEN/YELLOW
2) Component 2
1 X 1 PAIR
a) Conductor
14 (41/30) AWG TC
0.074
b) Insulation
0.032" Wall, Nom. XLPE
0.142
(1) Separator
Paper Tape, 10% Overlap, Min.
Color
(2) Color(s)
Pair
Color
1
BLACK-WHITE
Pair
Color
c) Pair
2/Cond Cabled Together
(1) Twists:
2.8 Twists/foot (min)
Pair
Color
Individually Applied:
d) Shield:
Alum/Mylar Tape, 25% Overlap, Min.
(1) Foil Direction
Foil Facing In
(2) Drain Wire
14 (41/30) AWG TC
3) Cable Assembly
5 Components Cabled
a) Twists:
1.1 Twists/foot (min)
4) Shield:
A/P/A Tape, 25% Overlap, Min.
a) Drain Wire
4 x 14 (41/30) AWG TC
b) Braid
TC,85% Coverage, Min.
5) Jacket
0.085" Wall, Nom.,PVC
a) Color(s)
BLACK
b) Jacket Separator
Tissue Tape, 25% Overlap, Min.
c) Print
ALPHA WIRE- E64067-L P/N V16108 4/C 8 AWG RHW-2
1PR 14 AWG XHHW-2 SERIES V VFD CABLE W/ BRAKE PAIR
600V TYPE TC-ER (UL) XLPE/PVC 90C DRY/WET SUN RES
DIR BUR 4/C 8 AWG 1PR 14 AWG--- LLXXXXXX CSA AWM
I/II A/B 1000V 90C FT4 --- CE ROHS
[Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.]
Applicable Specifications
1.032+/- 0.034
1) UL
RHW-2Wet/Dry
90°C / 600 VRMS
XHHW-2Wet/Dry
90°C / 600 VRMS
b) Component 2
XHHW-2Wet/Dry
90°C / 600 VRMS
c) Overall
TC
90°C / 600 VRMS
a) Component 1
EXPOSED RUN
DIRECT BURIAL
SUN RES
2) CSA International
a) Component 1
AWM I A/B
90°C / 1000 VRMS
b) Component 2
AWM I A/B
90°C / 1000 VRMS
c) Overall
AWM I/II A/B
90°C / 1000 VRMS
FT4
3) CE:
LVD 73/23/EEC Amendment 93/68/EEC
Environmental
1) EU Directive 2002/95/EC(RoHS):
All materials used in the manufacture of this part are in compliance with EU Directive
2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and
electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture.
Properties
Physical & Mechanical Properties
1) Temperature Range
-40 to 90°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
786 Lbs, Maximum
4) Sunlight Resistance
Yes
5) Direct Burial
Yes
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
1000 VRMS
2) Component 1
a) Characteristic Impedance
62 Ω
Other
Packaging
Flange x Traverse x Barrel (inches)
a) Bulk(Made-to-order)
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications
described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not
ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or
implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever,
even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out
of or in connection with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY
Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE,
and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and
agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be
copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall
govern the status of this document. ©2013 ALPHA WIRE - all rights reserved.
EU/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: V16108
V16108 , RoHS-Compliant Commencing With 10/1/2005 Production
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European
Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of
electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions
are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this
Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope. Additionally, Alpha certifies that
the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its
release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or
the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is
for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual
usage of the product.
Authorized Signatory for the Alpha Wire Company:
Dave Watson, Director of Engineering & QA
5/16/2013
