AB-FA02406-19700-XA2
    AMERICANBRIGHT
    LIGHT STRIP W IP20 24V 6 LED/SEG
AB-FA02406-19700-XA2 数据手册
13815-C MAGNOLIA AVE., CHINO, CA 91710 TOLL-FREE: 888-LED-0800 TEL: 909-628-5050 FAX: 909-628-5006 w w w . a m e r i c a n b r i g h t l e d . c o m AB-FA Flexible Tape Light Series Flexible Tape Light in 12V/24V DC - Single color, RGB, and RGBW options Features: Applications: • UL listed • Conference/meeting rooms • IP20 no surface coating • Commercial/ residential buildings • Top emitting, wide viewing angle 120° • Entertainment lighting • Hospitals • Storage temperature 0°C~60°C • Hotels • Operating temperature -20°C~80°C • Environment humidity 40-70%RH 1 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Part numbering system: AB–FAVVVKK–LLLWL–XA1 V V V – Voltage (volt) (012=12V, 024=24V) K K – Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 63 – 6300K, 65 – 6500K CCT, RD – Red, GR – Green, BL – Blue, AM – Amber, 06 – RGB, 08 – RGBW) L L L – Light strip length (unit: inch); Length selection of the strip: 12V 24V Single Color Multiple of 25mm Multiple of 50mm RGB/RGBW Multiple of 50mm Multiple of 100mm W L – Wire Lead length (unit: inch); standard length is 12 inches; 00- No wire, no end cap X – CRI (8 – 80, 9 – 90, X – not applicable) Ax – Version (Internal Code) For example, part number below calls out a flexible tape light with IP20 rating, 24V DC in 3000K CCT, CRI80, 197 inches long with 12 inches wire lead. AB–FA02430–19712–8A1 2 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Outline Dimension: Single Color: DC 12V: resistor DC 24V: resistor RGB Color: DC 12V: UL resistor 3 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 DC 24V: UL resistor RGBW Color: DC 12V: UL DC 24V: UL 1,2, Cutting Mark is imprinted on the strip: 12V 24V Single Color Every 25mm Every 50mm RGB/RGBW Every 50mm Every 100mm 1. Heat shrinks on both ends. 2. Light strip comes with rear adhesive, 3M 300LSE. 4 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Schematic Diagram: Single Color: DC 12V: DC 24V: RGB Color: DC 12V: 5 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 DC 24V: RGBW Color: DC 12V: 6 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 DC 24V: Characteristics: Table 1. Configurations for AB-FA Flexible Tape Light Series. OPERATING VOLTAGE (V) CURRENT (A/m) POWER LENGTH3 (W/m) m (inch) LED COUNT/m White/Green/Blue: 0.66 8 Red/Amber: 0.83 10 RGB: 0.83 10 60 RGBW: 1.18 14.2 60 RGB + 60 W White/Green/Blue: 0.33 8 Red/Amber: 0.41 10 RGB: 0.41 10 60 RGBW: 0.59 14.2 60 RGB + 60 W 120 12 5 (197) 120 24 3 5 (197) Standard length: 5m or 10m/roll, contact aboc@americanbrightled.com for custom length 7 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Table 2. Product performance of AB-FA Flexible Tape Light Series at T=25 degree C. PART NUMBER AB-FA012KK5-197WL6-XA1 AB-FA024KK-197WL -XA1 AB-FA01206-197WL-XA2 AB-FA02406-197WL-XA2 AB-FA01208-197WL-8Ax7 AB-FA02408-197WL-8Ax CCT/ WAVELENGTH 30: 3000K 40: 4000K 63: 6300K RD: Red 620-625nm GR: Green 520-525nm BL: Blue 440-450nm AM: Amber 558-592nm RD: Red 625-635nm GR: Green 520-535nm BL: Blue 465-475nm RD: Red 620-630nm GR: Green 520-525nm BL: Blue 460-475nm 27: 2700K 30: 3000K 40: 4000K 50: 5000K 65: 6500K LUMINOUS FLUX4 (lm/m) LUMINOUS EFFICACY (lm/W) CRI 720 90 >80 250 560 168 190 25 70 21 19 / / / / 90 248 56 81 223 50.2 25 73 18 / / / / / / / / / 334 / >80 4 Luminous flux ±10% is allowed. KK – Color/CCT (27 – 2700K, 30 – 3000K, 40 – 4000K, 50 – 5000K, 65 – 6500K CCT, 06 – RGB, 08 – RGBW) 6 WL – Wire lead length (12 – 12”, 00 – 0” no end cap, no wire lead) 7 x – 1- 3000K CCT, 2-4000K CCT, for other color temperature, please contact aboc@americanbrightled.com. 5 8 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Optional Mounting Accessories: Table 3. Mounting Accessories Item# AB-M-SS-10-12-L20 Size (mm) Description Compatible to 20x10x13 Stainless mounting bracket AB-FF series Silicon mounting bracket AB-FA series AB-FC series AB-FD series Aluminum Channel AB-FB series AB-M-SI-RBLL-06 18.3x6x6 AB-M-AL-20-09-1000 5000x15x10 AB-M-SS-18-09-L20 20x18x10 Stainless mounting bracket AB-FB series AB-M-SS-7-9-L7 7x6x12 Stainless mounting bracket AB-FH series Image 9 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Installation Instructions: Maximum flexibility precaution: 10 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019 Packaging: Table 4. Packaging information 8 Model QTY8 AB-FA series AB-FC series AB-FD series 1 roll/per ESD bag 10 bags/carton AB-FB series AB-FF series AB-FH series 1 roll/per tray 10 trays/carton Image Standard length: 5m or 10m/roll, 1 roll/bag. QTY/bag varies per different unit lengths. 11 AB-FA Flexible Tape Light Series Copyright © 2019 American Bright Optoelectronics Corp. All right reserved. Version: 2 Date: 5/2/2019
AB-FA02406-19700-XA2 价格&库存
很抱歉,暂时无法提供与“AB-FA02406-19700-XA2”相匹配的价格&库存,您可以联系我们找货
