Environmental Specifications . . . . . . . . . . . . . . . . . . . . . . 2
Equivalent Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Standard Pressure Ranges . . . . . . . . . . . . . . . . . . . . . . . . 3
Performance Characteristics. . . . . . . . . . . . . . . . . . . . . 4
Soldering Recommendations. . . . . . . . . . . . . . . . . . . . 4
I2C Electrical Parameters. . . . . . . . . . . . . . . . . . . . . . . . . 5
Operation Overview .. . . . . . . . . . . . . . . . . . . . . . . . . 6-7
Digital Interface Command & Data Formats. . . 7-8
I2C Interface ................................ . . . . ...8-10
How to Order Guide........................ . . . . . . . . 11
Standard Part Number Configurations.... . . . . . . . . 11
Product Identification Guide............... . . . . . . . . 12
Dimensional Package Drawings
Differential SMT, SML and SOIC...13-14
The low supply voltage allows for integration of the sensors into a wide range of process control and measurement
systems, as well as direct connection to I2C serial communications channels. The DLC series offers 16 bit digital
resolution. The digital interface options ease integration
measurement systems, allowing direct connection to serial
communications channels. For battery-powered systems, the
sensors can enter very low-power modes between readings
to minimize load on the power supply.
These calibrated and compensated sensors provide accurate,
stable output over a wide temperature range. This series
is intended for use with non-corrosive, non-ionic working
fluids such as air and dry gases.
Gage DIP and SMT . . . . . . . . . . . . . . . . . . . . . . . 15
A bsolute SMT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Packing Options................................16
Pressure Tubing Recommendations.......17
Suggested Pad Layouts .......................17
All Sensors
DS-0365 Rev A
Page 1
f 408 225 2079
Pressure Sensor Maximum Ratings . . . . . . . . . . . . . . . 2
p 408 225 4314
Features & Applications . . . . . . . . . . . . . . . . . . . . . . . . . . 2
The DLC Series Compact High Resolution Sensor is based on
All Sensors’ CoBeam2 TM Technology. This reduces package
stress susceptibility, resulting in improved overall long term
stability. This technology breakthrough advances the state of
the art for piezoresistive pressure sensors beyond what has
been achieved for low pressure sensing using silicon based
strain technology. Design engineers will find exceptional
space savings with optimal performance for various compact
applications.
a 16035 Vineyard Blvd. Morgan Hill, CA 95037
Introduction
Table of Contents
e www.allsensors.com
all sensors
DLC - Compact High Resolution Pressure Sensors Series
DLC — Compact High-Resolution Pressure Sensors
all sensors
Features
• Pressure Ranges from 1 inH2O to 150 psi
• High Resolution 16 bit Output
• Digital I2C Interface
• 1.8V to 3.6V Supply Voltage Range
• Compact Package Sizes As Small As 7mm x 7mm
Supply Voltage (Vs)
Common Mode Pressure
3.63 Vdc
10 psig
Temperature Ranges
Compensated
Operating
Storage
-25°C to 85 °C
-40°C to 85 °C
-40°C to 125 °C
Humidity Limits (non condensing) 0 to 95% RH
Equivalent Circuit
Vs
SCL
I2C
SDA
EOC
Gnd
See package drawings for pinouts
All Sensors
Table of Contents
p 408 225 4314
f 408 225 2079
Applications
• Medical Breathing
• Industrial Controls
• HVAC
• Environmental Controls
• Portable Equipment
DS-0365 Rev A
Page 2
Low Pressure Products
Device
Operating Range A
Proof Pressure
Burst Pressure
DLC-L01D
± 1 inH2O
248.84 Pa
100 inH2O
24.88 kPa
300 inH2O
74.65 kPa
DLC-L02D
± 2 inH2O
497.68 Pa
100 inH2O
24.88 kPa
300 inH2O
74.65 kPa
DLC-L05D
± 5 inH2O
1,244.20 Pa
200 inH2O
49.77 kPa
300 inH2O
74.65 kPa
DLC-L10D
± 10 inH2O
2,488.40 Pa
200 inH2O
49.77 kPa
300 inH2O
74.65 kPa
DLC-L20D
± 20 inH2O
4,976.80 Pa
200 inH2O
49.77 kPa
500 inH2O 124.42 kPa
DLC-L30D
± 30 inH2O
7,465.20 Pa
200 inH2O
49.77 kPa
DLC-L60D
± 60 inH2O
14,930.4 Pa
200 inH2O
49.77 kPa
800 inH2O 199.01 kPa
DLC-L01G
0 to 1 inH2O
248.84 Pa
100 inH2O
24.88 kPa
300 inH2O
74.65 kPa
DLC-L02G
0 to 2 inH2O
497.68 Pa
100 inH2O
24.88 kPa
300 inH2O
74.65 kPa
DLC-L05G
0 to 5 inH2O
1,244.20 Pa
200 inH2O
49.77 kPa
300 inH2O
74.65 kPa
DLC-L10G
0 to 10 inH2O
2,488.40 Pa
200 inH2O
49.77 kPa
300 inH2O
74.65 kPa
DLC-L20G
0 to 20 inH2O
4,976.80 Pa
200 inH2O
49.77 kPa
DLC-L30G
0 to 30 inH2O
7,465.20 Pa
200 inH2O
49.77 kPa
DLC-L60G
0 to 60 inH2O
14,930.4 Pa
200 inH2O
49.77 kPa
High Pressure Products
Device
Operating Range A
Proof Pressure
Burst Pressure
DLC-005D
± 5 psi
34.47 kPa
10 psi
68.95 kPa
15 psi
103.42 kPa
DLC-015D
± 15 psi
103.42 kPa
30 psi
206.84 kPa
45 psi
310.26 kPa
DLC-030D
± 30 psi
206.84 kPa
60 psi
413.69 kPa
90 psi
620.53 kPa
DLC-100D
± 100 psi
689.48 kPa
200 psi
1,378.95 kPa
225 psi
1,551.32 kPa
DLC-150D
± 150 psi
1,034.20 kPa
225 psi
1,551.32 kPa
225 psi
1,551.32 kPa
DLC-005G
0 to 5 psi
34.47 kPa
10 psi
68.95 kPa
15 psi
103.42 kPa
DLC-015G
0 to 15 psi
103.42 kPa
30 psi
206.84 kPa
45 psi
310.26 kPa
DLC-030G
0 to 30 psi
206.84 kPa
60 psi
413.69 kPa
90 psi
620.53 kPa
DLC-100G
0 to 100 psi
689.48 kPa
200 psi
1,378.95 kPa
225 psi
1,551.32 kPa
DLC-150G
0 to 150 psi
1,034.20 kPa
225 psi
1,551.32 kPa
225 psi
1,551.32 kPa
DLC-015A
0 to 15 psia
1.03 barA
30 psi
2.06 barA
45 psi
3.10 barA
DLC-030A
0 to 30 psia
2.06 barA
60 psi
4.14 barA
90 psi
6.20 barA
DLC-100A
0 to 100 psia
6.89 barA
200 psi
13.79 barA
225 psi
15.51 barA
DLC-150A
0 to 150 psia
10.34 barA
225 psi
15.51 barA
225 psi
15.51 barA
Note A: Operating range in Pa is expressed as an approximate value.
DLC — Compact High Resolution Pressure Sensors
Table of Contents
Page 3
Performance Characteristics for DLC Series
All parameters are measured at 3.3V ±5% excitation and 25C unless otherwise specified (Note 6). Pressure measurements are with positive
pressure applied to PORT B.
Output Span (FSS)
LxxD (All Packages)
±0.4 * 224
Dec Counts
LxxG (U2 Package)
0.4 * 224
Dec Counts
LxxG (All Other Packages)
0.8 * 224
Dec Counts
0xxD (All Packages)
Dec Counts
24
24
±0.4 * 2
0xxG (All Packages)
0.8 * 2
Dec Counts
0xxA (U5 Package)
0.8 * 224
Dec Counts
Specification
Notes
1
Offset Output @ Zero Diff. Pressure (Osdig)
24
LxxD (All Packages)
0.5 * 2
Dec Counts
LxxG (U2 Package)
0.5 * 224
Dec Counts
24
Dec Counts
24
Dec Counts
24
Dec Counts
24
0.1 * 2
0xxD (All Packages)
0.5 * 2
0xxG (All Packages)
0.1 * 2
0xxA (U5 Package)
0.1 * 2
Dec Counts
±3.00
±2.00
±1.25
±1.00
±1.00
%FSS
%FSS
%FSS
%FSS
%FSS
15.3
15.5
bit
Temperature Output
Resolution
Overall Accuracy
16
2
bit
°C
Supply Current Requirement
During Active State (ICCActive)
During Idle State (ICCIdle)
2.0
100
2.5
250
mA
nA
Power On Delay
2.5
ms
3
ms
3, 4
Total Error Band
L01G
L01D, L02G
L02D, L05G, L05D, L10G, L10D, L20G
L20D, L30G, L30D, L60G, L60D
All Higher Pressure
2
Pressure Digital Resolution - No Missing Codes
16-bit Option
3, 4, 5
Data Update time (tDU)
Calibrated
Resolution
16 bit
(see table below)
Single
Typ
3.70
Max
4.1
Average2
Typ
Max
7.20
8.0
Measurement Command
Average4
Average8
Typ
Max
Typ
Max
14.20
15.7
28.20
31.1
Average16
Typ
Max
56.20
61.9
Units
ms
1) Solder parts as a second operation only.
2) Post reflow, wait for 48 hrs before performing any calibration operations.
3) Perform spot cleaning as necessary only by hand. DO NOT wash or submerge device in cleaning liquid.
All Sensors
Table of Contents
DS-0365 Rev A
Page 4
all sensors
Units
Maximum
f 408 225 2079
Typical
p 408 225 4314
Minimum
Parameter
I2C Electrical Parameters for DLC Series
Parameter
Symbol Min Typ Max Units Notes
Input High Level
80.0
100
% of Vs
5
Input Low Level
% of Vs
5
Output Low Level
10.0
% of Vs
5
I2C Pull-up Resistor
1000
I2C Load Capacitance on SDA, @ 400 kHz CSDA
I2C Input Capacitance (each pin)
Ω 5
- - 200 pF 5
CI2C_IN - - 10.0 pF 5
I2C Address
41
decimal
Pressure Output Transfer Function
𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑑𝑑𝑑𝑑𝑑𝑑 − 𝑂𝑂𝑂𝑂𝑑𝑑𝑑𝑑𝑑𝑑
𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂) = 1.25 × �
� × 𝐹𝐹𝐹𝐹𝐹𝐹(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂)
224
Where:
𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑃𝑑𝑑𝑑𝑑𝑑𝑑
Is the sensor 24-bit digital output.
𝑂𝑂𝑂𝑂𝑑𝑑𝑑𝑑𝑑𝑑
Is the specified digital offset output.
(see Performance Characteristics Table)
𝐹𝐹𝐹𝐹𝐹𝐹(𝑖𝑖𝑖𝑖𝐻𝐻2 𝑂𝑂)
The sensor Full Scale Span in inches H2O
For Gage Operating Range sensors: Full Scale Pressure
For Differential Operating Range sensors: 2 x Full Scale Pressure.
Temperature Output Transfer Function
𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇 (℃) = �
Where:
𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑑𝑑𝑑𝑑𝑑𝑑
𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑇𝑑𝑑𝑑𝑑𝑑𝑑 ∗ 150
� − 40
224
The sensor 24-bit digital temperature output.
(Note that only the upper 16 bits are significant)
Specification Notes
note
1: THE SPAN IS THE ALGEBRAIC DIFFERENCE BETWEEN FULL SCALE DECIMAL COUNTS AND THE OFFSET DECIMAL COUNTS. THE FULL SCALE PRESSURE IS THE
note
2: TOTAL ERROR BAND CONSISTS OF OFFSET AND SPAN TEMPERATURE AND CALIBRATION ERRORS, LINEARITY AND PRESSURE HYSTERESIS ERRORS, OFFSET
note
3: PARAMETER IS CHARACTERIZED AND NOT 100% TESTED.
note
4: DATA UPDATE TIME IS EXCLUSIVE OF COMMUNICATIONS, FROM COMMAND RECEIVED TO END OF BUSY STATUS. THIS CAN BE OBSERVED AS EOC PIN
note
5: AVERAGE CURRENT CAN BE ESTIMATED AS : ICCIdle + ((tDU / Reading Interval) * ICCActive)). REFER TO FIGURE 2 FOR ACTIVE AND IDLE CONDITIONS OF THE
note
6: THE SENSOR IS CALIBRATED WITH A 3.3V SUPPLY HOWEVER, AN INTERNAL REGULATOR ALLOWS A SUPPLY VOLTAGE OF 1.8V TO 3.6V TO BE USED WITH-
MAXIMUM POSITIVE CALIBRATED PRESSURE.
WARM-UP SHIFT AND OFFSET POSITION SENSITIVITY ERRORS.
LOW- STATE DURATION.
SENSOR (THE ACTIVE STATE IS WHILE EOC PIN IS LOW).
OUT AFFECTING THE OVERALL SPECIFICATIONS. THIS ALLOWS DIRECT OPERATION FROM A BATTERY SUPPLY.
Note 7: CALIBRATED WITH CONTINOUS READS.
Table of Contents
Page 5
Device Ordering Options
Operation Overview
The DLC is a digital sensor with a signal path that includes a sensing element, a variable- bit analog to digital converter, a DSP and an IO block that supports an I2C interface (see Figure 1 below). The sensor also includes an internal
temperature reference and associated control logic to support the configured operating mode. Since there is a single
ADC, there is also a multiplexer at the front end of the ADC that selects the signal source for the ADC.
Sensor Commands: Five Measurement commands are supported, returning values of either a single pressure /
temperature reading or an average of 2, 4, 8, or 16 readings. Each of these commands wakes the sensor from Idle state
into Active state, and starts a measurement cycle. For the Start-Average commands, this cycle is repeated the
appropriate numper of times, while the Start-Single command performs a single iteration. When the DSP has
completed calculations and the new values have been made available to the I/O block, the sensor returns to Idle state.
The sensor remains in this low-power state until another Measurement command is received.
After completion of the measurement, the result may then be read using the Data Read command. The ADC and DSP
remain in Idle state, and the I/O block returns the 7 bytes of status and measurement data. See Figure 2, following. At
any time, the host may request current device status with the Status Read command.
See Table 1 for a summary of all commands.
For optimum sensor performance, All Sensors recommends that Measurement commands be issued at a fixed interval
by the host system. Irregular request intervals may increase overall noise on the output.
Furthermore, if reading intervals are much slower than the Device Update Time, using the Averaging commands is
suggested to reduce offset shift. This shift is constant with respect to time interval, and may be removed by the application. For longer fixed reading intervals, this shift may be removed by the factory on special request.
All Sensors
Table of Contents
DS-0365 Rev A
Page 6
p 408 225 4314
The DSP receives the converted pressure and temperature information and applies a multi-order transfer function to
compensate the pressure output. This transfer function includes compensation for span, offset, temperature effects on
span, temperature effects on offset and second order temperature effects on both span and offset. There is also
linearity compensation for gage devices and front to back linearity compensation for differential devices.
The ADC performs conversions on the raw sensor signal (P), the temperature reference (T) and a zero reference (Z)
during the ADC measurement cycle.
f 408 225 2079
Figure 1 - DLC Essential Model
all sensors
Output Resolution
Calibrated output resolution of 16 bits.
See the Data Update Time in the Performance Characteristics table.
Operation Overview
Figure 2 - DLC Communication Model
Start-Single Command
Command
Start-Single
Internal State
Idle
Interal Operation
Idle
Data Read
Active
ADC (Temp, Zero, Pressure)
Start-Single
Active
Idle
DSP
Idle
Idle
Idle
DSP
New Data Available
EOC
Start-Average2 / 4 / 8 / 16 Commands (Auto Averaging)
Command
Data Read
Start-Average2/4/8/16
Internal State
Idle
Interal Operation
Idle
Active
ADC (Temp, Zero, Pressure)1
ADC (Temp, Zero, Pressure)n
DSP
Idle
Active
Idle
ADC (T, Z, P)…
New Data Available
EOC
Digital Interface Command Formats
When requesting sensor status over I2C, the host simply performs a 1-byte read transfer.
When reading sensor data over I2C, the host simply performs a 7-byte read transfer.
See Table 1 below for Measurement Commands, Sensor Data read and Sensor Status read details.
Table 1 - DLC Sensor Command Set
Description
I2C
Start-Single
Start-Average2
0xAA
Start-Average4
0xAD
Start-Average8
0xAE
Start-Average16
0xAF
0xAC
Read Sensor Data
I2C Read of 7 bytes from device
Read Sensor Status
I2C Read of 1 byte from device.
Table of Contents
Page 7
Digital Interface Data Format
all sensors
For either type of digital interface, the format of data returned from the sensor is the same. The first byte consists of the
Status Byte followed by a 24-bit unsigned pressure value and a 24-bit unsigned temperature value. Unused bits
beyond the calibrated bit width are undefined, and may have any value. See the Pressure Output Transfer Function
and Temperature Output Transfer Function definitions on page 3 for converting to pressure and temperature.
Refer to Table 2 for the overall data format of the sensor. Table 3 shows the Status Byte definition.
Note that a completed reading without error will return status 0x40.
Table 2 - Output Data Format
S[7:0]
Status
Byte
P[23:16]
Pressure
MSB
P[15:8]
Pressure
Byte 1
P[7:0]
Pressure
LSB
T[23:16]
Temperature
MSB
T[15:8]
Temperature
Byte 1
T[7:0]
Temperature
LSB
Table 3- Status Byte Definition
I2C Interface
I2C Command Sequence
The part enters Idle state after power-up, and waits for a command from the bus master. Any of the five
Measurement commands may be sent, as shown in Table 1. Following receipt of one of these commands,
the EOC pin is set to Low level, and the sensor Busy bit is set in the Status Byte. After completion of measurement
and calculation in the Active state, compensated data is written to the output registers, the EOC pin is set high,
and the processing core goes back to Idle state. The host processor can then perform the Data Read operation,
which for I2C is simply a 7-byte Device Read.
If the EOC pin is not monitored, the host can poll the Status Byte by repeating the Status Read command, which
for I2C is a one-byte Device Read. When the Busy bit in the Status byte is zero, this indicate that valid data is
ready, and a full Data Read of all 7 bytes may be performed.
All Sensors
Table of Contents
DS-0365 Rev A
Page 8
p 408 225 4314
f 408 225 2079
Description
[Always = 0]
Power : [1 = Power On]
Busy: [ 1 = Processing Command, 0 = Ready]
Mode: [00 = Normal Operation ]
Memory Error [ 1 = EEPROM Checksum Fail]
Sensor Configuration [ always = 0]
ALU Error [1 = Error]
Bit
Bit 7 [MSB]
6
5
4:3
2
1
Bit 0 [LSB]
I2C Interface (Cont’d)
I2C Bus Communications Overview
The I2C interface uses a set of signal sequences for communication. The following is a description of the supported sequences and their associated mnemonics. Refer to Figure 3 for the associated usage of the following
signal sequences.
Bus not Busy (I): During idle periods both data line (SDA) and clock line (SCL) remain HIGH.
START condition (ST): A HIGH to LOW transition of SDA line while the clock (SCL) is HIGH is interpreted as
START condition. START conditions are always set by the master. Each initial request for a pressure value has to
begin with a START condition.
Slave address (An): The I²C-bus requires a unique address for each device. The DLC sensor has a preconfigured
slave address (see specification table on Page 3). After setting a START condition the master sends the address
byte containing the 7 bit sensor address followed by a data direction bit (R/W). A “0” indicates a transmission
from master to slave (WRITE), a “1” indicates a device-to master request (READ).
Acknowledge (A or N): Data is transferred in units of 8 bits (1 byte) at a time, MSB first. Each data-receiving
device, whether master or slave, is required to pull the data line LOW to acknowledge receipt of the data. The
Master must generate an extra clock pulse for this purpose. If the receiver does not pull the data line down, a
NACK condition exists, and the slave transmitter becomes inactive. The master determines whether to send
the last command again or to set the STOP condition, ending the transfer.
DATA valid (Dn): State of data line represents valid data when, after a START condition, data line is stable for
duration of HIGH period of clock signal. Data on line must be changed during LOW period of clock signal.
There is one clock pulse per data bit.
STOP condition (P): LOW to HIGH transition of the SDA line while clock (SCL) is HIGH indicates a STOP condition. STOP conditions are always generated by the master.
Figure 3 - I2C Communication Diagram
1. Measurement Commands: Start-Single ( to start reading of single sample):
Start-Single
C7…C0: 0xAA
Start-Average2
C7…C0: 0xAC
Start-Average4
C7…C0: 0xAD
Start-Average8
C7…C0: 0xAE
Start-Average16
C7…C0: 0xAF
Set by bus master:
Set by sensor:
I
ST A6 A5 A4 A3 A2 A1 A0 W
I
ST A6 A5 A4 A3 A2 A1 A0 R
I
A
C7 …
C0
N
SP
I
SP
I
2. Status Read:
Set by bus master:
Set by sensor:
A S7 … S0
N
3. Data Read:
Set by bus master:
Set by sensor:
Bus states:
Idle:
Start:
Stop:
Ack:
Nack:
“Read” bit (1):
“Write” bit (0):
I
ST
SP
A
N
R
W
Sensor Address:
A6 … A0
Default: 0x78
A S7 … S0
A
A
P23 … P16
A
P15 … P8
A
P7 … P0
A
T23 … T16
A
T15 … T8
N SP
I
T7 … T0
Data bits:
Status:
Pressure data:
Temperature data:
S7 … S0
P23 … P0
T23 … T0
Command Bits:
C7 … C0
Table of Contents
Page 9
Interface Timing Diagram
Figure 4 - I2C Timing Diagram
tH STA
tHIGH
tLOW
all sensors
SCL
SDA
MIN
100
1.3
0.6
0.6
0.6
0.1
2.0
tSUS TP
TYP
tIDLE
MAX
400
UNITS
KHz
us
us
us
us
us
us
us
us
SYMBOL
fSCL
tLOW
tHIGH
tSUSTA
tHSTA
tSUDAT
tHDAT
tSUSTP
tIDLE
tH DAT
p 408 225 4314
PARAMETER
SCL frequency
SCL low width
SCL high width
Start condition setup
Start condition hold
Data setup to clock
Data hold to clock
Stop condition setup
Bus idle time
tSUDAT
f 408 225 2079
tSUS TA
All Sensors
Table of Contents
DS-0365 Rev A
Page 10
How to Order
Refer to Table 5 for standard part numbers offered which includes the pressure range and package.
Example P/N with options: DLC-L05D-D4
Table 4 - Part Numbering Scheme:
DLC - L05 D - D4
Package:
Output Mode:
Output Mode
D — Differential
Dependent
G — Gage
A — Absolute
Package Dependent
Product
Pressure
Series Code Range
Where:
Pressure Range (D1, D3, D4 Package): All Differential Pressure Ranges
Pressure Range (U1, U2 Package): All Gage Pressure Ranges
Pressure Range (U5 Package): All Absolute Pressure Ranges
Low Pressure
Products
DLC
DLC
DLC
DLC
DLC
DLC
DLC
L01
L02
L05
L10
L20
L30
L60
D
D
D
D
D
D
D
D1
D1
D1
D1
D1
D1
D1
DLC
DLC
DLC
DLC
DLC
DLC
DLC
L01
L02
L05
L10
L20
L30
L60
D
D
D
D
D
D
D
D3
D3
D3
D3
D3
D3
D3
DLC
DLC
DLC
DLC
DLC
DLC
DLC
L01
L02
L05
L10
L20
L30
L60
D
D
D
D
D
D
D
D4
D4
D4
D4
D4
D4
D4
High
Pressure
Products
DLC
DLC
DLC
DLC
DLC
005
015
030
100
150
D
D
D
D
D
D1
D1
D1
D1
D1
DLC
DLC
DLC
DLC
DLC
005
015
030
100
150
D
D
D
D
D
D3
D3
D3
D3
D3
DLC
DLC
DLC
DLC
DLC
005
015
030
100
150
D
D
D
D
D
D4
D4
D4
D4
D4
Low Pressure
Products
DLC
DLC
DLC
DLC
DLC
DLC
DLC
L01
L02
L05
L10
L20
L30
L60
G
G
G
G
G
G
G
U1
U1
U1
U1
U1
U1
U1
DLC
DLC
DLC
DLC
DLC
DLC
DLC
L01
L02
L05
L10
L20
L30
L60
G
G
G
G
G
G
G
U2
U2
U2
U2
U2
U2
U2
High
Pressure
Products
U Packages
D Packages
Table 5 - Standard Part Number Configurations
DLC
DLC
DLC
DLC
DLC
005
015
030
100
150
G
G
G
G
G
U1
U1
U1
U1
U1
DLC
DLC
DLC
DLC
DLC
005
015
030
100
150
G
G
G
G
G
U2
U2
U2
U2
U2
DLC
DLC
DLC
DLC
015
030
100
150
A
A
A
A
U5
U5
U5
U5
Table of Contents
Page 11
Product Identification on backside of device
All products are labeled via laser marking as seen in Figure 5.
Figure 6 details how to interpret the part marking code. Low pressure ranges from 1 to 60 inH2O are specified with
code “L” and 5 to 150 psi high pressure products with code “H”.
all sensors
The pressure range will be indicated on the same line as the wafer number before the starting character “B”.
Example: DLC-L05D-D4
Pressure Range Identifier
5 i nH2O
10 i nH2O
20 i nH2O
30 i nH2O
Company
Part Marking
2 i nH2O
All Sensors
DLC-L-D4
5-B12399-09
R16A24-14
Wafer Number
Lot Number
f 408 225 2079
1 i nH2O
DLC - L - D4
Figure 6: Part Marking
Series
Op�on
Pressure Range
Identifier Option
1
Pressure Type
Identifier Option
L
2
5
10
60
5
15
30
100
150
L
L
L
L
L
L
H
H
H
H
H
All Sensors
Table of Contents
Pressure Type Identifier
Pressure Range
1 inH2O
2 inH2O
5 inH2O
10 inH2O
20 inH2O
30 inH2O
60 inH2O
5 PSI
15 PSI
30 PSI
100 PSI
150 PSI
p 408 225 4314
DLC
Package
Op�on Descrip�on
U1
DIP, Single Top Port, Gage pressure
U2
SMT, Single Top Port, Gage pressure
U5
D1
SMT, No Port, Absolute pressure
Jogged SMT Leads, Dual Port, Same Side, Differen�al pressure
D3
SML Leads, Dual Port, Opposite Side, Differen�al pressure
D4
SOIC, Differen�al pressure
DS-0365 Rev A
Page 12
Figure 5: Product Labeling
n Des cri p on
Package Drawings
D1 Package
Pin
.551 14
.512 13
3 21
.572 14.5
4 56
.374 9.5
.066 1.7
.088 2.2
.045 1.1
.381 9.7
Definition
1
N/C
2
SCL
3
SDA
4
EOC
5
VDD
6
VSS
.040 [1] TYP
Port B
.145 3.7
.217 5.5
.100 2.6
.062 1.6
.100 2.5 TYP
Port A
.018 0.5 TYP
.528 13.4
.157 4
.200 5.1
All Sensors
TITLE:
NOTES
1) Dimensions are in inches [mm].
2) For suggested pad layout, see drawing: PAD-20.
SIZE
A
D-Series Package
FILE NAME
D1 Package
D3 Package
Pin
.640 16.25
.320 8.125
.581 14.75
.512 13
.216 5.50
.364 9.25
.581 14.75
Port B
12 345 6
.226 5.74
.100 2.54 TYP
.255 6.48
.446 11.32
.025 0.64
SQUARE TYP
Port A
Definition
1
N/C
2
SCL
3
SDA
4
EOC
5
VDD
6
VSS
.220 5.59
.500 12.7
2X
.118 3
.062 1.57
.256 6.5
.059 1.5
All Sensors
TITLE:
NOTES
2) For suggested pad layout, see drawing: PAD-21.
SIZE
A
D-Series Package
FILE NAME
D3 Package
Table of Contents
Page 13
Package Drawings (Cont’d)
D4 Package
13
8
VDDB
.350 8.9
.209 5.3
SCL
5
4
SDA
6
EOC
16
10
.039 1
PIN 1
16
.016 0.4 TYP
.118 3
.098 2.5
.296 7.5
.197 5
.008 0.2
Gnd
.087 2.2
.142 3.6
.032 0.8
.407 10.3
Pin
Definition
1
INP
2
N/C
3
VSSB
4
SDA
5
SCL
6
EOC
7
N/C
8
N/C
9
N/C
10
VSS
11
VDD
12
N/C
13
VDDB
14
INN
15
N/C
16
VDDB
.093 2.4
All Sensors
TITLE:
SIZE
A
D-Series Package
FILE NAME
D4 Package
p 408 225 4314
NOTES
2) For suggested pad layout, see drawing: PAD-22
3) Sensors in this package require handling in accordance with MSL3.
4) Do not connect any signal to Pins 1, 3 & 14.
5) PCB must connect Pin 13 to Pin 16.
all sensors
9
Vs
11
.102 2.6
.050 1.3 TYP
f 408 225 2079
.104 2.6
All Sensors
Table of Contents
DS-0365 Rev A
Page 14
U1 Package
Pin
.335 8.5
3
2
1
4
5
6
.335 8.5
.118 3
Definition
1
N/C
2
SCL
3
SDA
4
EOC
5
VDD
6
VSS
.039 1
.236 6
Port B
.008 0.2
TYP
.122 3.1
2-5
.020 0.5 TYP
.100 2.5 TYP
.378 9.6
.200 5.1
All Sensors
TITLE:
NOTES
2) For suggested pad layout, see drawing: PAD-23.
SIZE
A
U-Series Package
FILE NAME
U1 Package
U2 Package
1 2 3
.043 1.1
.276 7
Pin
.024 0.6
.406 10.3
.024 0.6
6 5 4
Port B
.276 7
.118 3
.100 2.5 TYP
.031 0.8 TYP
Definition
1
N/C
2
SCL
3
SDA
4
EOC
5
VDD
6
VSS
.200 5.1
.020 0.5
.236 6
.010 0.3
.010 0.3
.138 3.5
All Sensors
TITLE:
NOTES
2) For suggested pad layout, see drawing: PAD-24.
SIZE
A
U-Series Package
FILE NAME
U2 Package
Table of Contents
Page 15
Pin
7
.276
0.8
.031
TYP
10.3
.406
Definition
1
N/C
2
SCL
3
SDA
4
EOC
5
VDD
6
VSS
3.5
.138
0.25
.010
0.25
.010
0.5
.020
5.8
.228
All Sensors
5.8
.228
NOTES
3) Absolute pressure only.
TITLE:
SIZE
A
all sensors
7
.276
U-Series Package
FILE NAME
U5 Package
Packing Options
p 408 225 4314
TUBE
f 408 225 2079
2.54
.100
TYP
U5 Package
ALL PRODUCTS FOUND IN THIS
DATASHEET ARE PACKAGED IN
TUBES.
(Consult with factory for the option to ship in trays)
All Sensors
Table of Contents
DS-0365 Rev A
Page 16
Tubing Number
1
2
Recommended Tubing Sizes
1/16" I.D. x 1/8" O.D. x 1/32" Wall
3/32" I.D. x 5/32" O.D. x 1/32" Wall
Package
D1
D3
D4
U1
U2
U5
Tubing Number
1
2
2
2
2
N/A
[1.0]
0.100 (Typ)
[2.54]
0.10 [2.54]
0.37
[ 9.4]
0.551
[14.0]
0.040 [1.0]
(Typ)
0.079
[ 2.0]
0.05 [ 1.27] ( TYP)
[2.4]
0.094
0.039
0.024
[ 0.6]
0.100 [2.54]
PAD-21
PAD-20
PAD-22
0.1 [2.54]
0.1 [2.54]
0.1
[2.54]
0.127
[3.23]
0.06
[1.5]
0.127 [3.23]
0.4
[10.2]
0.4
[10.2]
0.032 [0.8]
0.127 [3.23]
0.039 [1.0]
0.047 [1.2]
diam, 2 plcs
0.1 [2.54]
0.127 [3.23]
PAD-23
PAD-24
All Sensors reserves the right to make changes to any products herein. All Sensors does not assume any liability arising out of the application or use of any product or circuit
described herein, neither does it convey any license under its patent rights nor the rights of others.
Table of Contents
Page 17
