A100N50X4A
A100N50X4A
    TTM(迅达)
    非标准型SMD
    RF 衰减器 0 Hz ~ 3.5 GHz 50 Ohms 100W 非标准型 SMD
A100N50X4A 数据手册
ROHS Compliant Model A100N50X4A Chip Termination 100 Watts, 50Ω Description The A100N50X4A is high performance Aluminum Nitride (AlN) chip termination intended as an alternative to Beryllium Oxide (BeO). The termination is well suited to all cellular frequency bands such as; AMPS, GSM, DCS, PCS, PHS and UMTS. The high power handling makes the part ideal for terminating circulators and for use in power combiners. The termination is also RoHS compliant! General Specifications  RoHS Compliant Resistive Element Substrate Terminal Finish Thick film AlN Ceramic Matte Tin over Nickel Barrier  100 Watts Operating Temperature -55 to +150C (see de rating chart) Features:  DC – 3.5 GHz  AlN Ceramic Tolerance is 0.010”, unless otherwise specified. Designed to meet of exceed applicable portions of MIL-E-5400. All dimensions in inches. Electrical Specifications  Non-Nichrome Resistive Element Resistance Value: Power: 50 Ohms,  2% 100 Watts  Low VSWR Frequency Range:  100% Tested V.S.W.R.: DC – 3.5 GHz 1.12 : 1 DC – 3.0 GHz 1.22 : 1 DC – 3.5 GHz  Small Size Specification based on unit properly installed using suggested mounting instructions and a 50 ohm nominal impedance. Specifications subject to change . Outline Drawing All dimensions are in inches. (mm) A100N50X4A (097) REV. C Available on Tape and Reel For Pick and Place Manufacturing. USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392 Model A100N50X4A ROHS Compliant Typical Performance: Power De-rating: Tape & Reel Available: Mounting Footprint and Procedure: A100N50X4A (097) REV. C USA/Canada: Toll Free: Europe: (315) 432-8909 (800) 544-2414 +44 2392-232392 Available on Tape and Reel For Pick and Place Manufacturing.
A100N50X4A 价格&库存
很抱歉,暂时无法提供与“A100N50X4A”相匹配的价格&库存,您可以联系我们找货
