APS18A7A032G-6ATM1GWL 数据手册
RoHS Compliant
Serial ATA Flash Drive
SFD18A-M Product Specifications (Toshiba 15nm)
March 9, 2016
Version 1.2
Apacer Technology Inc.
1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C
Tel: +886-2-2267-8000
www.apacer.com
Fax: +886-2-2267-2261
APS18AXAxxxG-XXTM1GXX
Features:
z
Compliance with SATA Revision 3.1
SATA 6.0 Gbps interface
Backward compatible with SATA 1.5 and
3.0 Gbps interfaces
ATA-8 command set
z
z
Capacity
32, 64, 128, 256 GB
z
Supply Voltage
3.3V & 5V
z
Performance*
Interface burst read/write: 600 MB/sec
Sustained read: up to 510 MB/sec
Sustained write: up to 380 MB/sec
Random read 4K: up to 82,000 IOPS
Random write 4K: up to 81,000 IOPS
z
Power Consumption*
Active mode: 655 mA
Idle mode: 75 mA
z
Form Factor
1.8 inch (78.5 x 54 x 5, unit: mm)
z
Flash Management
Built-in hardware ECC
Static/dynamic wear leveling
Flash bad-block management
S.M.A.R.T.
Power failure management
ATA secure erase
TRIM
z
Connector
7-pin SATA male connector
9-pin SATA power connector
z
Shock & Vibration**
Shock: 1,500 G
Vibration: 15 G
z
SATA Power Management Mode
z
NAND Flash Type: MLC
z
Device Sleep Mode (optional)
z
RoHS Compliant
Temperature Range
Operating:
Standard: 0°C to 70°C
Extended: -40°C to 85°C
Storage: -40°C to 100°C
*Varies from capacities. The values addressed here are typical and may vary depending on settings and platforms.
**Non-operating
1
©2016 Apacer Technology Inc.
Rev. 1.2
Table of Contents
1. Product Description .................................................................................................. 3
1.1 Introduction ...................................................................................................................................................3
1.2 Capacity Specifications .................................................................................................................................3
1.3 Performance ...................................................................................................................................................3
1.4 Pin Assignments .............................................................................................................................................4
2. Software Interface ..................................................................................................... 6
2.1 Command Set .................................................................................................................................................6
2.2 S.M.A.R.T. ......................................................................................................................................................6
3. Flash Management .................................................................................................... 8
3.1 Error Correction/Detection ..........................................................................................................................8
3.2 Bad Block Management ................................................................................................................................8
3.3 Wear Leveling ................................................................................................................................................8
3.4 Power Failure Management ..........................................................................................................................8
3.5 ATA Secure Erase..........................................................................................................................................8
3.6 TRIM ..............................................................................................................................................................9
3.7 SATA Power Management ...........................................................................................................................9
4. Reliability Specifications ........................................................................................ 10
4.1 Environmental ............................................................................................................................................. 10
4.2 Mean Time Between Failures (MTBF) ...................................................................................................... 10
4.3 Certification and Compliance ..................................................................................................................... 10
5. Electrical Characteristics ....................................................................................... 11
5.1 Operating Voltage........................................................................................................................................ 11
5.2 Power Consumption .................................................................................................................................... 11
6. Mechanical Specifications ...................................................................................... 12
7. Product Ordering Information ................................................................................ 13
7.1 Product Code Designation........................................................................................................................... 13
7.2 Valid Combinations ..................................................................................................................................... 14
2
Rev. 1.2
1.1 Introduction
Apacer’s SFD18A is a well-balanced solid-state disk (SSD) drive with standard form factor and great
performance. Designed in SATA 6.0 Gbps interface, the SSD is able to deliver exceptional read/write speed,
making it the ideal companion for heavy-loading industrial or server operations. In regard of reliability, the drive
comes with various implementations including powerful hardware ECC engine, power saving modes, wear
leveling, flash block management, S.M.A.R.T., TRIM, and power failure management.
Table 1-1 Capacity Specifications
Capacity
Total Bytes*
Cylinders
Heads
Sectors
Max LBA*
32 GB
32,017,047,552
16,383
16
63
62,533,296
64 GB
64,023,257,088
16,383
16
63
125,045,424
128 GB
128,035,676,160
16,383
16
63
250,069,680
256 GB
256,060,514,304
16,383
16
63
500,118,192
*Display of total bytes varies from file systems.
**Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies.
LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of
the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small
portion of the capacity is reserved for device maintenance usages.
1.3 Performance
Table 1-2 Performance
Capacity
32 GB
64 GB
128 GB
256 GB
Sustained Read (MB/s)
340
375
510
505
Sustained Write (MB/s)
100
85
380
350
Random Read IOPS (4K)
48,000
45,000.
81,000
82,000
Random Write IOPS (4K)
24,000
22,000
81,000
80,000
Performance
Note: Performance varies from flash configurations or host system settings.
IOPS: measured on 8GB span (16777216 sectors Disk Size), 32 Outstanding I/Os (QD=32), Full Random Data pattern,
4KB Align I/Os and test durations 15minutes.
3
Rev. 1.2
1.4 Pin Assignments
Table 1-3 describes SAFD 18P signal segment, and Table1-4, its power segment.
Figure 1-1 Micro-SATA Connectors
Power Segment
Pin P1
Table 1-4 Power Segment
Table 1-3 Signal Segment
Name
Type
S1
GND
S2
RxP
+ Differential Receive Signal
S3
RxN
- Differential Receive Signal
S4
GND
S5
TxN
S6
TxP
S7
GND
Signal Segment
Pin S1
Description
Pin
Type
Signal/Description
P1
V33
3.3 V Power
P2
V33
3.3 V Power
P3
GND
P4
GND
- Differential Transmit Signal
P5
V5
5 V Power
+ Differential Transmit Signal
P6
V5
5 V Power
P7
GND
Reserved
P8
Optional
NC
P9
Optional
NC
4
Rev. 1.2
Figure 1-2 SATA Cable/Connector Connection Diagram
The connector on the left represents the Host with TX/RX differential pairs connected to a cable. The connector
on the right shows the Device with TX/RX differential pairs also connected to the cable. Notice also the ground
path connecting the shielding of the cable to the Cable Receptacle.
5
Rev. 1.2
2.1 Command Set
Table 2-1 summarizes the ATA commands supported by SFD18A.
Table 2-1 Command Set
Code
Command
Code
Command
E5h
Check Power Mode
F6h
Security Disable Password
90h
Execute Diagnostics
F3h
Security Erase Prepare
E7h
Flush Cache
F4h
Security Erase Unit
ECh
Identify Device
F5h
Security Freeze Lock
E3h
Idle
F1h
Security Set Password
E1h
Idle Immediate
F2h
Security Unlock
91h
Initialize Device Parameters
7Xh
Seek
C8h
Read DMA
EFh
Set Features
25h
Read DMA EXT
C6h
Set Multiple Mode
60h
Read FPDMA Queued
E6h
Sleep
47h
Read Log DMA EXT
B0h
S.M.A.R.T.
2Fh
Read Log EXT
E2h
Standby
C4h
Read Multiple
E0h
Standby Immediate
20 or 21h
Read Sector(s)
CAh
Write DMA
40 or 41h
Read Verify Sector(s)
35h
Write DMA EXT
10h
Recalibrate
61h
Write FPDMA Queued
57h
Write Log DMA EXT
3Fh
Write Log EXT
C5h
Write Multiple
30h or 31h
Write Sector(s)
2.2 S.M.A.R.T.
S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring
system that provides indicators of drive health as well as potential disk problems. It serves as a warning for
users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should
allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product
development reference.
Apacer devices use the standard SMART command B0h to read data out from the drive to activate our
S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include
initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours
and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the
host before the device reaches in critical condition.
Note: attribute IDs may vary from product models due to various solution design and supporting capabilities.
6
Rev. 1.2
Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information
of drive status and to predict potential drive failures. Users can take advantage of the following
commands/subcommands to monitor the health of the drive.
Code
D0h
D1h
D2h
D4h
D5h
D6h
D8h
D9h
DAh
Byte
1–2
3
4
5*-11
SMART Subcommand
READ DATA
READ ATTRIBUTE THRESHOLDS
Enable/Disable Attribute Autosave
Execute Off-line Immediate
Read Log (optional)
Write Log (optional)
Enable Operations
Disable operations
Return Status
General SMART attribute structure
Description
ID (Hex)
Status flag
Value
Worst
Raw Data
*Byte 5: LSB
ID (Hex)
9 (0x09)
12 (0x0C)
163 (0xA3)
164 (0xA4)
166 (0xA6)
167 (0xA7)
168 (0xA8)
175 (0xAF)
192 (0xC0)
194 (0xC2)
241 (0xF1)
SMART attribute ID list
Attribute Name
Power-on hours
Power cycle count
Max. erase count
Avg. erase count
Total later bad block count
SSD Protect Mode (vendor specific)
SATA PHY Error Count
Bad Cluster Table Count
Unexpected Power Loss Count
Temperature
Total sectors of write
7
Rev. 1.2
3. Flash Management
SFD18A implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 40
bits error in 1K bytes.
Current production technology is unable to guarantee total reliability of NAND flash memory array. When a
flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or
out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition,
bad blocks may develop during program/erase cycles. When host performs program/erase command on a
block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in
control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce
invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and
error will be corrected by designated algorithms.
3.3 Wear Leveling
Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs,
when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform
overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the
lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will
eventually cause some blocks to age faster than others. This would bring flash storages to their end of service
term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the
wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly
used wear leveling types are Static and Dynamic.
Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption
may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple
write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about
several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve
the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of
transmission.
Note: The controller unit of this product model is designed with a DRAM as a write cache for improved performance and data efficiency.
Though unlikely to happen in most cases, the data cached in the volatile DRAM might be potentially affected if a sudden power loss takes
place before the cached data is flushed into non-volatile NAND flash memory.
ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined
in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all
user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage
media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user
data in the drive and protects it from malicious attack.
8
Rev. 1.2
3.6 TRIM
TRIM is a SATA command that helps improve the read/write performance and efficiency of solid-state drives
(SSD). The command enables the host operating system to inform SSD controller which blocks contain invalid
data, mostly because of the erase commands from host. The invalid will be discarded permanently and the
SSD will retain more space for itself.
By complying with SATA 6.0 Gb/s specifications, the SSD supports the following SATA power saving modes:
y
ACTIVE: PHY ready, full power, Tx & Rx operational
y
PARTIAL: Reduces power, resumes in under 10 μs (microseconds)
y
SLUMBER: Reduces power, resumes in under 10 ms (milliseconds)
y
HIPM: Host-Initiated Power Management
y
DIPM: Device-Initiated Power Management
y
AUTO-SLUMBER: Automatic transition from partial to slumber.
y
Device Sleep (DevSleep or DEVSLP): PHY powered down; power consumption ʀ 5 mW; host assertion
time ʀ 10 ms; exit timeout from this state ʀ 20 ms (unless specified otherwise in SATA Identify Device
Log).
Note:
1. The behaviors of power management features would depend on host/device settings.
2. Device Sleep mode is optional, depending on product ordering selections.
9
Rev. 1.2
4.1 Environmental
SFD18A environmental specifications follow MIL-STD-810F, as indicated in the following table.
Table 4-1 Environmental Specifications
Environment
Temperature
Vibration
Shock
Specifications
0°C to 70°C (Operating); -40°C to 85°C (Extended)
-40°C to 100°C (Non-operating)
Non-operating: Sine wave, 15(G), 10~2000(Hz),
Operating: Random, 7.69(Grms), 20~2000(Hz)
Non-operating: Acceleration, 1,500 G, 0.5 ms
Operating: Peak acceleration, 50 G, 11 ms
Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in
SFD drive. The prediction result for the SFD18A is more than 2,000,000 hours.
Notes about the MTBF:
The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2”
method.
SFD18A complies with the following standards:
z
z
z
z
CE
FCC
RoHS
MIL-STD-810F
10
Rev. 1.2
Table 5-1 lists the supply voltage for SFD18A.
Table 5-1 Operating Voltage
Parameter
Conditions
Supply Voltage
3.3V ± 5%
(3.135-3.465V) / 5V ± 5% (4.75-5.25V)
Table 5-2 lists the power consumption for SFD18A.
Table 5-2 Power Consumption (typical)
Capacity
32 GB
64 GB
128 GB
256 GB
Active (mA)
215
295
280
655
Idle (mA)
60
60
75
75
Mode
Note: Power consumptions may vary depending on settings and platforms.
11
Rev. 1.2
Pin S1
Pin P1
Pin S1
Unit: ੈ
Tolerance: ± 0.2
12
Rev. 1.2
AP S
18A
X
A
x x x G - XX
TM1G
X
X
Volt
Blank: 5V
L: 3.3V
Temperature Range
Blank: Standard
W: Extended Temperature
Flash Type
Version Control
Capacity
032G = 32GB
064G = 64GB
128G = 128GB
256G = 256GB
1.8” Housing Type
Solution Version
1.8 inch Form Factor
Apacer Product Code
13
Rev. 1.2
7.2.1 MLC-3.3V / Operating Temperature (0°C ~ 70°C
Capacity
32GB
64GB
128GB
256GB
No DEVSLP
APS18A7A032G-6ATM1GL
APS18A7A064G-6ATM1GL
APS18A7A128G-6ATM1GL
APS18A7A256G-6ATM1GL
DEVSLP
APS18A7A032G-6BTM1GL
APS18A7A064G-6BTM1GL
APS18A7A128G-6BTM1GL
APS18A7A256G-6BTM1GL
7.2.2 MLC-3.3V / Operating Temperature (-40°C ~ 85°C
Capacity
32GB
64GB
128GB
256GB
No DEVSLP
APS18A7A064G-6ATM1GWL
APS18A7A128G-6ATM1GWL
APS18A7A256G-6ATM1GWL
DEVSLP
APS18A7A032G-6BTM1GWL
APS18A7A064G-6BTM1GWL
APS18A7A128G-6BTM1GWL
APS18A7A256G-6BTM1GWL
7.2.3 MLC-5V / Operating Temperature (0°C ~ 70°C
Capacity
32GB
64GB
128GB
256GB
No DEVSLP
APS18A7A032G-6ATM1G
APS18A7A064G-6ATM1G
APS18A7A128G-6ATM1G
APS18A7A256G-6ATM1G
DEVSLP
APS18A7A032G-6BTM1G
APS18A7A064G-6BTM1G
APS18A7A128G-6BTM1G
APS18A7A256G-6BTM1G
7.2.4 MLC-5V / Operating Temperature (-40°C ~ 85°C
Capacity
32GB
64GB
128GB
256GB
No DEVSLP
DEVSLP
Note: Valid combinations are those products in mass production or will be in mass production. Consult your
Apacer sales representative to confirm availability of valid combinations and to determine availability of new
combinations.
14
Rev. 1.2
Revision History
Revision
Description
Date
1.0
Official release
1/12/2016
1.1
Revised product ordering information due to FW change
2/17/2016
1.2
Added IOPS values
3/9/2016
15
Rev. 1.2
Global Presence
Taiwan (Headquarters)
1F., No.32, Zhongcheng Rd., Tucheng Dist.,
New Taipei City 236, Taiwan R.O.C.
Tel: 886-2-2267-8000
Fax: 886-2-2267-2261
amtsales@apacer.com
U.S.A.
Apacer Memory America, Inc.
46732 Lakeview Blvd., Fremont, CA 94538
Tel: 1-408-518-8699
Fax: 1-510-249-9568
sa@apacerus.com
Japan
Apacer Technology Corp.
5F, Matsura Bldg., Shiba, Minato-Ku
Tokyo, 105-0014, Japan
Tel: 81-3-5419-2668
Fax: 81-3-5419-0018
jpservices@apacer.com
Europe
Apacer Technology B.V.
Science Park Eindhoven 5051 5692 EB Son,
The Netherlands
Tel: 31-40-267-0000
Fax: 31-40-267-0000#6199
sales@apacer.nl
China
Apacer Electronic (Shanghai) Co., Ltd
Room D, 22/FL, No.2, Lane 600, JieyunPlaza,
Tianshan RD, Shanghai, 200051, China
Tel: 86-21-6228-9939
Fax: 86-21-6228-9936
sales@apacer.com.cn
India
Apacer Technologies Pvt Ltd,
th
Unit No.201, “Brigade Corner”, 7 Block Jayanagar,
Yediyur Circle, Bangalore – 560082, India
Tel: 91-80-4152-9061
Fax: 91-80-4170-0215
sales_india@apacer.com
16
Rev. 1.2
