10C
-1
M
Round caps • ergonomic feel
DISTINCTIVE FEATURES
Slightly concave round cap
Ø19.2 mm
h=13.7 mm
Consists of two pieces
Designed for excellent illumination
SWITCH SPECIFICATIONS : see Multimec™ 5 series.
13,7 (0,540)
11,2 (0,441)
5G+10C - SMD
Ø 19,2 (0,754)
Ø2
7,62 (0,300)
14 (0,551)
2,0
(0,8
66)
11,2 (0,441)
5G+10C - TH W/LED
Min 10,16 (0,400)
Max 12,5 (0,492)
13,7 (0,540)
EC
PANEL
PCB SWITCHES
08
0C
Ø 19,2 (0,754)
Ø2
7,62 (0,300)
2,0
(0,8
66)
The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm.
1
MOUNTING
MATERIALS
• Top part of the cap: :
- solid color : ABS UL94HB
- illuminated : polycarbonate UL94HB
• Panel cut-out : Ø19.8 mm
• Switch spacing AxB :
illuminated 30.2 x 30.2 mm
non-illuminated 24 x 24 mm
• Bottom part of the cap : polycarbonate UL94HB
ASSEMBLY
1.
LED PLACEMENT
2.
SMD
14,0 (0,551)
14,0 (0,551)
7,0 (0,276)
1,2 (0,047)
7,62 (0,300)
7,0 (0,276)
2,5 (0,098)
12,5 (0,492)
TH
14,0 (0,551)
10,16 (0,400)
2
Ø
1
14,0 (0,551)
7,0 (0,276)
7,0 (0,276)
7,62 (0,300)
PCB SWITCHES
10C
(0
,0
39
BUILD YOUR PART NUMBER
ILLUMINATED
5G
SERIES
LED
MOUNTING
TH9
through-hole
SH9
surface mount
ACTUATION FORCE
CAP
COLOR TOP
10C
16
02
blue
22
green
29
high intensity
green
42
yellow
PRINT TYPE
frosted
white
R
Reverse print
LMH
Hard paint
laser marked
COLOR BOTTOM
PAINT COLOR
2.0N
61
white
35
3.5N
82
red
65
6.5N
2242
green/yellow
8222
red/green
118
8242
red/yellow
123
16
09
frosted white
black
LEGEND
OK
NON-ILLUMINATED
5G
MOUNTING
SERIES
ACTUATION FORCE
TH9
through-hole
2.0N
SH9
surface mount
35
65
CAP
10C
COLOR TOP
LEGEND
00
blue
118
3.5N
03
grey
123
6.5N
08
red
09
black
36
signal white
COLOR BOTTOM
16
frosted white
OK
LEGEND COLOR
06
white
ABOUT THIS SERIES
Notice : please note that not all combinations of above numbers are available. Contact APEM for more information.
For more information on legends see the next two pages.
3
PANEL
PCB SWITCHES
10C
PCB SWITCHES
Legends
Available for Multimec caps
STANDARD LEGENDS
STANDARD LEGENDS
LEGEND
1DS09_
1FS096R_
000
1
001
001
2
002
002
3
003
003
4
004
004
5
005
005
6
006
006
7
007
007
8
008
008
9
009
009
107
107
019
019
1ZB09D_
1ZB16DLMH_
1ZCS_
1Z_
1ZW_
10Q_
10QM16_
10R_ & 10RF_
10RM16_
054
054
054
059
059
059
123
123
10A_
10C_
10D_
033
133
034
134
135
135
136
123
123
136
123*
136
123
123
123
ON/OFF
017
017
STOP
018
018
031
031
038
038
048
048
105
105
118
118
START
RESET
038
CANCEL
ENTER
ESC
051
ON
116
OFF
117
OK
118*
SET
119
MENU
120
FUNC
121
HOME
122
118
118
118
STANDARD OPTIONS
1
• 1DS: pad printed
• 10A: pad printed / laser marked
• 1FS: reverse printed
• 10C: pad printed / laser marked
• 1ZB: pad printed / laser marked
• 10D: UV printed / laser marked
• 1ZCS: pad printed / *reverse printed / *laser marked
• 10R(F) & 10Q: pad printed / reverse printed
• 1Z & 1ZW: pad printed / laser marked
• 10RM & 10QM: metal symbol
HOW TO ORDER
POSITIONING OF LEGENDS ON ROCKER-ACTION CAPS
LEGEND ILLUMINATION
• Option 1 - laser marked: In case of laser marked
legends an “LM” is added after the cap colour,
before the legend code. We recommend using
hard paint (additional “H” ) for increased lifetime
of the paint. E.g. 1ZB16DLMH13609
When ordering legends for caps with hinge-type cap retention system, it is important to note the position of the cap.
An extra letter (U, D, R or L) needs to be added to the part
number to refer to the position of the hinges in relation to
the legend. See samples:
• Option 2 - reverse printed: In case of reverse
printed caps an “R” is added after the cap colour,
before the legend code. Especially relevant
when standard legends have both negative and
positive print options. E.g. 1FS096R00009
Rocker-action caps without a lens: 1A, 1B, 1M, 1ZA and 1ZB
ON/OFF
UP
1A09U01706
ON/OFF
RIGHT
1ZB16RLMH11809
OK
ON/OFF
• Option 3 - metal symbol: Only available
ON/OFF
for
10RM
andON/OFF
10QM
(therefore the “M”). E.g.
ON/OFF
ON/OFF
10RM16059
ON/OFF
ON/OFF
ON/OFF ON/OFF
ON/OFF
ON/OFF
3
1
ON/OFF -
4
DOWN
2
1B09D01706
2
4
1
ORIENTATION OF THE SWITCH
LEFT
1ZB09L00106
1
3
3
1
1
3
1
4
4
2
UP
2
4
2
2
1
1
4
3
3
DOWN
STANDARD AND CUSTOM LEGENDS
3
• Standard are only certain legends on certain caps. See the table on the previous page.
• All standard pad-printed legends are white on black caps.
• All standard reverse-printed and laser marked legends are black on frosted white cap.
STANDARD LEGENDS
CAP COLOR
CAP
DIRECTION*
TYPE*
LEGEND
LEGEND COLOR*
1DS
00
Blue
D
Down
UV
UV printed
001
1
00
Blue
1FS
02
Green
U
Up
2
02
Green
Grey
R
Right
Laser marked
on soft paint
002
03
LM
3
03
Grey
Yellow
L
Left
Laser marked
on hard paint
003
04
LMH
etc
04
Yellow
06
White
06
White
08
Red
08
Red
09
Black
09
Black
16
Frosted white
Etc
Etc
R
*Only for hingetype caps
Reverse
printed
*In case of illumination
*In case of reverse printed
the colour of the paint
Notice: The size of the legends listed may not correspond to the actual size.
If you decide to use one of the standard legends without any adjustments (without a new cliché or programming) on another cap than designated in the
table, then there is no cliché or programming cost, for this to apply the cap has to be black and the print white.
For further information on legends please contact your local distributor or MEC.
2
PANEL
PCB SWITCHES
Legends
1B
1DS
1ES/1FS
1GAS/1GCS
1H
36
38
40
42
50
53
57
58
1JS
1KS
1LS
1M
1NS
1PS
1QS
1RS
1SS
1TS/1US/1VS
1WAS/
1WDS/1WPS
1XS
1ZA
1ZB
1ZCS
1Z/1ZW
10A
10C
10R/10RF +
10Q
10D
The RAL Codes mentioned are the codes nearest to the solid colors in the multimec™ range.
3
Metal bordeaux /
No ral code
1A
Metal dark grey /
No ral code
08
Metal light grey /
No ral code
06
Metal dark blue /
No ral code
04
Aqua blue / 5021
Melon / 1028
03
Dusty blue / 5014
Tele grey / 7046
02
CODE
Noble red / 3002
Mint green / 6029
00
CAP
Signal white / 9003
Ultra blue / 5002
Red / 3000
34
White / 9010
33
Yellow / 1023
32
Grey / 7004
30
green / 6018
09
Blue / 5012
Black / 9004
Available for Multimec™ caps
Colour / RAL
Code
PCB SWITCHES
Solid colors
■ Designed for 5G cap retention system
■ Stackable, giving the possibility to match most overall
heights
■ h =5-10 mm
■ Material: Nylon
Extender for 5G cap range
Range:
Extender
5Grange
cap range
5G + caps
Extender
Extender
for■ Temp.
5Gfor
cap
5G + Extender
2SS 2SS
Multimec™
• Switch: -40/+160°C
• LED: -30/+85°C
• Solid keycap: -40/+65°C
■ Designed
for
5G
cap
retention
system
giving
■ Designed
for
5G
cap
retention
system
• Transparent keycap: -40/+85°C ■ Stackable,
ACCERSSORY
SPECIFICATIONS
All
dimensions
in
mm
Tolerances
-/+0.2mm
Stackable,
giving
the
possibility
to
match
most
overall
heights
■ Stackable,
MATERIAL
PARTS
TEMP. LIMIT UL RATING
heights
h
=5-10
mm
heights
DIMENSIONS
ABS
Solid color 1A, 1B, 1DS, 1ES, 1FS, 1H, 1JS, 1KS, 1LS, 1M, 1NS, 1PS, 1QS, 1RS, 1TS, 1US, 1VS,
Max 65 °C
UL94HB
■ hmm
=5-10 mm 1WAS, 1WDS, 1WPS, 1XS, 1Z, 1ZA,
■ Material:
■ h =5-10
1ZB, 1ZCS,Nylon
1ZW, 10A, 10C, 10Q, 10R, 10RF and AQCS
Max 149 °F
reflectors
1KBS, 1KCS, 1YS and 1YASSMD + 2SS+1DS
2SS■ Material:
SMD
+ 2SS+1GCS
TH + 2SS+1TS
■forTemp.
Range:
■ Material:
Nylon NylonBezels 2C, 2D and 2K,
Polycarbonate
All
lenses
and
transparent
colour
caps,
lids
for
1KBS
1KCS
Max
85
°C
UL94HB
Temp.
Range:
• Switch:
-40/+160°C
■ Temp. Range:
1GCS
Max 185 °F
1GCS
5
mm,
6
mm,
7
mm,
8
mm,
15
-40/+160°C
• LED: -30/+85°C 15
• Switch:• Switch:
-40/+160°C
9 mm, 10 mm
1GAS, 1GCS, 1SS and 2SS
Max 160 °C
UL94V2
• LED: -30/+85°C
• Polyamide
LED: -30/+85°C
Max 320 °F
• Solid keycap:
-40/+65°C
• Legends
Solid keycap:
-40/+65°C
adhesion
DS/EN ISO 2409 Class 1 & ASTM D3359 Class 4B
All dimensions in mm
Tolerances -/+0.2mm
• Transparent
-40/+85°C
• Transparent
keycap:keycap:
-40/+85°C
DIMENSIONS
DIMENSIONS
EXTENDERS
0,3
0,3
14
0,8
7,62
PANEL
PCB SWITCHES
Total height
19,9 - 24,9
5 - 10
Height
5 - 10
5 - 10
Total height
19,9 - 24,9
Height
5 - 10
Total height
19,9 - 24,9
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
Tolerances
Tolerances
-/+0.2mm-/+0.2mm
DIMENSIONS
0,8
Total height
17,5 - 22,5
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
Height
5 - 10
5 - 10
Total height
19,9 - 24,9
Height
5 - 10
All dimensions
All dimensions
in mm in mm
Total height
17,5 - 22,5
Cap & Bezel Specifications
multimec®
multimec®
multimec®
0,3
0,8
7,62
Height
Total height
19,9 - 24,9
Height
5 - 10
Total height
Height
19,9 - 524,9
5 - 10 - 10
Height
Total
height
5 - 10
17,5 - 22,5
Height
Total height
5 - 10
19,9 - 24,9
5 - 10
Height
5 - 10
Total height
17,5 - 22,5
Total height
17,5 - 22,5
Total height
17,5 - 22,5
Total height
19,9 - 24,9
Height
5 - 105 - 10
Ordering example: 5GTH935+1GAS09+2SS09-06.0 OR *5GSH920Q or 5GTH92082Q (quiet 4version)
Please
colour
codes,
of products
and
changes of specifications on www.mec.dk
Ordering
example:
ORsee
*5GSH920Q
or updates
5GTH92082Q
(quiet
version)
or 5GTH92082Q
(quiet
version)
Height
5 - 10
Total height
Total height
0,3
19,9 - 24,9
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 10
0,3
0,3
H1
H2
H1
H3
H1
H2
H3
H2
H3
H1
H2
H3
Height
Total height
5 - 10
19,9 - 24,9
Height
5--10
10height
5Total
17,5 - 22,5
Total height
19,9 - 24,9
Height
0,3
5 - 10
Total height
17,5 - 22,5
Height
Height
5 - 10
5 - 10
Height
Total height
5 - 10
0,3
Total19,9
height
- 24,9
17,5 - 22,5
Height
Total
5 - 10height
17,5 - 22,5
0,3
Total height
17,5 - 22,5
Height
5 - 10
Height
5 - 10
Height
Total 5
height
- 10
17,5 - 22,5
5 - 10
Total height
17,5 - 22,5
Total height
17,5 - 22,5
Height
5 - 10
Total height
Height
17,5 - 522,5
- 10
Height
5 - 10
Total height
19,9 - 24,9
Total height
17,5
- 22,5
Height
5 - 10
0,3
0,3
0,3
Height
5 - 10
Total height
17,5 - 22,5
Height
5 - 105 - 10
0,3
5 - 10
Total height
19,9 - 24,9
19,9 - 24,9
Height
5Total
- 10height
17,5 - 22,5
Height
5 - 10
Min 10,16
1GCS + 2SS+1DS
2SS 14
SMD + 2SS+1GCS
SMD
15Max 12,5
2SS
SMD + 2SS+1GCS
SMD + 2SS+1DS
TH + 2SS+1TS
2SS
SMD + 2SS+1GCS
SMD + 2SS+1DS
TH + 2SS+1TS
1GCS
1GCS
HOW
TO
ORDER
5
mm,
6
mm,
7
mm,
8
mm,
15
5
mm,
6
mm,
1GCS
15
1GCS
1GCS
1GCS
mmmm
, 8 mm,
1GCS
9 mm,715
10
5 mm,
615mm,
7 mm, 8 mm,
15
5 mm, 6 mm,
7 mm,
8 mm,
15
15
9 mm, 10 mmLED (optional)
Cap
Extender 2SS
Switch
Actuation force
mm,
10 mm Mounting
9 mm, 109mm
0,8
height
7,62
14
5 G
2 S S 0 9 . 0
See the table
TH9 through-hole
02 blue
below0,8
0,805.0
SH9 surface mount
35
22 green
7,62
14
0,8
7,62
14
0,8
0,8
06.0
0,8
42 yellow
65
0,8
0,3
7,62
0,3
0,8
0,8
7,62
14
7,62
14
7,62
14
7,62
Min 10,16
14Q*
Min
10,16
07.0
61 white
1GCS
1GCS
7
7,62
Max 12,5
15Max 12,5 15
08.0
82 red
HOW TO ORDER
09.0
2242 green/yellowSMD + 2SS+1DS
HOW
TO ORDER
HOW TO
ORDER
TH+2SS+1TS
2SS
Cap
LED
(optional)
Switch
Mounting
Actuation
force
10.0
8222 red/green
*For an illuminated quiet 2.0N switchActuation
add Q
Cap
Extender
2SS
LED8242
(optional)
Cap
Extender
2SS
LED
(optional)
Switch SwitchMountingMounting
Actuation force 5force
red/yellow
14
G
to the end of the switch part number.
0,8
height
0,8
height
7,62
14
7,62
5
G
14
5 G
See the tab
TH9 through-hole
02 blue
. 0
2 S S 20 S9 S- 0 9 - . 0 below
HOW
TO USE
1GAS/1GCS
+ 2SS
FOIL
CANthe
BE table
USED
WITH
ALL
See the
table
02 blue
TH9
through-hole
surface mount 2SS35
225G-TYPE
green SNAP-ON CAPS
See
02 blue SH9
TH9
through-hole
20UNDER20
How
tosurface
useSH9
1GAS/1GCS
+ 2SS
foil
2SS can
be used
with all 5G-type
snap-on
below
05.0caps
below
05.0
surface mount
42
yellow
65
SH9
mount
35under35
22 green22 green
06.0 the possibility to
All 2SS
06.0
65
Q* extenders are stackable
61
whitegiving
42 yellow42 yellow
A65
match
most
overall
heights.
Foil
All
2SS
extenders
are
stackable
giving
07.0
Q*
82
red 07.0
Q*
61 white 61 white
heights.
08.0
08.0 green/yellow
2242
82 red 82 red
HEIGHT WITH A
ORIGINAL
09.0 SINGLE EXTEN09.0
2242
green/yellow
8222
red/green
2242
green/yellow
CAP
SERIES
add
Q
HEIGHT
(H1)
Cap
Original
with a single extender
DER (H2;H3)
10.0 Height
10.0height
8222
red/green
8242
red/yellow
red/green
to the8222
end of
the
switch
part number.
*For an illuminated
quiet
2.0N
switch
*For an illuminated
quiet 2.0N
switch
add
Q add Q
(H2;H3)
(H1)
1DS/1ES/1FS
14.9
19.9-24.9
8242 red/yellow
8242 red/yellow
to of
thethe
end
of the
switch
part number.
to the end
switch
part
number.
19.9-24.9
14.9 12.5
1DS/1ES/1FS
1GAS/1GCS
17.5-22.5
17.5-22.5
12.5
1GAS/1GCS
24.1; 25.2; 25.1-29.1;
How to use 1GAS/1GCS + 2SS under foil1KS/1KBS/1KCS
2SS
can30.1
be used with all 5G-t
19.1 ; 20.2 ; 20.1
PCB
30.2;
24,1;
25,2;
25,1-29,1; 30,2; 30,1
19.1; 20.2; 20.1
1KS/1KBS/1KCS
How
to use 1GAS/1GCS
+ 2SS
2SSused
can be used5G-type
with all 5G-type
snap-on caps
How to use
1GAS/1GCS
+ 2SS under
foilunder foil
snap-on
caps
A be
Panel 2SS can
19.9-24.9
14.9 14.9
1NSwith all
1NS
19.9-24.9
Foil
All 2SS extenders are stackab
A you toAallocate enough space for travel of the foil and
19.9-24.9
14.9 14.9
1TS/1US/1VS
1TS/1US/1VS
19.9-24.9
recommend
heights.
Foil
All 2SS extenders
are
stackable
giving
the
possibility
to
match
most overall
Foil
•A=We
A=We
recommend
space for travel of
the foil
and leave All 2SS extenders
are stackable giving the possibility to match
most
overall
20.7-25.7
15.7
1WAS/1WDS/1WPS
leave the area free from adhesive
1WAS/1WDS/1WPS
15.7
20.7-25.7
heights.
heights.
the area free from adhesive.
23.5-28.5
18.5 18.5
1XS
H=We recommend you to calculate this dimension from the top of the PCB
1XS
23.5-28.5
Cap
Orig
•toHthe
=We
recommend
youwith
to calculate
this dimension
16.7-21.7
11.7
1ZCS
inner
top of the panel
a small pretention
0.1-0.2mm from Cap
1ZCSOriginal height
16.7-21.7
Cap
Original11.7
height
Height
withextender
a single extender(H1)
Height with
a single
the top of the PCB to the inner top of the panel.
(H1) 13.7(H2;H3) (H2;H3)
10C(H1)
18.7-23.7
14.9
1DS/1ES/1FS
17.0-22.0
14.9 12.019.9-24.919.9-24.9
1DS/1ES/1FS10D14.9
12.5
1GAS/1GCS
1DS/1ES/1FS
PCB
17.5-22.5
12.5
1GAS/1GCS
19.1;
1KS/1KBS/1KCS
17.5-22.5
12.5
1GAS/1GCS
OR *5GSH920Q or 5GTH92082Q (quiet version)
PCB PCB
Panel
24,1;
25,2;
25,1-29,1;
30,2;
30,1
19.1;
20.2;
20.1
1KS/1KBS/1KCS
14.9
1NS
24,1;
25,2;
25,1-29,1;
30,2;
30,1
19.1;
20.2;
20.1
1KS/1KBS/1KCS
Please see colour codes, updates of products and changes of specifications on www.mec.dk
Panel
Panel
19.9-24.9
14.9
1NS
14.9
1TS/1US/1VS
19.9-24.9
14.9
1NS
A=We recommend you to allocate enough space for travel of the foil and
19.9-24.9
14.9
1TS/1US/1VS
15.7
1WAS/1WDS/1WPS
19.9-24.9
14.9
1TS/1US/1VS
thefoil
area
free
A=We recommend
you to enough
allocatespace
enough
for
travel
ofand
the
foilfrom
andadhesive
A=We recommend
you to allocate
forspace
travelleave
of the
20.7-25.7
15.7
1WAS/1WDS/1WPS
18.5
1XS
20.7-25.7
15.7
1WAS/1WDS/1WPS
the area
from adhesive
leave theleave
area free
fromfree
adhesive
23.5-28.5
18.5
1XS
11.7
1ZCS
to
the
inner
top
of
the
panel
with
a
small
pretention
0.1-0.2mm
23.5-28.5
18.5
1XS
H=We recommend
you to calculate
this dimension
of the PCB
H=We recommend
you to calculate
this dimension
from the from
top ofthe
thetop
PCB
16.7-21.7
11.7
1ZCS
to
the
inner
top
of
the
panel
with
a
small
pretention
0.1-0.2mm
16.7-21.7
11.7
1ZCS
to the inner top of the panel with a small pretention 0.1-0.2mm
PCB SWITCHES
Multimec™ caps
HOW TO ORDER
EXTENDERS
SWITCH
5G
5
MOUNTING
ACTUATION FORCE
LED (OPTIONAL)
2SS09-
CAP
See the table on
the previous page
.0
EXTENDER 2SS
HEIGHT
TH9
Through-hole
blue
05
SH9
Surface mount
35
22
green
06
65
42
yellow
07
61
white
08
82
red
09
2242
green/yellow
10
8222
red/green
8242
red/yellow
Multimec™ 5G
M
U
-M
EC
I
LT
PANEL
PCB SWITCHES
EC
8
10
-2
5G
M
High performance tactile switches •
MIL-PRF-28855H • excellent illumination
Large range of accessories
Momentary switches with NO or NC/NO function
Sealed to IP67
Single or bi-color illumination option
Illumination with integrated chip-LEDs
ENVIRONMENTAL SPECIFICATIONS
• Sealing : IP67 according to IEC 60529
• Working and storage temperature :
- non-illuminated: -40 °C/+160 °C (-40 °F to +320 °F)
- illuminated: -30 °C/+85 °C (-22 °F to +185 °F)
• Soldering :
- through-hole : IEC 60068-2-20 8
- surface mount : JEDEC J-STD-020E
ELECTRICAL SPECIFICATIONS
• Recommended load :
- Gold contacts : 0.5µ-50 mA 24 VDC
- Silver contacts : 0.5-50 mA 24 VDC
• Contact resistance : 10 MΩ
• Contact bounce : 10,000,000 cycles
- NC/NO : >1,000,000 cycles
• Actuator : PPS UL94V0
• Sealing : Silicone rubber
• Terminals : SnCu + 2 µNI + 3 µSn100
All tolerance if not otherwise specified ±0.2 mm.
1
RAS
6,4
13,8
12
0,8
0,8 Min 10,16
5,5
Max
12,5
7,62
10
11
14
7,62
0,8
7,62
7,62
7,62
5,08
5G ILLUMINATED
7,62
7,62
4
0,8
• SMD, TH or right angle TH
• NO or NC/NO
Min 10,16
Max 12,5
5,08
0,3
6,4
10
14
12
11
4
0,3
10
13,8
5,5
6,4
6,4
TH
10
SMD
5G NON-ILLUMINATED
4,85
7,62
SMD
TH
8,5
8,5
4:1
0,3
10,0
0,3
14
10,0
Min 10,16
Max 12,5
4:1 5G RAS
• SMD or TH
• NO
• single or bi-color LEDs
0,8
0,8
7,62
7,62
All tolerances unless otherwise noted : ±0.2 mm
PCB LAYOUT & CIRCUIT DIAGRAM
-2
4
3
12,50
2
-2
4
+3
-2
1
4
2,5
+3
1
1
4
+3
2,50
2
1
4
3
3
Ø1,0(3x)
12,50
1,20
1,2
3
+3
Ø 0,9
7,62
-2
7,62
2,5
1
Ø 0,9
12,50
1
1,2
*not for sale in Japan
1
Ø 0,9
2
4
NC/NO function
7,62
5,08
1
7,62
4
RAS
10,16
7,62
10,16
Bicolor - 2 LEDs
10, 16
7,62
2
Single LED
7,62
Non-illuminated
7,62
PCB SWITCHES
Multimec™ 5G
ILLUMINATED
5G
ACTUATION FORCE
MOUNTING
SERIES
LED
OPTIONAL
TH9
Through-hole
2.0 N
02
Blue
SH9
Surface mount
35
3.5 N
22
Green
65
6.5 N
29
High intensity
Green
42
Yellow
61
White
82
Red
2242
Green/yellow
8222
Red/green
8242
Red/yellow
Q
Quiet contact
(with 2.0 N only)
R
Tape & reel
(with SMD only)
G
Gold contacts
NON-ILLUMINATED
5G
MOUNTING
SERIES
OPTIONAL
ACTUATION FORCE
TH9
Through-hole
2.0 N
SH9
Surface mount
35
3.5 N
65
6.5 N
Q
RAS
NCNO
Quiet contact
(with 2.0 N only)
Right angle
(with TH only)
Normally closed/
normally open function
(with 3.5 N only)
R
Tape & reel
(with SMD only)
G
Gold contacts
ABOUT THIS SERIES
Laser marking on the switch for identification : WWYS, WW=week, Y=year, S=suffix for the type of switch, e.g. P=2.0 N and silver
contacts, S=3.5 N and silver contacts, E6.5 N and silver contacts
Caps and accessories : for the full range of accessories for Multimec™ 5G please see the website.
3
PANEL
PCB SWITCHES
Multimec™ 5G
PCB SWITCHES
Multimec™ 5G
TAPE & REEL
Tape and reel is available for the parts listed and has the
following specifications
PART NO.
ORDERING CODE
PITCH
QUANTITY
PER REEL
5GSH9XX
5GSH9XXR
16
500
• Reel diameter: Ø330 mm
5GSH9XX1SSXX-08.0
5GSH9XXR1SSXX-08.0
• Tape width: 24 mm
5GSH9XX1SSXX-09.5
5GSH9XXR1SSXX-09.5
• Pitch: see list
5GSH9XX1SSXX-10.4
5GSH9XXR1SSXX-10.4
5GSH9XX1SSXX-11.0
5GSH9XXR1SSXX-11.0
5GSH9XX1SSXX-12.0
5GSH9XXR1SSXX-12.0
5GSH9XX02
5GSH9XX02R
5GSH9XX22
5GSH9XX22R
5GSH9XX29
5GSH9XX29R
5GSH9XX42
5GSH9XX42R
5GSH9XX61
5GSH9XX61R
• Tape and reel material: antistatic or better
• Quantity per reel: see list
5GSH9XX82
5GSH9XX82R
5GSH9XX2242
5GSH9XX2242R
5GSH9XX8222
5GSH9XX8222R
5GSH9XX8242
5GSH9XX8242R
OPERATING FORCE
2.0 N
10
FORCE
6.5 N
10
FORCE
9
9
8
8
8
7
7
7
6
6
6
5
2N
5
F(N)
9
F(N)
F(N)
10
3.5 N
3,5N
5
4
4
4
3
3
3
2
2
2
1
1
1
TRAVEL
TRAVEL
0,2
0,4
0,6
0,8
1
L(mm)
1,2
1,4
1,6
1,8
2
0,4
0,6
0,8
1
L(mm)
1,2
1,4
1,6
1,8
2
FORCE
6,5N
TRAVEL
0,4
0,6
0,8
1
L(mm)
1,2
1,4
1,6
1,8
2
RECOMMENDED OPERATING CONDITIONS
0,3 [0.012 in] Max.
e tio
ng ec
ra dir
e
l
gl ca
an rti
g (ve
in
an 4°
Le ° ±
90
Plunger
n)
Switch
For the optimal performance of the switch use the recommended operating conditions.
MOUNTING
MOUNTING TOOLS FOR MULTIMEC™ THROUGH-HOLE SWITCHES
Part No. 9861000
1
2
3
4
5
MULTIMEC™ SPACING EXAMPLES
15.4
Min 10.16
Max 12.5
12.7
25.3
Min 10.16
Max 12.5
14.0
1.4
14.0
10.16
15.14
15.4
10.16
10.16
10.16
2.54
10.16 5.24 10.16
5GT+1B+2C/D
12.7
5GS+1B+2C/D
5GT+1M
5GT+1A/H
12.7
1VS+1TS+1VS
5
PANEL
PCB SWITCHES
Multimec™ 5G
MOUNTING (CONTINUED)
Min. 12,7
Min. 12,7
Min. 15,24
Min. 10,3
Min. 10,3
Through-hole (TH)
Min. 10,3
SPACE REQUIREMENT - MATRIX MOUNTING
Min. 10,3
PCB SWITCHES
Multimec™ 5G
Surface mount (SMD)
Min. 15,24
SPACE REQUIREMENT - SWITCH/CAP
Cap dimensions
Switch spacing
Panel cut-out
6
CAP SERIES
RECOMMENDED
MIN.SWITCH SPACING AxB
NOMINAL CAP DIMENSION
WxH
RECOMMENDED
MIN. PANEL CUT-CUT
1A/1H
12.7x10.3
12.6x10.1
13.0x10.5
1B+2C/2D
15.4x15.4
15.1x15.1
15.5x15.5
1DS/1ES/1FS
12.7x11.3
Ø9.6
Ø10.0
1GAS
12.7x11.3
Ø11.0
Ø11.4
1GCS
15.3x15.3
Ø15.0
Ø15.4
1JS
12.7x10.3
Ø10.0
Ø10.4
1KS/1KBS/1KCS
14.6x14.6
14.3x14.3
14.7x14.7
1M
25.3x10.3
25x10
25.7x10.5
1NS
13.6x11.3
Ø9.8/ 14.9
Ø10.2/15.1
1PS/ 1QS/1RS
12.8x10.3
6.5x12.5
7x13, R max. 1.0
1SS/1IS/1LS
12.7x10.3
Ø6.5
Ø7.0
1TS
12.7x12.3
10.6x10.6
11.0x11.0
1US
12.7x12.3
Ø10.6
Ø11.0
1VS
15.95x12.1
10.6x13.25
11.0x13.65
1WAS/1WPS
14.2x10.3
12.5x6.5
12.9x6.9
1WDS
16.9X10.3
15.2x8.0
15.6x8.4
1XS
12.7x10.3
9.4x7.4
9.8x7.9
1ZA
19.0X10.3
18.7x10.1
19.4x10.5
1ZB
24.34x12.1
R1=7.4; R2=17.5 90°
R1=7.1; R2=17.5-17.75 90°
1ZCS
14.6x14.6
Ø14.3
Ø14.7
1Z/1ZW
35.5x35.5; 41.6x41.6
Ø29.5
Ø30.3
Ø19.2
Ø19.8
Ø16.4
10C
22.3x22.3
10D (+10DWY)
19x19 (27x27)
Ø16
10R/10RF/10RM
37.3X37.3
Ø30.0
Ø30.6
10Q/10QM
29.3X29.3
22x22
22.5x22.5
LED COMPONENT SPECIFICATIONS
Color
Blue
Green
Yellow
White
Red
High Intensity Green
Color Codes
02
22
42
61
82
29
ABSOLUTE MAXIMUM RATINGS (Ta= 25°C)
Power
mW
75
75
60
46.5
65
102.5
Current forward
mA
25
15
25
25
Forward peak current
mA
100
80
60
100
100
150
Voltage reverse
V
5
5
5
5
12
5
Operating
temperature
°C
-40/+85
-55/+85
-40/+85
-40/+85
-30/+85
-40/+85
Storage temperature
°C
-40/+90
-55/+85
-40/+90
-40/+85
-40/+85
-40/+85
Soldering temperature
°C
2
3.3
245 for max 10 sec
ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25 °C)
Voltage forward
Typ. V
2.7
Max. V
Current reverse (VR=5V)
Max. µA
Wave length
nm
Spread
nm
1.75**
2.85
3.7
2.4
2.35
3.1
2.5
4.1
50
100
10
10
100
50
468
571
591
NA
633
525
25
NA
15
NA
16
30
120
130
120
150
160
60
Min. mcd
45
18
28.5
56
28
500
Typ. mcd
112*
35
72*
max 450*
max 180*
1000
Lm/w
NA
NA
NA
36
7
NA
Spread angle
degree
Luminous Intensity
Optical intensity
2
*/F=20 mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50 mA, ****Luminous Flux mlm
7
PANEL
PCB SWITCHES
Multimec™ 5G
PCB SWITCHES
Multimec™ 5G
USAGE GUIDELINES
HOW TO GET THE BEST RESULTS WITH
MEC SWITCHES ?
case situation with water jets, complete immersion
into a liquid with a temperature below the board or
surface tension reducing additives.
These guidelines are offered to users of MEC Switches as
an aid to ensure successful and reliable switch operation.
Please see the technical specifications for details on operating and storage temperatures and soldering guidelines
to make sure you select the best switch for your application. When reflow soldering is taking place, MEC strongly
recommend that the temperature profile is analyzed and
compared with the temperature rating of the switch. It is
also important to monitor the accumulated heat buildup
from both the pre-heat zones and the solder zone.
Recommended cleaning methods are demineralized
water. Any surface tension reducing agents, such as
soap, must not be used as they risk causing a potential leakage of the switch.
Most standard accessories for multimec™ 5 series switches are made from ABS plastic with a maximum operating temperature of 65 °C. It is strongly recommended that
accessories are mounted after soldering of the switch. If
this is not possible care must be taken not to overheat the
accessories during the soldering process. The 1SS and
1GAS/1GCS caps are, however, made of high temperature
materials and will meet the same temperature specifications as the switches. For accessories made from other
plastic materials please see multimec™ 5 series cap &
bezel technical specifications.
Wave soldering: heat built up in the switch during
pre-heating and soldering must not exceed the
maximum operating temperature of the switch. Peak
temperature must not exceed 260 °C, and soldering
time is max 10 sec. (IEC 60068-2-20 8)
SOLDERING - THROUGH HOLE
VERSIONS
Hand soldering: max. 350 °C for max. 3 sec
SOLDERING - SURFACE MOUNT
VERSIONS
LEDs have their own temperature specifications. When
fitted in a switch the LED will determine the max. operating
temperature, i.e. 5GTH93522 has an upper temperature
limit of 85 °C!
For all methods - infrared, convection and vapor
phase. The upper limit 240 °C/40 sec must be observed. The soldering temperature profile must have
moderate temperature gradients. (JEDEC J-STD020E)
MOUNTING AND DISMOUNTING
ROHS COMPLIANCE
If switches are to be mounted in rows it is essential that
the recommendations regarding spacing are followed. PC
board thickness should be 1.4 ±0.2 mm and terminal hole
diameter should be 0.9 mm.
As of 1 July 2006 MEC has completed the conversion
to RoHS compliance. For more info please see our
homepage www.apem.com
All multimec™ 5 series caps and bezels are easily snapped
onto the switch modules and can be changed at a later
time.
TEMPERATURE LIMITS:
A mounting tool is available for through hole multimec™ 5
series switches.
SOLDERING AND CLEANING
MULTIMEC™ SERIES
Multimec™ 5 series switches are fully sealed to IP67 specifications to minimize solder flux and aqueous based cleaning solutions from entering the switch and contaminating
the contacts. The switches can be placed on the PC board
with other components and reflow soldered. Multimec™ 5
series offers a high level of sealing, however, with aqueous
solvent solutions care must be taken to avoid the worst
8
Switch
LEDs
Accessories
160 °C
85/90 °C
65/85/160 °C
PACKAGING
Multimec™ 5 series switches are packed in rigid
tubes of 50 pieces each.
A box contains 1.000 pcs.
The surface mount versions of multimec™ 5 series
switches with a height up to 12.5 mm can also be
delivered on tape/reel.
Each reel contains 250/500 pcs.
Right angle switches are packed into trays.
Each tray contains 100 pcs.
