EC
M
PANEL
PCB SWITCHES
10
S/
/1
0U
1
T/
01
21
0V
10S/10T/10U/10V
Many design combinations • floating caps •
low total height
Round caps in two sizes + square cap + triangle cap
h=7.5 mm
Convex top surface
Floating mounting - easy alignment of PCB and front panel
2,60 [0,102]
7,50 [0,295]
DISTINCTIVE FEATURES
Many combination possibilities to customize your panel
0,90 [0,035]
0,90 [0,035]
7,50 [0,295]
6,50 [0,256]
7,50 [0,295]
[0,059]
1,50
[0,512]
13,00
11,50 [0,453]
R3,00 [R0,118]
0,90 [0,035]
1,50 [0,059]
5,00 [0,197]
1,50 [0,059]
7,50 [0,295]
11,50 [0,453]
1,80 [0,071]
1,80 [0,071]
5,00
[0,059]
1,50[0,197]
5,00 [0,197]
5,00 [0,197]
5,00 [0,197]
5,00 [0,197]
2,50 [0,098]
2,50 [0,098]
2,50 [0,098]
0,90 [0,035]
Correction
8,00 [0,315]
Note:Geometry
11,50 [0,453]
Part rev.
Dwg. rev.
Dwg.
Creator
Apprvd.
Edited
Da
4/7
4/7
1,50 [0,059]
5,00 [0,197]
1,50 [0,059]
5,00 [0,197]
2,50 [0,098]
2,50 [0,098]
0,90 [0,035]
Material:
Scale
1:1
Surface finish:
C:\AIS_Workspace\mec\R&D\A. New R&D Structure\Sandbox\ABA\Marketing Drawing to Rika\
Part:
13,00 [0,512] x 3
Drawing to Rika\
Dwg: C:\AIS_Workspace\mec\R&D\A. New R&D Structure\Sandbox\ABA\Marketing
Description:
11,50 [0,453] x 3 Tool no.
10
USTV
Note:Geometry
Note:Geometry
according
according
to 3D
to 3D
CAD
CAD
model.
model.
0,90 [0,035]
11,50 [0,453]
7,50 [0,295]
11,50 [0,453]
7,50 [0,295]
6C+10V - J-BEND
Correction
Correction
0,90 [0,035]
7,50 [0,295]
13,00 [0,512]
[0,295]
7,50
[0,512]
13,00
[R0,118]
[R0,118]
R3,00R3,00
No.
2,50 [0,098]
0,90 [0,035]
8,008,00
[0,315]
[0,315]
11,50 11,50
[0,453][0,453]
6C+10U - J-BEND
No.No.
0,90 [0,035]
6,50 [0,256]
7,50 [0,295]
6,50 [0,256]
7,50 [0,295]
6C+10T - J-BEND
2,60 [0,102]
2,60 [0,102]
7,50 [0,295]
7,50 [0,295]
6C+10S - J-BEND
2,50 [0,098]
2,50 [0,098]
SWITCH SPECIFICATIONS : see Ultramec™ series
MECMEC
ApSApS
Status:
Status:
WorkInProgress
WorkInProgress
Industriparken
Industriparken
23 23
Status:
Status:
WorkInProgress
WorkInProgress
DK-2750
DK-2750
Ballerup
Ballerup
Date
Date Sign.
Sign. Sheet
Sheet
1 / 4
1 / 4 Denmark
Denmark
Tel: Tel:
+45 +45
44 97
4433
9766
33 66
Theoretical
Mass
Mass
Dwg.
Dwg.
4/7/2020
4/7/2020 ABAABA Theoretical
R3,00 [R0,118]
www.apem.com
www.apem.com
Creator
Creator 4/7/2020
4/7/2020 ABAABA
e-mail
e-mail
danmec@mec.dk
danmec@mec.dk
Note:Geom
N/A N/A
No.
Correction
The company reserves the right to change specifications
without
notice.
All tolerance if not otherwise specified ±0.2mm.
Material:
Material:
Scale
Scale
Apprvd.
Apprvd.
Part rev.
1 : 1 : 1 Edited
Dwg. rev.
Edited
Surface
Surface
finish:
finish:
PartPart
rev. rev.
11,50
[0,453]
11,50
[0,453]
Dwg.
Dwg.
rev. rev.
New R&D
New Structure\Sandbox\ABA\Marketing
Drawing
Drawing
to Rika\10S
to Rika\10S
på kontakt.iam
på kontakt.iam
Part:
Part:C:\AIS_Workspace\mec\R&D\A.
13,00 [0,512]
13,00x [0,512]
3
x3
New R&D
Drawing
Drawing
to Rika\10
to Rika\10
- USTV.dwg
- USTV.dwg
18
PCB SWITCHES
10S/10T/10U/10V
low total height
BUILD YOUR PART NUMBER
NON- ILLUMINATED
6C
POLES
MOUNTING
SERIES
J
1
J-bend
single pole
FUNCTION
NO
PACKAGING
POSITIONING PINS*
P
normally open
pins
R
tape & reel
NON- ILLUMINATED
(FOLLOWING)
UV
CAP
COLOR
PRINT TYPE*
PRINT
10S
Ø6.5
00
blue
118
10T
11.5 x 11.5
03
grey
123
10U
Ø11.5
08
red
10V
11.5 x3
09
black
36
signal white
OK
*optional
NOTICE : In case of the standard printed legends the anti-rotation cut-out is placed downwards from the legend.
Please note that the switches and caps are ordered separately.
MOUNTING
• Panel cut-out :
10S: min. Ø6.7 mm
10T: min. 11.7 x 11.7 mm, R 3,2 mm
10U: min. Ø11.7 mm
10V: min. 11.7 mm x3, R 3,2 mm
• Switch spacing AxB :
10S: min. 9.0 x 9.0 mm
10T: min. 14.0 x 14.0 mm
10U: min. 14.0 x 14.0 mm
10V: min. 14.0 x 14.0 mm
19
MATERIALS
• Cap : ABS UL94HB
COLOR
06
white
08
EC
Ultramec™ 6C
M
RA
LT
U
EC
PANEL
PCB SWITCHES
6C
M
High performance tactile switches •
low profile • IP67
Low profile h=2.5 mm
8 x 8 mm
Normally open momentary switch
Sealed to IP67
3,000,000 cycles lifetime
ENVIRONMENTAL SPECIFICATIONS
• Sealing : IP67 according to IEC 60529
• Working and storage temperature :-40 °C/+85 °C (-40 °F to 185°F)
• Soldering : JEDEC J-STD-020E
ELECTRICAL SPECIFICATIONS
• Recommended load : 0.5-50 mA 24 VDC
• Contact resistance : 10 MΩ
• Contact bounce :
