ARFS-3001-05
ARFS-3001-05
    ARAS
    AC/DC CONVERTER 5V 30W
ARFS-3001-05 数据手册
D A T A S H E E T ARFS-3001-XX Switching Power Supply 30 WATT / SINGLE OUTPUT KEY FEATURES: • 30 Watts output Power • 24 and 5 VDC Single Output • Open Frame Package measuring only 2” x 4” x 1.2” • 87% Efficiency typical • High Reliability in excess of 300,0000 Hours • International Safety Approvals • Class B Radiated and Conducted Emissions • 3 Year Warranty Output MODEL Voltage (V) Regulation Maximum Current (A) Ripple/Noise (mVp-p) Standby (Vsb) ARFS-3001-05 +5.0 +/- 2% 6.0 100 N/A ARFS-3001-24 +24.0 +/- 2% 1.25 480 N/A INPUT SPECIFICATIONS PROTECTION Input Voltage 90 – 264 VAC Overvoltage Latch-mode (Cycle AC input) Input Frequency 47 – 63 Hz Overpower Latch-mode (Cycle AC input) Input Current Maximum 1.5A @ 115 VAC Short Circuit Latch-mode (Cycle AC input) Inrush Current max 50A @ 230 VAC Input Protection Fuse Leakage Currrent Maximum 1 mA Power Factor Correction Active PFC to meet or exceed EN610003-2 ENVIRONMENT SPECIFICATIONS Operating Temperature 0 oC to +70 oC Derate linearly above 50 oC to 50% load @ 70 oC Storage Temperature -40 oC to +85 oC Forced Air Cooling 15CFM from AC to DC side MTBF 300 kHrs at 25 oC (Telcordia SR-322) Shock Storage: 30G , 11ms, 1/2 sine wave pulse, 6 axis Operation: 5G , 11ms, 1/2 sine wave pulse, 6 axis Vibration 2G rms, 5Hz to 500kHz, 3 axis OUTPUT SPECIFICATIONS Setpoint Accuracy +/- 1% Total Output Power 30W Hold-up Time 10ms @ 115Vac Efficiency 87% typical Minimum Load No minimum load Isolation (HiPot) 1500 VAC Input to Ground Aras Power Technologies 371 Fairview Way Milpitas, CA 95035 | Phone: (408) 935-8877 | sales@arastech.com 05/15/2014 D A T A S H E E T ARFS-3001-XX COMPLIANCE EMI FCC Class B / EN55022 Class B under all rated input and load conditions Electrostatic Discharge EN61000-4-2: Contact Discharge- Contact discharge in 2kV increments to 6kV for metallic surfaces including connector bodies. 10 discharges pretest point at each voltage: 5 positive polarity and 5 negative polarity. Air discharge – Air discharge in 2kV increments to 8kV for scams and non-metallic user accessible surfaces. 10 discharges pretest point at each voltage: 5 positive polarity and 5 negative polarity. Radiated Susceptibility EN61000-4-3: Electromagnetic Field Strength 3V/m EFT / Bursts EN61000-4-4: Direct Coupling Line to Ground Reference Plane: 1KV increments up to 2kv for a minimum of 1 min. at each voltage. Direct Coupling Neutral to Ground Reference Plane: 1kV increments up to 2kV for a minimum of 1 min. at each voltage. Direct Coupling Ground to Ground Reference Plane: 1kV increments up to 2kV for a minimum of 1 min. at each voltage Surges EN61000-4-5: The peak value of the bi-directional surge waveform shall be 2kV for common mode and 1kV for differential modes of transient surge injection. No unsafe operation or no user noticeable degradation is allowed under any condition. Conducted Immunity EN610000-4-6: 0.15~800MHz, 10V, 80% AM Voltage Dips EN61000-4-10: 95% Dip & 10ms, 30% Dip & 500mS Voltage Interruptions EN61000-4-11, 95% reduction, 5s Fluctuations & Flicker EN61000-3-3 Harmonic Distortion EN61000-3-2 Class D Safety Certifications cTUVus UL60950-1, CB Report IEC 60950-1 Typical Outline Drawing: (REFER TO PRODUCT MECHANICAL DRAWING FOR COMPLETE INFORMATION) CONNECTORS Conn. Pin Signal 1 AC Neutral 2 AC Line 1 N/A 2 5V / 24V 3 5V / 24V 4 5V / 24V 4 GND 4 GND 4 GND A1 CN2 DERATING Aras Power Technologies 371 Fairview Way Milpitas, CA 95035 | Phone: (408) 935-8877 | sales@arastech.com 05/15/2014
ARFS-3001-05 价格&库存
很抱歉,暂时无法提供与“ARFS-3001-05”相匹配的价格&库存,您可以联系我们找货
