A000007
A000007
    ARDUINO
    KIT XBEE/SHIELD ARDUINO
A000007 数据手册
... The Xbee shield allows an Arduino board to communicate wirelessly using Zigbee. It is based on the Xbee module from MaxStream. The module can communicate up to 100 feet indoors or 300 feet outdoors (with line-of-sight). It can be used as a serial/usb replacement or you can put it into a command mode and configure it for a variety of broadcast and mesh networking options. The shields breaks out each of the Xbee's pins to a through-hole solder pad. It also provides female pin headers for use of digital pins 2 to 7 and the analog inputs, which are covered by the shield (digital pins 8 to 13 are not obstructed by the shield, so you can use the headers on the board itself). Board comes fully assembled and tested (without Arduino board). If you want to give a closer look to this shield we advise you to visit the official Xbee Shield page in the Hardware Section. 1
A000007 价格&库存
很抱歉,暂时无法提供与“A000007”相匹配的价格&库存,您可以联系我们找货
