A000064
A000064
    ARDUINO
    ARDUINO SHIELD - WIRELESS
A000064 数据手册
            A R D U I N O   W I R E L E S S   P R OTO   SHIELD  Code: A000064  The Wireless Proto shield allows an Arduino board to communicate  wirelessly using a wireless Xbee module or similar     The Wireless Proto shield allows an Arduino board to communicate wirelessly  using a wireless module. It is based on the Xbee modules from Digi, but can use  any module with the same footprint. The module can communicate up to 100 feet  indoors or 300 feet outdoors (with line‐of‐sight). It can be used as a serial/usb  replacement or you can put it into a command mode and configure it for a variety  of broadcast and mesh networking options. The shields breaks out each of the  Xbee's pins to a through‐hole solder pad.  This shield doesn't have the SD socket.  An on‐board switch allows the wireless module to communicate with the USB‐to‐ serial converter or with the microcontroller.  Getting Started  You can find in the Getting Started section all the information you need to  configure your board, use the Arduino So ftware (IDE), and start tinker with coding  and electronics.  https://www.arduino.cc/en/Guide/HomePage   OSH: Schematics  Arduino Wireless Proto Shield is open‐source hardware! You can build your own  board using the following files:    EAGLE FILES IN .ZIP   https://www.arduino.cc/en/uploads/Main/arduino‐wireless‐proto‐shield‐ reference‐design.zip    SCHEMATICS IN .PDF  https://www.arduino.cc/en/uploads/Main/arduino‐wireless‐proto‐shield‐ schematc.pdf  Switch Settings  The Wireless Proto shield has an on‐board switch labelled Serial Select. It  determines how the Xbee's serial communication connects to the serial  communication between the microcontroller (ATmega8 or ATmega168) and USB‐to‐ serial chip on the Arduino board.        When in the Micro position, the DOUT pin of the wireless module is connected to  the RX pin of the microcontroller; and DIN is connected to TX. The wireless module  will then communicate with the microcontroller. Note that the RX and TX pins of  the microcontroller are still connected to the TX and RX pins (respectively) of the  USB‐to‐serial converter. Data sent from the microcontroller will be transmitted to  the computer via USB as well as being sent wirelessly by the wireless module. The  microcontroller will not be programmable via USB in this mode.        With the switch in the USB position, the DOUT pin the wireless module is  connected to the RX pin of the USB‐to‐serial converter, and DIN on the wireless  module is connected to the TX pin of the USB‐to‐serial converter. This means that  the module can communicate directly with the computer. The microcontroller on  the board will be bypassed. To use the shield in this mode, you must program the  microcontroller with an empty sketch (shown below), or remove it from the board.    Empty sketch:  void setup() { }  void loop() { }    [GetCode] ht tps://www.arduino.cc/en/Main/ArduinoWirelessShield?action=sourceblock&num=1     Networking  The Wireless Proto shield can be used with different modules with the same  footprint as the XBeemodules. The instructions below are for the XBee 802.15.4  modules (sometimes called "Series 1" to distinguish them from the Series 2  modules, although "Series 1" doesn't appear in the official name or product  description) and also for the XBee ZNet 2.5 or XBee ZB modules, both known as  "Series 2" modules. All the modules, basically have the same type of configuration  parameters, but differ by the function that they implement and the topologies of  networks that they can create. Can communicate with each other only modules of  the same family.  Addressing  There are multiple parameters that need to be configured correctly for two  modules to talk to each other (although with the default settings, all modules  should be able to talk to each other). They need to be on the same network, as set  by the ID parameter (see "Configuration" below for more details on the  parameters). The modules need to be on the same channel, as set by  the CHparameter. Finally, a module's destination address (DH and DL parameters)  determine which modules on its network and channel will receive the data it  transmits. This can happen in a few ways:       If a module's DH is 0 and its DL is less than 0xFFFF (i.e. 16 bits), data transmitted by that  module will be received by any module whose 16‐bit address MY parameter equals DL.    If DH is 0 and DL equals 0xFFFF, the module's transmissions will be received by all  modules.    If DH is non‐zero or DL is greater than 0xFFFF, the transmission will only be received by  the module whose serial number equals the transmitting module's destination address  (i.e. whose SH equals the transmitting module's DH and whose SL equals its DL).    Again, this address matching will only happen between modules on the same  network and channel. If two modules are on different networks or channels, they  can't communicate regardless of their addresses.    For the "Series 2" modules you must chose which firmware put on the module to  give it Coordinator, Router or End Device functionality. Series 2 use only serial low  (SL) and serial high (SH) for addressing.  Configuration  Here are some of the more useful parameters for configuring your Xbee module.  For step‐by‐step instructions on reading and writing them using AT commands, see  the:      guide to the Wireless shield with the 802.15.4 modules.  https://www.arduino.cc/en/Guide/ArduinoWirelessShield    guide to the Wireless shield with the ZNet 2.5 modules.  https://www.arduino.cc/en/Guide/ArduinoWirelessShieldS2    Make sure to prepend AT to the parameter name when sending a command to the  module (e.g. to read the ID parameter, you should send the command ATID).            Command  Description  Valid Values  Default Value  ID   The network ID of the XBee module.  0 ‐ 0xFFFF  3332  CH   The channel of the XBee module.  0x0B ‐ 0x1A  0X0C  SH  and SL  T he serial number of the XBee module  ( SH  gives the high 32 bits,  SL  the low 32  MY   bits). Read‐only.  0 ‐ 0xFFFFFFFF   different for  each module  (for  both SH  and SL )  The 16‐bit address of the module.  0 ‐ 0xFFFF  DH  and DL  T he destination address for wireless  communication ( DH  is the high 32  bits,  DL  the low 32).  BD   0  0 ‐ 0xFFFFFFFF   0 (for  both DH  and DL )  (for  both DH  and DL )  The baud rate used for serial  0 (1200 bps)  communication with the Arduino board or  1 (2400 bps)  computer.  2 (4800 bps)   3 (9600 bps)   4 (19200 bps)   5 (38400 bps)   6 (57600 bps)   7 (115200 bps)  3 (9600 baud)    Note: although the valid and default values in the table above are written with a  prefix of "0x" (to indicate that they are hexadecimal numbers), the module will not  include the "0x" when reporting the value of a parameter, and you should omit it  when setting values.    Here are a couple more useful commands for configuring the XBee module (you'll  need to prependAT to these too).    Command  Description  RE   Restore factory default settings (note that like parameter changes, this is  not permanent unless followed by the  WR  command).  WR   Write newly configured parameter values to non‐volatile (long‐term)  storage. Otherwise, they will only last until the module loses power.  CN   Exit command mode now. (If you don't send any commands to the module  for a few seconds, command mode will timeout and exit even without  a  CN  command.)    For more details on configuring the XBee module, see the 802.15.4 modules  product manual or the ZB modules product manual from Digi International.    http://www.digi.com/products/wireless‐wired‐embedded‐solutions/zigbee‐rf‐modules/zigbee‐ mesh‐module/xbee‐zb‐module#docs    http://www.digi.com/products/wireless‐wired‐embedded‐solutions/zigbee‐rf‐modules/zigbee‐ mesh‐module/xbee‐zb‐module#docs                                                   https://store.arduino.cc/usa/arduino‐gsm‐shield‐2‐antenna‐connector 12‐7‐17
A000064 价格&库存
很抱歉,暂时无法提供与“A000064”相匹配的价格&库存,您可以联系我们找货
推荐型号
