A000065
A000065
    ARDUINO
    ARDUINO SHIELD - WIRELESS SD
A000065 数据手册
  ARDUINO WIRELESS SD SHIELD  Code: A000065      The Wireless SD shield allows an Arduino board to communicate  wirelessly using a wireless Xbee module or similar plus a micro‐SD  card slot  OVERVIEW   The Wireless SD shield allows an Arduino board to communicate wirelessly using a wireless module. It is based on the Xbee modules from Digi, but can use any module with the same footprint. The module can communicate up to 100 feet indoors or 300 feet outdoors (with line-of-sight). It can be used as a serial/usb replacement or you can put it into a command mode and configure it for a variety of broadcast and mesh networking options. The shields breaks out each of the Xbee's pins to a through-hole solder pad. Included on board is a SD card slot. When using the SD Library to access the card, Pin 4 is CS and cannot be used otherwise. SPI also relies on pins 11, 12, and 13 for communication. An on-board switch allows the wireless module to communicate with the USB-toserial converter or with the microntroller.  Switch Settings The Wireless SD shield has an on-board switch labelled Serial Select. It determines how the Xbee's serial communication connects to the serial communication between the microcontroller (ATmega8 or ATmega168) and USB-to-serial chip on the Arduino board. When in the Micro position, the DOUT pin of the wireless module is connected to the RX pin of the microcontroller; and DIN is connected to TX. The wireless module will then communicate with the microcontroller. Note that the RX and TX pins of the microcontroller are still connected to the TX and RX pins (respectively) of the USB-to-serial converter. Data sent from the microcontroller will be transmitted to the computer via USB as well as being sent wirelessly by the wireless module. The microcontroller will not be programmable via USB in this mode. With the switch in the USB position, the DOUT pin the wireless module is connected to the RX pin of the USB-to-serial converter, and DIN on the wireless module is connected to the TX pin of the USB-to-serial converter. This means that the module can communicate directly with the computer. The microcontroller on the board will be bypassed. To use the shield in this mode, you must program the microcontroller with an empty sketch (shown below), or remove it from the board. Empty sketch: void setup() { } void loop() { } [Get Code] Networking The Wireless SD shield can be used with different modules with the same footprint as the XBeemodules. The instructions below are for the XBee 802.15.4 modules (sometimes called "Series 1" to distinguish them from the Series 2 modules, although "Series 1" doesn't appear in the official name or product description) and also for the XBee ZNet 2.5 or XBee ZB modules, both known as "Series 2" modules. All the modules, basically have the same type of configuration parameters, but differ by the function that they implement and the topologies of networks that they can create. Can communicate with each other only modules of the same family. Addressing There are multiple parameters that need to be configured correctly for two modules to talk to each other (although with the default settings, all modules should be able to talk to each other). They need to be on the same network, as set by the ID parameter (see "Configuration" below for more details on the parameters). The modules need to be on the same channel, as set by the CHparameter. Finally, a module's destination address (DH and DL parameters) determine which modules on its network and channel will receive the data it transmits. This can happen in a few ways:    If a module's DH is 0 and its DL is less than 0xFFFF (i.e. 16 bits), data transmitted by that  module will be received by any module whose 16‐bit address MY parameter equals DL.  If DH is 0 and DL equals 0xFFFF, the module's transmissions will be received by all  modules.  If DH is non‐zero or DL is greater than 0xFFFF, the transmission will only be received by  the module whose serial number equals the transmitting module's destination address  (i.e. whose SH equals the transmitting module's DH and whose SL equals its DL).  Again, this address matching will only happen between modules on the same network and channel. If two modules are on different networks or channels, they can't communicate regardless of their addresses.  For the "Series 2" modules you must chose which firmware put on the module to give it Coordinator, Router or End Device functionality. Series 2 use only serial low (SL) and serial high (SH) for addressing. Configuration Here are some of the more useful parameters for configuring your Xbee module. For step-by-step instructions on reading and writing them using AT commands, see the:   guide to the Wireless shield with the 802.15.4 modules.  guide to the Wireless shield with the ZNet 2.5 modules.  Make sure to prepend AT to the parameter name when sending a command to the module (e.g. to read the ID parameter, you should send the command ATID).  Command Description  Valid Values  Default Value  ID   The network ID of the XBee module.  0 ‐ 0xFFFF  3332  CH   The channel of the XBee module.  0x0B ‐ 0x1A  0X0C  SH  and SL The serial number of the XBee module  ( SH  gives the high 32 bits,  SL  the low 32  bits). Read‐only.  0 ‐ 0xFFFFFFFF   different for  each module  (for  both SH  and SL )  MY   0 ‐ 0xFFFF  The 16‐bit address of the module.  0  DH  and DL The destination address for wireless  communication ( DH  is the high 32  bits,  DL  the low 32).  0 ‐ 0xFFFFFFFF   0 (for  both DH  and DL )  (for  both DH  and DL )  BD   0 (1200 bps)  1 (2400 bps)  2 (4800 bps)   3 (9600 bps)   4 (19200 bps)   5 (38400 bps)   6 (57600 bps)   7 (115200 bps)  The baud rate used for serial  communication with the Arduino board or  computer.  3 (9600 baud)  Note: although the valid and default values in the table above are written with a prefix of "0x" (to indicate that they are hexadecimal numbers), the module will not include the "0x" when reporting the value of a parameter, and you should omit it when setting values.  Here are a couple more useful commands for configuring the XBee module (you'll need to prependAT to these too). Command  Description  RE   Restore factory default settings (note that like parameter changes, this is  not permanent unless followed by the  WR  command).  WR   Write newly configured parameter values to non‐volatile (long‐term)  storage. Otherwise, they will only last until the module loses power.  CN   Exit command mode now. (If you don't send any commands to the module  for a few seconds, command mode will timeout and exit even without  a  CN  command.)  For more details on configuring the XBee module, see the 802.15.4 modules product manual or the ZB modules product manual from Digi International.        https://store.arduino.cc/usa/arduino‐wirelss‐sd‐shield 11‐30‐17
A000065 价格&库存
很抱歉,暂时无法提供与“A000065”相匹配的价格&库存,您可以联系我们找货
推荐型号
