UNO WIFI REV2
Add WiFI to your devices with
the Arduino Uno WiFi. It's
basically an Arduino Uno Rev3
with more kic.
Uno WiFI Rev2 comes with a brand new
8-bit microprocessor from Microchip, and
an onboard IMU (Inertial Measurement
Unit). As for the WiFi connection, that's
made secure with the new ECC608 crypto
chip accelerator.
STORE.ARDUINO.CC/ARDUINO-UNO-WIFI-REV2
UNO WIFI REV2
ARDUINO MICROCONTROLLER
Add this board to a device and you'll be able to
connect it to a WiFi network, using its secure
ECC608 crypto chip accelerator. The Arduino
Uno WiF incorporates a brand new 8-bit
microprocessor from Microchip and has an
onboard IMU (Inertial Measurement Unit).
The Wi-Fi Module is a self-contained SoC with
integrated TCP/IP protocol stack that can
provide access to a Wi-Fi network, or act as an
access point. It supports OTA (over-the-air)
programming, either for transfer of Arduino
sketches or Wi-Fi firmware.
The Arduino Uno WiFi has 14 digital
input/output pins—6 can be used as PWM
outputs—6 analog inputs, a 16 MHz ceramic
resonator, a USB connection, a power jack, an
ICSP header, and a reset button. Simply
connect it to a computer with a USB cable or
power it with an AC adapter or battery to get
started.
Microcontroller
ATMega 4809
Architecture
AVR
Operating Voltage
5V
Flash Memory
48 KB
SRAM
6 KB
EEPROM
256 byte
DC Current per I/O Pin
40 mA (I/O Pins)
GENERAL
Input Voltage
7-12 V
Digital I/O Pins
Interfaces
I2C, SPI, UART
PWM Output
5
Analog I/O Pins
6/0
Weight
8.9 g
Product Code
ABX00021
很抱歉,暂时无法提供与“ABX00021”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+383.65636
- 10+367.25456
- 25+352.10242
- 100+314.24810
